Prescott CPU wrecks another motherboard
  • bigbeark
    • Jan 2010
    • 661
    I must be one of the few still using my old Netburst machines, but those Presc-hotts just fried another of my Intel boards. Are the Cedar Mill CPUs any kinder (cooler)? What would you recommend?
    • 31154
    Re: Prescott CPU wrecks another motherboard
    can your mobo run an E6600? those are cheap.
    • Compgeke
      • Feb 2014
      • 524
      ^ That's what I'd recommend. If it can't run Core 2 Duos I'd suggest finding a newer motherboard and a Core 2 Duo. Both can be had for less than $40 USD, looks like a bit more up in Canada.
      Here's about the cheapest I can find, http://www.ebay.ca/itm/331572430440
      Intel DG35EC with a Core 2 Duo E8400. It'll be a huge upgrade and you can probably reuse everything off the Pentium 4 sans ram if that's DDR rather than DDR2.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        Most HT/netbust processors are socket 478....not very likely you'll get an LGA775 C2D to work in that.... If the motherboard is toast, I most certainly wouldn't replace it....time for something a touch more modern.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • bigbeark
          • Jan 2010
          • 661
          Thanks for the link! Might just do that.
          • rievax_60
            • May 2012
            • 897
            • australia
            I went back to Northwood CPUs in my P4 machines. I find the Pentium HT 2.6GHz to have good performance and low power consumption.
            • c_hegge
              • Sep 2009
              • 5219
              Yah. I find that you can get used C2D PCs so cheap now that you can't even give a P4 machine away.
              If we end up being left with a P4 PC at work, it just goes straight to the metal recyclers, even if it is working fine (although I may scavenge and recap or re-use the PSU if it's decent enough)
              • brethin
                • Dec 2008
                • 1907
                Yes the Prescott's run hot and knowing that you can't really blame the cpu for killing the motherboard if you don't use proper cooling. To make any good recommendation you need to tell use what board you are using (aka socket and chipset at least).
                  master hoarder
                  • May 2008
                  • 12175
                  Nothing wrong with the Netburst Prescott CPUs. Intel just designs crappy CPU VRMs on their motherboards. If I had a penny for every Intel motherboard with discolored/overheated CPU VRM, I'd have some serious pocket change by now. Put one in a MSI motherboard, and I guarantee you'd never have a problem. Heck, even ECS does a better job at VRM design. I bet your board has a shorted FET on the CPU VRM.
                  The old Foxconn motherboards that Dell used are pretty solid too, sans the caps. My OptiPlex 170L is still kicking. In fact, I am about to retire my Pentium 3 PC (HP Pavilion 8756C) right now to put the 170L in its spot, which has a 2.8 GHz Prescott.
                  Anyways, if you have socket 775, check your motherboard's manual to see what CPUs it supports. You may be able to put a C2D in it. If not, then go with a C2D and new motherboard. Used C2D chips are super cheap on eBay now (at least the low and mid-end, not the high end ones). If the P4 CPU did everything fine for your before, the C2D should be more than enough for a while. Not to mention it will run cool and consume much less power.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    If you are going to spend $40 to $50, I suggest checking your local kijiji for systems with a dual core processor.
                    I looked up your area and set $50 as the maximum and found the following. Remember to negotiate on kijiji. If they ask $50, offer $35 or $40.
                    If the description is correct (ask seller), then this deal is the best bang for the buck. Pentium quad core 2gb ram for $30.
                    http://www.kijiji.ca/v-desktop-compu...top/1084006902
                    There are many others under the $50 mark that are dual core, 1 to 2GB DRAM and some with hard drives and Windows 7 COA. I won't list them all, but you can easily search on your own.
                    PS. All my systems at home that are dual core or quad core were found on local ads from people who gave them away for free as non working. Usually the culprit was a single bad capacitor in the power supply.
                    --- begin sig file ---
                    --- end sig file ---
                    • Compgeke
                      • Feb 2014
                      • 524
                      There's no way that's even a dual core. Anything dual-core or quad-core Thinkcentre releated would be Lenovo branded. I'm guessing the seller's taking Pentium 4 as Pentium, 4 cores.
                      Edit:
                      Looking on there there's a few things.
                      Some Acer with a 1.8 Pentium Dual-Core for $40. http://www.kijiji.ca/v-desktop-compu...ter/1075273253
                      HP DC7800 slim tower for $50, 2.33 Core 2 Duo. http://www.kijiji.ca/v-desktop-compu...key/1085026233
                      Custom tower with an E8400 for $65, http://www.kijiji.ca/v-desktop-compu...ghz/1062520573
                      Lenovo M57p for $70. No processor speed listed but it'd be a C2D. http://www.kijiji.ca/v-desktop-compu...57p/1075519005
                      • c_hegge
                        • Sep 2009
                        • 5219
                        The one thing I hate about those slim desktops is how everything is non-standard form factor.
