ESR meter kit - not working
  • xelectech
    retired tech
    • Nov 2014
    • 238
    Ok, I got the kit from a diy-type website supposedly based in New York and assembled it, pretty straight forward; except, it doesn't do anything other than light the back light on the display. I suspect that it's the Atmega 168, which is supposedly pre-programmed, but I have no idea how this thing is supposed to work, nor how to check it, hope somebody here might be able to help me out.
    It has a 78L05 which is putting out 4.97vdc, and everything is wired according to the schematic - I'm feeding it 9vdc, it's drawing 25mA. I've got emails into them (since first thing yesterday morning), not heard from them yet. I've got a Cen-Tech Dvmm, no logic probe or scope.
    Please see attachments: (can't seem to attach the schematic, guess I'll do another post)
  • xelectech
    retired tech
    • Nov 2014
    • 238
    Re: ESR meter kit - not working
    Huh, msg. too short error, what else can I do wrong...
    • SteveNielsen
      Retired Tech
      • 2327
      Turn up the contrast control?
        • 31091
        that's an ancient design, it doesnt even use a crystal!
        it may be similar to page11
        • xelectech
          retired tech
          • Nov 2014
          • 238
          I've tried setting the pot across it's full range, it has no effect.
            • 31091
            contact the seller,
            if you have 5v then it's probably the atmel because there really isnt much else.
            • xelectech
              retired tech
              • Nov 2014
              • 238
              Supposedly its using a crystal that is contained in the Atmega168.
              Thanks for the pdf, yours has a bunch more circuitry. I'll have to spend some time and see if the literature lends me any clues.
              • xelectech
                retired tech
                • Nov 2014
                • 238
                looked up the data sheet - it's actually an Atmega168A-pu, guess I'll be reading for awhile
                http://html.alldatasheet.com/html-pd...GA168A-PU.html
                  • 31091
                  internal R/C oscillator, not a crystal.
                  crystals are prefered for acuracy.
                  so is a 328 cpu - double the flash space.
                  • xelectech
                    retired tech
                    • Nov 2014
                    • 238
                    You can bet that I'm now wishing I just bought the already-assembled one on ebay.
                    Got an email back from DIY-electronics, looks like they're gonna drag this out as long as they can...
                      • 31091
                      if you had a programmer you could make up a second chip to test the board or dump the fuses on the supplied chip.
                      it wouldnt surprise me if the fuse-bytes are configured for a crystal given the board has a space for one!
                      • xelectech
                        retired tech
                        • Nov 2014
                        • 238
                        Nope, no programmer, wouldn't know what to do with one. Something is going on inside of there though (in the 168 IC), there's one pin that changes from hi to lo to hi at about a five second interval and another one thats briefly changes state then goes back to hi on a much briefer interval.
                        Also wondering, is it of any significance that, on the display's input, data lines d-4 and d7 have 0 volts but the other six have about 5vdc - that's whether I'm pushing the test button or not.
                        • R_J
                          • 9558
                          Why does this picture from electronics-diy and the sheet you posted in #2 show a crystal?
                          After checking I guess the Atmega328p can be used without a crystal.
                            • 31091
                            both can be used with or without a crystal.
                            BUT you need to configure that with your programmer!
                            • R_J
                              • 9558
                              Well I guess the one in their picture was programmed to use a crystal.
                              • xelectech
                                retired tech
                                • Nov 2014
                                • 238
                                I wouldn't recommend electronics-DIY. com, they seem not to be very customer-oriented.
                                I've been trying to find their phone # so they can answer more than one question a day but so far no luck. I'm also wondering why they call it an atmega168/328 esr meter when its actually powered by the lesser 168 chip.
                                However, some headway has been made, thanks to Redwire's help in the thread 'LCD display compatibility'; I needed to turn down the voltage going to the contast pin of the display.
                                  • 31091
                                  i seem to remember a thread about esr kits - was it you?
                                  because i recommended a chinese 328 based graphic one.
                                    • 31091
                                    with or without a case.
                                    http://www.banggood.com/DIY-M12864-G...-p-986954.html
                                    http://www.banggood.com/DIY-M12864-G...-p-997023.html
                                    • xelectech
                                      retired tech
                                      • Nov 2014
                                      • 238
                                      That might have been me, I did look at them but, being unfamiliar with paying on line and hating to web-surf with javascript enabled, I had to pass on that possibility.
                                      • SteveNielsen
                                        Retired Tech
                                        • 2327
                                        Your javascript paranoia cost you $40.
                                        • chth96
                                          Is it possible to test small ceramic disc capacitor with analogue meter?
                                          by chth96
                                          I read EBOOK of Testing Electronic Component and found that
                                          "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                          Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                          It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                          Is it really possible to test small ceramic disc capacitor with analogue...
                                          03-09-2024, 10:03 PM
                                          Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                          by sam_sam_sam
                                          I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                          I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                          12-31-2023, 06:04 AM
                                        • jorpec
                                          Changing the scale of an analog meter
                                          by jorpec
                                          Hi
                                          I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                          I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                          Thnaks
                                          01-23-2023, 10:37 AM
                                          How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                          by sam_sam_sam
                                          About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                          Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                          Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                          12-14-2023, 07:45 PM
                                        • Stephan Mathers
                                          EDMI ATLAS MK10 Electronic Meter Discussion
                                          by Stephan Mathers
                                          Greetings, new guy here but always interested in the crazy universe of modding
                                          We just finished construction of around 25 vacation houses, all inside the same private area.
                                          Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
                                          The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
                                          Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
                                          05-20-2025, 09:09 AM
