Mainboard chipset makers - Gone
  • bigbeark
    • Jan 2010
    • 661
    A sister thread to the boardmaker one. Chipset makers no longer supplying motherboard
    chipsets?
    ALI
    NVIDIA
    SIS
    VIA
    I thought ASUS A7NX8 (NVIDIA) was the best-ever socket A board. What happened to them?
    The others made some good chipsets too. Where did they go?
    Your comments please.
  • mariushm
    • May 2011
    • 3799
    Re: Mainboard chipset makers - Gone
    ALI just didn't have the marketshare outside Asia where I think they were present in lots of very cheap computers. They used to sell their chipsets as AMD chipsets (AMD contracted them or something like that)
    Via still make their own chipsets, for their own processors. They stopped making chipsets for Intel because Intel stopped licensing them and AMD started to get into the chipset business themselves. I think the last socket they had license for was socket 370 i think.
    SIS was bought by someone.. it's a mess and I don't remember it now, it was probably S3 and then some parts were sold to VIA or something like that.
    NVIDIA ... same story, Intel didn't want them to make chipsets anymore and refused to give them licenses. The profits from AMD chipsets were probably too small or they decided not to make them when AMD decided to buy ATI ...
    Nowadays a lot of the functionality that was in northbridge is inside the processor, and there's even processors that don't need chipsets at all (everything's built in).. there's little profits in chipsets.
    Now that I think about it, the battery is also huge... but at least some manufacturers install it vertically.
    Honestly, what I'm still surprised with is the I/O chip common on most boards and all the passives they need around... it handles ps2 keyboard and mouse, fan sensors, some uart, some other crap, yet it takes a hunge amount of space on a motherboard... just look at top left here: http://www.ixbt.com/mainboard/gigaby...-ud7/board.jpg or below the vga connector on this itx board http://www.ixbt.com/mainboard/asus/i...big/mobo-2.jpg
    I guess they're too cheap and too generic for some manufacturers to invest in making them BGA or innovate and reduce the footprint.
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      most northbridges (now called ICH's at least for intel) handle the pci-express lanes for the audio, nic. and Handle USB and SATA. The Higher end PCI-express lanes (x16) are usually on CPU. They have passives cause they want audio options for the motherboard, instead of integrating audio or nics into the ICH itself.
      Onboard video is going out the wayside. Integrating video onto a chip with a passive heatsink tended to be problematic, not to mention required more power and generated more heat. Processors with APU's have a big heatsink that is simply the processor heatsink.
      Nvidia does technically make a chip for SLI motherboards, as its not integrated into the CPU like crossfire is.
      PS/2 is also slowly going into the wayside, why there are still some motherboards that still use it, I have no idea (with the exception of server boards)
      • mariushm
        • May 2011
        • 3799
        Lots of gamers still prefer ps2 because it does not suffer from latency associated with usb, which polls at 125 Hz by default (so keys are sent to pc every 8ms) unless the driver (or user manually) sets the polling rate to 1000 hz.
        PS2 also has a higher interrupt priority if I remember correctly.
        If it were up to me, everything in the back of a board these days should be usb, 2 network connectors (10gbps is starting to be cheap) and audio...
        Audio annoys me as well, there's a huge amount of space taken out by these old 3.5 audio jacks.
        • Compgeke
          • Feb 2014
          • 524
          PS/2 on gaming boards is because USB has a 6KRO limitation without firmware trickery on keyboard side (such as making one board show up as 2 or 3). PS/2 on the other hand can register every key at once providing your board controller is capacitive or you have diodes on every key.
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16956
            The PC market as a whole is about gone as well.... Not much demand anymore. Phones & tablets are taking over the consumer market....
            <--- Badcaps.net Founder
            Badcaps.net Services:
            Motherboard Repair Services
            http://folding.stanford.edu/
            Team : 49813
            Join in!!
            Team Stats
            • rhomanski
              nowhere man
              • 5157
              • U S of A
              Unless they make a 30 inch widescreen phone I'll stick with my PC. I've got the double cataract blues the Doc said last week when I told him Obama turned down the sun to fight global warming.
              sigpicThe Sky Is Falling
              • c_hegge
                • Sep 2009
                • 5219
                VIA made chipsets for intel CPUs all the way up to the early C2D era (s775). The MSI P4M900M2 is an example
                • pfrcom
                  Oldbie
                  • Jun 2006
                  • 1230
                  And the Gigabyte GA-VM900M - handy to have C2D and four IDE support
                  better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                  • rugger
                    • Feb 2005
                    • 55
                    Most of the 3rd party chipsets have been pretty crap and bug infested.
                    Particularly VIA.
                    Intel chipsets have been mostly rock solid since the P35 was released (although the LX and BX chips were also legendary for their rock stability)
                    • mariushm
                      • May 2011
                      • 3799
                      Yeah, you guys are right. I was thinking of cpu sockets.
                      It was a long time ago so I don't remember it quite well. VIA had some licensing agreements with intel giving them documentation for chipsets but at some point VIA bought some processor manufacturer that included cross licensing agreement to patents for x86 processors ... yeah, it was Centaur from IDT : http://www.eetimes.com/document.asp?doc_id=1188382
                      Those patents then gave VIA the ability/rights to make x86 processors but if I remember correctly cpu socket wise, they only had rights to use socket 370 for desktop computers.
