I have this strange issue with my Toshiba P25-5093 laptop where the screen will intermittently go red and/or fuzzy on very rare occasions. Most of the time the screen is fine and I don't have any problems with it.
When this problem occurs, I just get my finger and lightly tap the area near the hinges and the problem goes away and everything is normal again.
I don't know why this strange issue happens.... but I'm taking a guess that the connection of the screen cable to the motherboard is most likely loose and/or has bad contacts.
I have also tried to recreate the scenario with the red/ fuzzy display by tapping on certain areas of the laptop on purpose, but I have no luck in doing so.... so I can only assume something with bad contacts with the cable and connector.
I presume that if I had bad solder joints this problem would happen all the time and not once in a while/ very rarely and also tapping various areas of the laptop would make the issue reappear immediately.
The issue happens regardless of what i'm doing with the laptop (e.g games and idle desktop).... so I have ruled out any driver/software problems.
By the way, the graphics card is an nvidia Geforce Go FX5200 32MB and the display is a 17" WXGA display.
Does anyone know what could be wrong with my laptop?? Could my idea of the contacts and cable connections be correct??
Thanks.
Thanks.
