psu sata power wires thinner - does it make a difference ?
  • playit
    • Feb 2020
    • 182
    • india
    hello , i have a psu 450 zebronics (yes its bad crap) which used to work before with its own sata power cable ,but today its not able to power up harddrive efficiently with its own power sata cable , but when there is a connector which have a thick wire than the psu sata power cable wires - its powering up and working smooth , no problem yet .
    i the voltages with multimeter shows 12 ,3.3 v , no problem , but hardrives powers well only with this thick wire sata power cable connector from psu power molex .
    any explanation on this ?? thank you ,soon i am planning to buy some branded power supply of 450 watts .
    • 31262
    Re: psu sata power wires thinner - does it make a difference ?
    maybe the connector is crap,
    harddrives dont use much power, under 2A
    • playit
      • Feb 2020
      • 182
      • india
      but it used to work before , now it seems to work only with thicker wires in the connector , i tried to fix the sata powercable of psu to both drives i have firmly , still similar results ..scratching my head now ^^
        • 31262
        i meant the connector on the sata power cable may be crap
        is it sealed or can you open it to inspect the joints?
        • playit
          • Feb 2020
          • 182
          • india
          "i have the voltages with multimeter shows 12 ,3.3 v , no problem , but hardrives powers well only with this thick wire extension sata power cable connector from psu power molex ."
          its a cutter one , not sealed , but this connector which is a extension is not a cutter, its a sealed one ,
          may i dont get it what you saying
            • 31262
            im saying maybe where the wire joins to the pin inside the plastic may be bad.
            • playit
              • Feb 2020
              • 182
              • india
              ohh but i checked thier voltages , they gave right 12 v and 3.3v , umm may be they go bad when i connect to harddrive ?? i cant check the voltages while connected to hdd tho .. i am afraid of short circuit duringthat time.. damm it psu in my country is so expensive , just want a 450wats a decent one . any idea how the antec 450watts is ? its litle expensive than the other ones
                • 31262
                all good psu's are expensive now,
                i was looking at them yesterday and was shocked at some of them!
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8342
                  Only because you get voltage, doesn't mean it can carry current.
                  • playit
                    • Feb 2020
                    • 182
                    • india
                    umm looks like due to mining , psu makers wana enjoy too much profit
                    • playit
                      • Feb 2020
                      • 182
                      • india
                      so whats happening here, any explanation ? i dont have anything to measure current , i only have a basic multimeter
                      • petehall347
                        • Jan 2015
                        • 4447
                        that is all you need .
                        • playit
                          • Feb 2020
                          • 182
                          • india
                          oh i saw and kept 10amp knob,10amp positive terminal , ground at same com port , but when i tried to touch the 12v line with my positive terminal and black to ground , i see the spark in red terminal and it feels warm to hot when i touched the red terminal of multimeter, i am afraid to do it again .
                          on the multimeter i see it says at amp - 10 A , unfused 10A max for 10secmax for every 15 min , no idea what are they .
                            • 31262
                            thats not how you use it!
                            i'll be surprised if you didnt blow a fuse in the meter - if it has one
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8342
                              Think of electricity behaving like water in a hose. Speed equals voltage and the diameter of the hose equals current.
                              Besides this, there is a phenomena called "ghost voltage", where you can see power on your meter but actually there isn't any.
                              For example you have a broken wire on which the connector is only held by a couple of strands and all the other strands have broken away (kind of like i pinch the garden hose). If you turn that PSU on and measure the voltage on the output, you will say: Goodie! Got power!
                              Now you put a light bulb to it to actually trying to draw current for the light bulb to glow and it will either be dim like a candle or doesn't light up at all. To proof what's going on here is to have a load on the PSU (that light bulb) on the output, put your DMM into Volts DC and probe with one lead on the positive side of the light bulb and the negative probe on also the positive side on the other side of the bad connector. That will measure a Voltage Drop across the bad connection under load. As more voltage drop you get, as worse the connection is.
                              Hope that helps you understand in this little crash course.
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8704
                                As said earlier this is the wrong way to use the ammeter function of a multimeter. This will basically short out your power supply, good thing it didn't fry your PSU or cause other damage. There is only one possibly legitimate use for measuring current this way - and that's to measure short circuit current of solar panels - and this is okay only because solar panels are current limited unlike normal PSUs.
                                This means your multimeter doesn't have a fuse and basically will *try* to conduct hundreds of amps until it fries. Bad/Cheap. Better multimeters will have a fast acting, high rupture capability fuse to prevent the meter from becoming fireworks.
                                10A max for 10 sec every 15 min means you can measure 10 amps for 10 seconds... but after you do so you must wait 15 minutes before doing it again. This means your meter probably has a high burden voltage when measuring current - whether it's from the meter or the probes - and will get hot and burn up if you use it too much for too long.
                                • playit
                                  • Feb 2020
                                  • 182
                                  • india
                                  ya i jumped up and messed up , i was hurried and thought its easy as voltmeter ,oops , i checkd psu is working good , computer running ok , dono if anything happen and will show up later .
                                  about the ammeter in multimeter , i read if anything went wrong in it , i read to see a short btween volt and amp , it shoul give some resistance , if not its a continuity , then ammeter is gone ,i did get a continuity i dont have a fuse in multimeter , the fuse section in circuit is empty . or if there is any other fuse nearby i dont have idea, i see only resistances , r20 r22 somethng, may be ammeter resistance is gone bad , i dont see any burst mark .
                                  umm but multimeter reads the battery voltage wtih voltmeter , those 12 v again i tried , it reads ok , nothing happen, and it gives continuity when 2 red black touching together when continiuty mode.
                                  any other ways i shoudl check if multimeter is bad now because i did a major flaw wtih ampmetering. !
                                  • playit
                                    • Feb 2020
                                    • 182
                                    • india
                                    thank you for explaining , teaching me stuffs here eccerr0r ,CapLeaker ,stj ,petehall347
                                    • PantherDave
                                      by PantherDave
                                      Hi all!
                                      05-29-2024, 02:01 PM
                                    • GLISIT
                                      by GLISIT
                                      01-16-2025, 02:29 PM
                                      03-31-2024, 02:12 PM
                                    • DynaxSC
                                      GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                                      by DynaxSC
                                      I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                                      There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                                      The board is generally working now, all PCIe ports are working, Windows installs normally.
                                      However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                                      The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                                      03-10-2025, 12:27 PM
                                      09-06-2024, 05:59 AM
