Pata/Sata converter anyone?
  • Uranium-235
    replied
    Re: Pata/Sata converter anyone?
    Originally posted by alessioblaupunkt
    I think I'm going to buy an IDE hd.
    unless you get it used, they're pretty expensive due to supply. Something with that motherboard is long overdue for an upgrade. Here is some cheap stuff that can run 7 great or even XP if you're willing to either try the driver install methods I mentioned above or use DMA.
    CPU - $47
    http://www.newegg.com/Product/Produc...82E16819117301
    Motherboard (H81, MSI) - $45 - Yes, it has no PCI slots
    http://www.newegg.com/Product/Produc...82E16813130731
    Ram - $28 (4GB, 1600 - I choose 1600 for a 1333 CPU cause it costs the same as 1333 and runs at cas7 instead of 9, so you get a small performance boost for the same price)
    http://www.newegg.com/Product/Produc...82E16820231277
    I'm assuming you have an ATX case, P4 PSU and of course, your SATA drive, which would be cheaper new than a IDE new
    oh shit wait, I need to correct myself, there is no XP driver for haswell HD graphics
  • fzabkar
    replied
    Measure the voltages at the IDE pins on the adapter. Do the same for the IDE pins on the motherboard. Are the TTL levels the same, or is one 5V and the other 3.3V?
  • alessioblaupunkt
    replied
    markings on the bridge IC
    First thing I did: search the datasheet: nothing found for
    IDE/SATA
    D0F
    B75K80041
    LDO regulators:
    AMS 1117
    3.3 H440PE
    AMS 1117
    1.8 H446PE
    Thanks for the page, got details even if I don't know Russian.
    Perhaps the motherboard cannot handle this low I/O voltage?
    The MB receive 3.3V and I don't know if it has 1.8V regulator in it.
    I suggest u do your research on sites with user reviews like amazon and newegg
    On amazon there are reviews reporting both working and not working unit.
    A few days ago I found this, MAC os discussion, go to reply #15 he's talking about the very
    same adapter working good with a SSD SATA3 drive.
    http://macos9lives.com/smforum/index...sg1072#msg1072
  • Th3_uN1Qu3
    replied
    I have used both Silicon Image 3112A and VIA (can't remember the model) PCI SATA cards in a dual-PIII system and they both worked ok. The Sil3112A had some isssues with the VIA Apollo Pro 133A chipset board (would hang the system for up to 30 seconds on heavy drive activity, then resume), but the VIA card still works to this day in that computer. The Silicon Image works fine on other boards with Intel and other VIA chipsets.
    Those adapters that just have ATA and power, i've had trouble with. They are either very slow, make the boot process hang for a long while before they start working, or just plain don't work.
  • Uranium-235
    replied
    Or a decent adapter at that rate.
    Yeah I see the problem, that motherboard has no sata. Problem with an adapter is the boot driver might not be compatible, especially if the card does not support generic dma and use just use ahci, which considering the motherboard you have, you probably have windows XP, and you're not going to get a matching PnP id. Vista and 7 are a bit better at this to a certain point.
    If you are planning on moving your old OS over, you might be screwed. Even if you're planning on installing XP fresh, you might be...somewhat screwed because you will either need to:
    1. Slipstream the disk with the appropriate boot driver with a tool like Nlite
    2. Have a floppy drive with the drivers on the floppy, and not all adapters have them for XP, though i'm sure some do
    using a PCI adapter will likely be faster but using a the sata-> ide adapter will likely be more compatible
    in the end, you might want to consider upgrading your whole computer because the P4S533 is limited to what you can do and is umm...like 12 years old
  • ratdude747
    replied
    Originally posted by Uranium-235
    I suggest a PCI card. A decent one from newegg
  • Uranium-235
    replied
  • fzabkar
    replied
    I found this page:
    http://www.mindrunway.ru/IDE44toSata.html
    The author of the project discusses an RXD639 bidirectional SATA<=>IDE adapter. It is based on the Sunplus SPIF223A bridge IC.
