ESR meter kit - not working
  • xelectech
    retired tech
    • Nov 2014
    • 238
    Re: ESR meter kit - not working
    Originally posted by stj
    if you run firefox then install this:
    https://www.eff.org/privacybadger
    I'm running an older version of firefox - I hate upgrading FF cause the times I have there's generally changes that screwed up my previously-learned usage habits.
    After reading about both Ghostery and Privacybadger, I have to wonder if the newer FF
    still has an option in the preferences having to do with "do not track". Sounds like Ghostery is going to yield some info on the trackers, but whether that's the case with Privacybadger is not so clear.
    So what browser (and version) do you use, ?
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      #42
      im running the latest firefox version for windows 7 and it does have a option saying do not track
        • 31204
        Opera
        classic PRESTO based 12.16
        • xelectech
          retired tech
          • Nov 2014
          • 238
          Opera
          I guess I'll have a closer look at Privacybadger, learned that the EFF is behind it, so it
          warrants further review.
            • 31204
            it's interesting,
            each time it finds something it adds it to a list,
            the list has toggles so you can choose to block or not.
            • chth96
              by chth96
              03-09-2024, 10:03 PM
              12-31-2023, 06:04 AM
            • jorpec
              by jorpec
              Hi
              Thnaks
              01-23-2023, 10:37 AM
              Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
              12-14-2023, 07:45 PM
            • Stephan Mathers
              EDMI ATLAS MK10 Electronic Meter Discussion
              by Stephan Mathers
              Greetings, new guy here but always interested in the crazy universe of modding
              We just finished construction of around 25 vacation houses, all inside the same private area.
              Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
              The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
              Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
              05-20-2025, 09:09 AM