                      That's why VIA then moved on to their own sockets (nanobga2 etc)
                      • Uranium-235
                        Comrade Glimmer
                        • Aug 2007
                        • 5042
                        • US
                        via still makes a whole bunch of other chip for other things. VLI (USB 3.0), Vectro (USB 2.0), Vinyl (Audio), Solomon (Wireless), Rhine (Ethernet), Fire (Firewire), Card Reader chips, SATA/IDE controllers (no codename), Embedded CPU's (for low power, small solutions)
                        they learned early to keep making stuff. thought most of it is used in cards, and not motherboard embedded solutions
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          Particularly VIA.
                          The only problem with post-KT133 chipsets, was that overclockers pissed and moaned, because of the PCI frequency being linked to the FSB frequency.
                          (KT133 was the buggiest)
                          Via's drivers were good.
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • lti
                            • May 2011
                            • 2551
                            VIA had the worst drivers I've ever seen, and I never saw a working VIA USB controller. However, I have only used one VIA chipset (KN133 - mobile KT133) and one USB 2.0 card with a VIA controller.
                            • RJARRRPCGP
                              • Jul 2004
                              • 6304
                              Looked all good with KT400. The only problem I saw with KT400 was being impossible to unlink the FSB frequency from the PCI frequency and the FSB frequency from the AGP frequency.
                              That means the PCI and AGP frequencies go higher when looking for max OC.
                              Looks like I had a wall at only around 180 Mhz for the FSB.
                              (3D Mark 2001 SE kept getting terminated, it's probably the AGP frequency)
                              Arc A770 16 GB
                                master hoarder
                                • May 2008
                                • 12175
                                • Bulgaria
                                So I can plug in my IBM model M keyboard and kick your ass in any game .
                                And most USB keyboards these days are either flimsy junk or overpriced (and sometimes both).
                                Those aren't going anywhere anytime soon. The 3.5 mm jacks are just too damn reliable and simple. Optical S/PDIF can be fragile. I do like coaxial S/PDIF, though. This is also why VGA D-SUB isn't dead yet. I remember reading an interesting article that compared the number of connect/disconnect cycles that various computer ports could take. The highest and most robust by far was the D-SUB type (i.e. VGA, parallel, serial, etc.)... but also the most expensive. USB was second in terms of reliability, but provided best "bang-for-buck" in terms of reliability vs. cost. DVI didn't fare too well. And HDMI and SATA/e-SATA were just plain terrible.
                                • Uranium-235
                                  Comrade Glimmer
                                  • Aug 2007
                                  • 5042
                                  • US
                                  yeah you buy cheap you get cheap.
                                  PS/2 has a limit to the number of keys you can hold down at once, and USB still has a limit but its higher from the experiments i've ran
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    • Bulgaria
                                    I don't buy keyboards, period. It's not that I don't want to spend the money on one. Just that old, quality keyboards are easy to find.
                                    Which is contradictory to posts #4 and 5 above. Interesting.
                                    • c_hegge
                                      • Sep 2009
                                      • 5219
                                      Nope. Post 5 is correct according to pretty much every technical document/page you read. The limit is between 3 and 6 for USB keyboards (4 on my GK-K6800), while PS/2 lacks a limit, and is theoretically capable of registering every key at once. However, the controller in the keyboard can sometimes limit you to fewer keys.
                                      • mariushm
                                        • May 2011
                                        • 3799
                                        With the standard USB class (human interface device), there is a limitation of 6 keys ... see the explanation at https://en.wikipedia.org/wiki/USB_hu...e_device_class
                                        If the manufacturer implements their own driver, the controller inside the keyboard could theoretically pack as many keys into a data frame (or consecutive data frames) which would then be decoded by the driver on the computer and translated to whatever is needed. Naturally, there may be some input lag depending on the usb polling rate and the driver's priority and other things.
                                        • Mirenia
                                          Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                                          by Mirenia
                                          I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                                          I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                                          In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                                          The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                                          03-30-2025, 06:47 AM
                                        • orcic
                                          MASTER TL240 and new mainboard LW36BKC01
                                          by orcic
                                          I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
                                          The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
                                          After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
                                          Now I have some doubts about how to connect the new mainboard to the old power supply.
                                          First of...
                                          05-12-2023, 08:10 AM
                                        • Devonavar
                                          Vizio M43-C1 - How closely do I need to match the mainboard number?
                                          by Devonavar
                                          I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
                                          I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
                                          Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
                                          So, I've ruled out the PSU for now.
                                          The reboot loop...
                                          08-14-2022, 08:46 PM
                                        • Malva
                                          Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
                                          by Malva
                                          I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
                                          Mainboard model: EAX65684604
                                          PCB marking: EBT62954607
                                          SPI chip: Winbond W25X20CLNIG Problem description:
                                          Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
                                          After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
                                          • I bought another
                                          06-25-2025, 02:07 PM
                                        • l0lhaxz1
                                          QN65QN90A - Mainboard MLCC failed - now bootloop
                                          by l0lhaxz1
                                          Hi
                                          I have a QN65QN90A which was purchased around launch I guess making it about 1.5-2 years old... had been working fine until a few days ago, simply went black and would no longer turn on (at all). No standby light and no typical PSU relay click etc. Absolutely dead.
                                          Pulled it apart without doing much research first, suspecting the power supply as it had a faint buzz (I guess due to the forthcoming found short), investigated PSU for some time and concluded there was no fault that I could spot with the board removed.
                                          Came to learn after a bit more research...
                                          02-06-2023, 08:59 AM
