Changing voltages.
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    Changing voltages.
    I have a friend who brought me his PC. He says it's been acting up. It takes around 10 minutes to shut down and it's running Windows 10. He updated it from 7 to 10, 64-bit. It has 4 gigs of RAM, running at 800MHz. It has an E5200 Dual-Core @ 2.50GHz. The onboard video seems to be a bit cheap. Total memory in the BIOS shows 4096MB with 8MB shared memory and 1MB GTT memory. I was planning on replacing the thermal paste, cleaning it real good, backing up his data, formatting and doing a clean install of 10. I went to the hardware monitor in the BIOS and noticed some that I wanted some advice on.
    I see the Vcore voltage is changing. 1.208V - 1.232v. I also see the +3.30V changing. 3.344V - 3.60V. THe 5.00V changes as well, 5.040V to 5.064V. Finally, the 12.00V changes. 12.144V - 12.196V. The ranges might be a bit different, I got tired of watching them. Is it normal for a PC to change voltage a little bit like that? I know it's not much of a change, but I'd think the voltages would be stable. All I can think is maybe the board is doing some sort of auto-overclock or something and changes some of those voltages automatically...
    If not, do you guys know what might cause this? It's an AsRock G31M-S board.
    Thanks!
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
    • 31150
    Re: Changing voltages.
    bad caps will cause voltage drift like that.
    another sign is fluctuating fan rpm in the bios.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      And a third is that voltage monitors built in to mainboards are notoriously bad.
      Use a DMM to check the voltages instead and ignore what the BIOS thinks
      • Spork Schivago
        • Mar 2012
        • 4734
        The fan RPM is fluctuating as well. I thought maybe it was just trying to adjust to the temp. So with a fluctuating fan RPM and the fluctuating voltages, definitely bad caps?
        • Spork Schivago
          • Mar 2012
          • 4734
          Thanks Per Hansson. Even though I've worked on computers for a very long time and know a good deal about them, I'm afraid that is beyond my current knowledge. What exactly would I be measuring on the board with the DMM? For example, the Vcore, 3.30V, 5.00V, 12.00V....are there normally test points that say Vcore for me to measure? Or would I need a schematic or something to find these test points?
          For the fan RPMs, I believe I can just use my Hz mode on my DMM. From what I've googled, I just measure on the tach wire and multiple by 30. Does that sound right?
          If it is bad caps, would you think they'd be the caps in the VRM circuit?
            • 31150
            scope the power connector on the board.
            the monitoring chips arent accurate, but they are stable.
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              Thanks!
              So I am wondering is the Ram 800 MHz the speed of the Ram or the speed of the Bus? I would think the Ram speed needs to be faster?
              • fzabkar
                • Mar 2009
                • 772
                Some of the voltage readings don't make sense to me, and that's not because of any inaccuracy in the hardware monitor IC.
                AFAICT, the Super IO chip is an ITE IT8718F:
                https://cdn.badcaps-static.com/pdfs/...45f7d6b508.pdf
                The chip's ADC is 8-bit with a 4.096V reference. This means that it can resolve voltages in increments of 16mV (= 4096 / 256). The lower voltages (+3.3V, +2.5V/Vmem, Vcore, Vbat, 3V3_STBY) can be measured directly, but higher voltages (+5V, 5V_STBY, +12V) need to be stepped down via voltage dividers. Hardware monitor software typically has problems measuring the higher voltages because it is unaware of the voltage divider ratios. The motherboard's own BIOS, however, shouldn't have such a problem.
                In the OP's case the Vcore readings do not differ by an integral multiple of the ADC resolution.
                1.208V = 75.5 counts x 16mV per count
                1.232V = 77 counts
                3.344V = 209 counts
                If we assume that the scale factor for the 5V readings is 1.5, then the resolution would be 24mV. This is consistent with the readings.
                If the OP's 12V readings are accurate, then we can assume that the difference of 52mV corresponds to a single count.
                So 256 counts x 52mV per count = 13.312V
                ... and the scale factor is 52 / 16 = 3.25
                Note that many (most?) PC PSUs regulate the output voltages by sensing the weighted average of the +5V and +12V rails. This means that when the +5V rail drops (eg by -20mV), the +12V rail rises (eg by +50mV).
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Don't overdo it, just shove a DMM probe into an empty HDD molex connector from the PSU or whatever else is convenient.
                  VCore is usually quite easy to measure via a coil or something close to the CPU, but that's overkill for now, you just want to confirm if the reading on the mobo is bullshit or not.
                  • Spork Schivago
                    • Mar 2012
                    • 4734
                    The 24 pin one or the 4-pin one that's for the CPU? Would I see the changing voltages on either of those? If the PSU is good, wouldn't those voltages be normal at that point in the circuit and not be fluctuating until after the bad capacitor? Still in the progress of learning how electricity works.
                    If I have a 12v power supply on a circuit and then say a few resistors in there, in series, wouldn't the voltage be 12v before the first load (resistor), and then after each resistor it'd get lower until there were no loads left in the circuit, in which case it'd be 0v?
                    I'd think if the voltage was fluctuating because of a bad cap, before the bad cap, it'd be normal. Am I wrong in thinking that? Thanks!