    Here is its datasheet:
    https://cdn.badcaps-static.com/pdfs/...0aeea28e28.pdf
    The two regulators provide 3.3V Vio and 1.8V Vcore. The chip does not connect to the +5V supply, so its I/O levels must be 3.3V LVTTL. Perhaps the motherboard cannot handle this low I/O voltage? That would be consistent with the multiple dropped bits.
  • fzabkar
    replied
    Don't buy RXD-629A7-7 adapter[/B][/COLOR] or any other adapter that looks like.
    You need to tell us the markings on the bridge IC. That's the important criterion, not what the baord looks like. Maybe the datasheet for the chip will tell us why it doesn't work. Maybe it has something to do with the I/O voltage. Could it be that the I/O is not 5V tolerant?
    What are the markings on the two LDO regulators (3-pin ICs)? This will probably tell us the Vcore and Vio volts for the bridge.
  • ChaosLegionnaire
    replied
    well, actually a LOT of ide to sata adapters dont work properly or are problematic especially the made in china or brandless ones.
    i suggest u do your research on sites with user reviews like amazon and newegg to know which ones work and which dont and try to order one that works in your respective area.
    as an example and for my case, none of the ide to sata adapters would work in my area. i had to import some syba and startech adapters from amazon usa which did actually work for me.
  • alessioblaupunkt
    replied
    It's the adapter:
    I checked continuity from every single IDE pin to the respective via and got continuity, so the problem is the continuity from the via to the the chip or the chip itself.
    The chip has too thin pins and I can't use my probe because of their large size.
    Here's a SATA WD hd in an ASUS P4S533-X motherboard:
    WDC WD3200┴A╩[-88L╗A0
    instead of
    WDC WD3200AAJS-08L
    Also the ASUS P4S533-X motherboard give me another name for my toshiba, different from the name my MSI motherboard could read, will report in the future.
    I'll write to the seller and report it's not working on 2 different machines.
    Character translate:
    ┴=ALT+193
    ╩=ALT+202
    [=ALT+91
    -=ALT+45
    ╗=ALT+187
    They might don't work with several SATA HD.
    ATTENTION: WRONG PICTURE IN POST #1.
  • alessioblaupunkt
    replied
    Thank you really much ESPECIALLY fzabkar and Per Hansson.
    I am not a computer expert and this is the first time I found this problem.
    Tomorrow during spare time I'll try the HD on a SATA motherboard,
    if name is ok I'll test both the adapter and HD in a IDE motherboard
    to see if in BIOS the name is wrong again.
  • Per Hansson
    replied
    Yes sure seems like it, here is a similar case I once had:
    http://forum.hddguru.com/viewtopic.php?f=1&t=25204
    So check the soldering, probably you have a loose connection in there...
  • fzabkar
    replied
    Bought and adapter quite similar to the one in post #1 and there are problems.
    Bought a different hd, different from the one in post #1.
    Here's the full description.
    The problem you have described at bleepingcomputer is due to stuck bits (0 and 3) in the IDE interface.
    Code:
    C:\>debug
    -e 100 "TFS@ABA DT00ACA0"
    -e 110 "TOSHIBA DT01ACA050"
    -d 100 11f
    1262:0100 54 46 53 40 41 42 41 20-44 54 30 30 41 43 41 30  TFS@ABA DT00ACA0
    1262:0110 54 4F 53 48 49 42 41 20-44 54 30 31 41 43 41 30  TOSHIBA DT01ACA0
    -q
    Bad model number due to stuck bit in IDE interface:
    http://www.hddoracle.com/viewtopic.php?f=59&t=147&p=262
    replied
    i have seen some adapters running on 5v when they should have a 3.3v regulator on the board.
    they run real hot and die after a few monhs.
    now the bitch is, the boards had the pads for a regulator, but the input and output had simply been bridged to save money!
