stop 0X00000024
  • tva
    • Nov 2015
    • United Kingdom
    stop 0X00000024
    0X00000024 I recieve this message on an HP computer as I was loading a program the mains went off and now I get this.I don't have a disc XP is there anything I can do.
  • Sparkey55
    • Jan 2010
    • 1523
    Re: stop 0X00000024
    You will need an Windows XP cd in order to run the Recovery Console that has the checkdisk command. Your files are screwed up from the power loss. Borrow one from a friend if you can.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Re: stop 0X00000024
      You're required to reformat the drive and reinstall XP. NTFS is trashed!
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • Sparkey55
        • Jan 2010
        • 1523
        Re: stop 0X00000024
        I would give the repair tools a chance first. Chkdsk then Fixboot and if needed Fixmbr, then its time to format and install XP.
          • 30994
          Re: stop 0X00000024
          that's one shitty FS if that's all it takes to trash it.
          sounds like windows needs an Ext4 driver.
          • RJARRRPCGP
            • Jul 2004
            • 6304
            Re: stop 0X00000024
            Probably because it was in middle of writing files.
            Arc A770 16 GB
            • Sparkey55
              • Jan 2010
              • 1523
              Re: stop 0X00000024
              I would think that you want to blame Isreal for the power outage and Syrian refugees for the file corruption.
                • 30994
                Re: stop 0X00000024
                IsraHell probably made the cpu!
                if your in the middle of a file write and lose power you should only lose the file.
                • goontron
                  5000!
                  • Dec 2011
                  • 4108
                  • US
                  Re: stop 0X00000024
                  sounds like winblows needs an Ext4 driver.
                  Fuck EXT4, Let's see BTRFS!
                  Follow the white rabbit.
                    • 30994
                    Re: stop 0X00000024
                    too new - if i want new i'll use ZFS.
                    • Joseph cauchi
                      jccomputers
                      • Jan 2015
                      • 89
                      • Malta
                      Re: stop 0X00000024
                      Please check HP Hard Drive Native Mode Configuration in BIOS Setup.
                      1. GOTO BIOS ROM Setup by pressing F10 key on keyboard.
                      2. Goto Advanced Tab and select On Board Devices.
                      3. Change the Valeu of SATA Hard Drive Native Mode from Enable to Disable.
                      4. After Disable the value save and exit from BIOS Setup. and continue to boot from Windows XP CD.
                      Let me know if it fix.
                      thanks & Best Regards,
                      Joseph
                      • ChaosLegionnaire
                        HC Overclocker
                        • Jul 2012
                        • 3264
                        • Singapore
                        Re: stop 0X00000024
                        i think one already exists. its called ext2fsd tho its a project run out of sourceforge. the recent versions also support all the ext4 features/functions. really ingenious way the linux guys setup the linux extended filesystem with regards to both backward and forward compatibility.
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          Re: stop 0X00000024
                          wont be the first time i have seen windows hosed by a power blink.
                          disk scans,check smart, memtest,ect if no go and hardware is ok back up and reload.
                            • 30994
                            Re: stop 0X00000024
                            that's been around a while, but you cant use it on the boot-drive!
                            windows users should stick to FAT32, atleast you can recover it.
                            • Junior††
                              PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
                              by Junior††
                              Good Afternoon fellas,
                              Issue:
                              Disc is showing as not supported when a disc is put in.
                              Here's what I've done, you can skip this if you just wanna know the question:
                              - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
                              - reflowed the disc drive connector
                              -reflowed the chip in question (shown on image)
                              - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
                              Question:
                              I...
                              02-19-2025, 12:48 PM
                            • x_orange90_x
                              Seven Leagues Slot Machine stop button issues
                              by x_orange90_x
                              I don't know if anyone here has experience with Japanese slot (pachislo) machines, but I sure hope so. I bought this machine last week in semi-working order. It would play and the reels would spin, but the stop buttons would not stop them at all. I found that the high-frequency filtering tantalum capacitor was bad on the reel stop board, along with the fuse being blown. I replaced the fuse and removed the capacitor. I haven't replaced the cap yet because I didn't have one on hand, but it's not necessary for the operation of the machine.
                              The issue now is the Stop buttons are intermittently...
                              02-12-2025, 10:01 AM
                            • AJ847.63e
                              Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                              by AJ847.63e
                              Hi Folks,
                              Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                              I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                              The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                              05-06-2025, 10:37 PM
                            • trbovan
                              Asus GL731GT Boot loop
                              by trbovan
                              Laptop is a GL731GT with the I7-9750h and GTX1650.
                              Full model number is gl731gt-rb71-cb
                              Serial: (placeholder for when I get home)
                              Board model: G531GT REV. 1.5
                              Issue: Laptop was password protected with admin password. I extracted the Bios with the CH341A and ASprogrammer. I Initially saved the backup. I then scoured the internet for a rom to flash to the chip. I found a file and flashed it. I then read it back to verify and mistakenly over wrote my backup of the original Bios.
                              I assembled and tested anyway. The bios worked, I was able...
                              10-04-2023, 07:27 AM
                            • m4a2t0t
                              Disc caps
                              by m4a2t0t
                              Can I replace a ceramic disc cap with a multilayer ceramic cap? I cant even find .047 uf disc caps at digikey, mouser or newark. The places I do find them want anywhere from 25c to $3 each, at any quantity, plus shipping....
                              01-18-2024, 10:00 PM