                    • Spork Schivago
                      • Mar 2012
                      • 4734
                      The board says the bus is 1600 MHz. Whether it's running at 1600 MHz or not, I'm not sure. The RAM is DDR-1066 with a CL5-5-5-15 (2.0 - 2.1v), G.Skill F2-8500CL5D-4GBPK. The base frequency of the FSB would be 400MHz, right? The BIOS only has options to run the RAM at 667MHz or 800MHz, but my understanding is, unless someone's overclocking the FSB, there's no real point in running the RAM at a faster speed. Probably why the board only gives the option for 667MHz or 800MHz. Am I right in thinking that?
                      • Spork Schivago
                        • Mar 2012
                        • 4734
                        1.232V = 77 counts
                        3.344V = 209 counts
                        Although I don't understand everything you said, parts of it makes sense. I wanted to add that the voltage monitor in the BIOS, when the voltages change, they're always changing to the same numbers. Just as an example, the 3.30V would be 3.344V or 3.60V. Never 3.350V, etc. That's just an example though. I remember for some of the values, there would be maybe 3 or 4 numbers it would change too.
                        The 12V one was the one that I watched the least. It was at the bottom of the list and I got tired of waiting for it to change and just jotted it down real quick like. If you'd like, I can start the machine back up and be more thorough with the voltages. I can list exactly what voltages it's changing to, instead of listing the lowest voltage it changes to and the highest voltage it changes to.
                        Would you like me to do that? If I do, I'm sure we could figure out that voltage divider ratio for certain.
                        • Spork Schivago
                          • Mar 2012
                          • 4734
                          Okay. I also have a PSU tester. I can pull the 24 pin + the 4 pin CPU power supply, plug it into my tester and see what the voltages say, if you'd like. I think it only goes out to two significant digits though (ie, 3.31).
                          I'll grab the pinout for the 24-pin connector and measure the various voltages using the DMM and post back.
                          • Spork Schivago
                            • Mar 2012
                            • 4734
                            OMG! There's this terrible smell inside! I'm not trying to be mean here, but sometimes old people smell like this. I think it might be like a mothball type of smell. The friend is definitely a bit older and his cloths smell just like this, but usually not as strong.
                              • 31150
                              refering to the psu i hope?
                              time to get it open for some visual recon.
                              • Spork Schivago
                                • Mar 2012
                                • 4734
                                Using the 24-pin connector, I've measured, with my DMM, the 3.3v, 5v, 12v, and -12v pins. There's four 3.3v pins, but they all ready the same. That's true for all the voltage pins I've measured. So instead of posting all four 3.3v readings, I'll post one.
                                Code:
                                3.3v = ( 3.370v through 3.376v) -- changes frequently.
                                 5v = ( 5.08v )        -- seems steady.
                                 12v = ( 12.08v through 12.10v) -- jumps to 12.10v and stays at 12.10v.
                                -12v = (-11.78v through -11.80v) -- seems to jump between the range.
                                • Spork Schivago
                                  • Mar 2012
                                  • 4734
                                  No, the whole computer inside smells like this, not just the PSU. I opened up the case to the PC and it's awful!
                                    • 31150
                                    open the psu, those outputs should be rock-stable.
                                    specially as a psu tester has no real load in it.
                                    you should have metered it connected to the motherboard atleast.
                                    • Spork Schivago
                                      • Mar 2012
                                      • 4734
                                      I did meter it connected to the board, instead of the PSU tester, because the DMM has better resolution. Should I check the voltages hooked to the PSU tester as well?
                                        • 31150
                                        no, open it.
                                        • Capacitorial
                                          Powersupply has all the voltages - Monitor still no power
                                          by Capacitorial
                                          Hello guys,
                                          I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                          I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                          On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                          The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                          The weird thing is, that the Power LED is powered over the TCON board.
                                          On The TCON...
                                          12-28-2024, 02:12 PM
                                        • gjgib
                                          Help reading schematic voltages input/output
                                          by gjgib
                                          Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
                                          I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
                                          I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
                                          I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
                                          05-06-2024, 08:11 PM
                                        • RossMoodley1967
                                          HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
                                          by RossMoodley1967
                                          Hello
                                          Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
                                          Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
                                          03-01-2024, 06:07 AM
                                        • karlp028
                                          MSI Z390-A PRO missing VCORE voltages
                                          by karlp028
                                          I've got an MSI Z390-A Pro motherboard that starts up fine, but it's missing the VCORE (and VGT) voltages. All of the other voltages are present (e.g. VCCSA, VCCIO) and I know the CPU (i7-9700k) is good. Now, the original PWM controller (UP9521P) had an internal short and I replaced it with a new one. All of the enable signals look good. The problem seems to be the PWM signals going to the MOSFET drivers. I checked them with an oscilloscope and they are all flat 1.5V with no pulses. I don't know why this would be and I'm not sure where to look next.
                                          06-23-2025, 01:25 AM
                                        • lol999
                                          Asus Prime x299 Deluxe - no VCCIO VCCSA voltages
                                          by lol999
                                          Motherboard after starting show Q code 00.
                                          No shorts on any rail ( at last I can't finde any)
                                          All voltage are correct on SIO - 3.3V, PCH power 1V , DDR 1.2V, SPI 8 leg 3.3V
                                          Nothing get hot, PSU starting, all lights came ON....
                                          One thing i can see incorrect is no VCCIO and VCCSA voltages and no main power on CPU.
                                          After deep looking I found dead Synchronous Buck converter CSD97374Q4M that is powering VCCIO for CPU but after replacing it nothing changed. Voltages on it are correct....
                                          This buck converter is PWM'ed by Asus DigiVRM ASP1405I-62T. Can't finde any datasheet...
                                          01-21-2024, 02:25 PM