  • eccerr0r
    replied
    I have a few SATA MB -> PATA drive converters, every single one work perfectly. They even worked for CDROM/DVD drives. On the other hand, I have one PATA MB -> SATA drive converter. This didn't work so well, but didn't play with it much.
    Yes and via SATA PCI boards are trouble... then again it seemed to work ok on a via motherboard... or perhaps I'm imagining things.
  • alessioblaupunkt
    replied
    Quite similar to ChaosLegionnaire.
    Sorry for posting elsewhere but I need much more people to read about this problem.
    Using the old PATA now.
  • ChaosLegionnaire
    replied
    waaa, u guys are lucky to have gotten your hands on working pata/sata converters. there's lots of fake pata/sata converters in my area almost as bad as fake caps around ebay.
    anyway, none of the pata/sata converters i got would work reliably. first one i bought was a converter u attach to the board, couldnt detect my sata2 hdd. inserted jumper to limit the drive to sata1 and drive was detectable but speed and transfer rate were unstable. ruled out that the sata cable is faulty. works fine when connected directly to another sata motherboard.
    next, when i tried a pata drive connected to a sata motherboard, the sata board simply could not recognise the pata drive. it just stuck at detecting the drive for several seconds then gave up and said "no drive detected at port".
    also, another pata/sata converter (the type that is attached to the drive) killed one of my 2tb hard drives because it couldnt supply enuff current to the drive. drive kept clicking. smart failure detected. seek error rate out of spec. drive head failure. bye bye data. it was good to have had you.
    poor me!
    replied
    seen them? i'v owned them.
    any motherboard that's old enough to only have ATA100 is unlikely to have any code in the bios to boot from SATA or even know what that is.
    i hope this does not turn into another "anything older than c2d is junk for the skip" type threads!
  • c_hegge
    replied
    Yup. I've also seen VIA SATA cards which were not bootable.
    EDIT: And owned one.
  • DynaxSC
    GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
    by DynaxSC
    I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
    There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
    The board is generally working now, all PCIe ports are working, Windows installs normally.
    However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
    The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
    03-10-2025, 12:27 PM
    HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD i7-8700K Specification for Upgrade or Repair
    This specification for the HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z2 G4 + 3TB SATA 6Gb/s 7200 HDD boardview and Z2 G4 + 3TB SATA 6Gb/s 7200 HDD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
    09-12-2024, 03:28 PM
  • clabr
    Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
    by clabr
    Need help to solve some problems with this laptop.
    After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
    After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
    Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
    Before this had happened I observed some other problems:
    When I tried replacing original mecanical HDD with a SSD HDD could not get them...
    12-02-2021, 08:09 AM
    Pegatron M2N78-LA (rev. 3.02) freezes on POST with SATA drives attached
    by momaka
    Like the title says, I have a Pegatron M2N78-LA (HP P/N: 513430-002) motherboard out of an HP Pavilion PC. The motherboard hard-locks during POST when it gets to the part of trying to detect the SATA devices *only* if there is a SATA device (be it HDD or optical drive) connected to any of the SATA ports. I cannot enter BIOS or do anything when this occurs. Pressing Ctrl+Alt+Del cannot restart the system either. In fact, the keyboard locks up too (Num Lock status LED cannot be toggled anymore.). However, if I disconnect everything from the motherboard's SATA ports, the motherboard can POST successfully...
    11-28-2020, 11:08 PM
  • playit
    psu sata power wires thinner - does it make a difference ?
    by playit
    hello , i have a psu 450 zebronics (yes its bad crap) which used to work before with its own sata power cable ,but today its not able to power up harddrive efficiently with its own power sata cable , but when there is a connector which have a thick wire than the psu sata power cable wires - its powering up and working smooth , no problem yet .
    i the voltages with multimeter shows 12 ,3.3 v , no problem , but hardrives powers well only with this thick wire sata power cable connector from psu power molex .
    any explanation on this ?? thank you ,soon i am planning to buy some branded...
    10-12-2023, 05:25 AM
