Disc caps
  • m4a2t0t
    • Mar 2013
    • 279
    Disc caps
    Can I replace a ceramic disc cap with a multilayer ceramic cap? I cant even find .047 uf disc caps at digikey, mouser or newark. The places I do find them want anywhere from 25c to $3 each, at any quantity, plus shipping.
    • 31262
    yes,
    and you can search for 47nf or 47000pf
    • PeteS in CA
      • Aug 2005
      • 3583
      • USA, Unsure of Planet
      Be sure to match the temperature coefficient if you know it. If you don't, use X7R or CGO.
      PeteS in CA
        by momaka
        03-12-2025, 03:42 PM
      • chth96
        by chth96
        03-09-2024, 10:03 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
        Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
        by momaka
        This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
        Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
        Macron Power Technology Co. LTD.
        Let’s look at the PSU itself.
        The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
        06-02-2021, 10:05 PM