                          • 31154
                          that's intentional, they probably learned it from Dell.
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5042
                            • US
                            Where I used to work I had two core2's available for sell for upgrades, an E6600 and E6550. If one was sold, I would get the money for it. My boss (a 48 year old ex manager of a plastics factor who did computer work for hobbying) put the 6550 in a customers Pentium D motherboard, after I told him not to, he said 'fuck off'. I knew the motherboard was not core compatible and ran much higher voltage, too much for the chip. He turned it on, with a black screen, and a burnt silicon smell coming from it. He burned the chip. I said, I told you, congratulations, you owe me for the processor. He said simply 'fuck off'. I told the owner, he said he would talk to him. I never got my money
                            • rhomanski
                              nowhere man
                              • 5157
                              • U S of A
                              Sorry, but it's obvious he was more valuable to the owner than you. I've been in that situation, it makes you mad. Not much you can do about it though.
                              sigpicThe Sky Is Falling
                              • RJARRRPCGP
                                • Jul 2004
                                • 6304
                                Wouldn't surprise me if he bent and shorted socket pins.....
                                Possibly also forgot to clip down all the heatsink push-pins.....
                                Sounds like a moron.
                                ASRock B550 PG Velocita
                                Ryzen 9 "Vermeer" 5900X
                                Arc A770 16 GB
                                eVGA Supernova G3 750W
                                Alienware AW3423DWF OLED
                                • Uranium-235
                                  Comrade Glimmer
                                  • Aug 2007
                                  • 5042
                                  • US
                                  no, he put the PD back in and it booted up fine. I saw him take the c2d out and I didn't see any bent pins. Pentium D is 1.2v minimum, Core 2 E6x is usually 0.8 - 1.5v, but the startup voltage of this motherboard might have been different
                                  We were building two identical computers for a customers business (I built one, he built one) when I was switched to contract (without notice or being notified so I could not claim unemployment). I finished and brought it to the shop when the customer was called to pick them up. I put mine in the original computer case, he did the same to his, the customer picked up HIS case and we heard a fairly loud bang inside. He forgot to screw the hard drive in. He had to take it back out and screw it in. So embarrassing for him.
                                  • RJARRRPCGP
                                    • Jul 2004
                                    • 6304
                                    65 nm Core 2 is 1.2 V for the norm. (1.5 V is the max allowed for overclocking)
                                    Arc A770 16 GB
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      I think a lot of Intel branded boards actually, if you check the integration guide, says not to install Prescotts in them. At least my DQ45CB does not list the S775 Prescott as a valid CPU, most likely due to the VRM not being correct for them.
                                      I unfortunately had to go get one of these boards because my Gigabyte EP43-UD3L stopped working properly, but the Gigabyte board does list the Prescotts as valid CPUs. I currently have a 3.4GHz Prescott in that Gigabyte board while it's being tested.
                                      The DQ45CB got the nice Core2Quad Q9550S to run, which probably is very easy on the VRMs. It was the cheapest on eBay at the time that supported all the old hardware the Gigabyte board had.
                                      I still have yet another 3.4GHz Prescott in a S775 MSI Neo3-F which doesn't support Core2 CPUs officially. Unless I get a really cheap Core2 to test, I don't think I want to try to see if it will work with them for fun. Would be nice to have a Core2 board that supports DDR1.
                                      • RJARRRPCGP
                                        • Jul 2004
                                        • 6304
                                        I think they got some of those!
                                        Arc A770 16 GB
                                        • glovecaps
                                          by glovecaps
                                          11-25-2024, 04:23 PM
                                        • Docus
                                          Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                                          by Docus
                                          Hi everyone 😀,
                                          I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                                          To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                                          Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                                          1. I already own the exact same model, but its plastic chassis is badly damaged.
                                          06-10-2025, 04:24 PM
                                        • Archimedes
                                          HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                                          by Archimedes
                                          Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                                          Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                                          Fans are spinning. Blindly could install windows11 and got the device manager...
                                          07-30-2024, 05:14 PM
                                        • dragon3x
                                          by dragon3x
                                          power on.
                                          Here are some examples :
                                          switching supply area).
                                          than 6.3 V.)
                                          03-21-2025, 02:46 PM
                                          ASUS P5GC-MX motherboard recap
                                          by momaka
                                          Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                          This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                          So here is what the motherboard looked like with its original caps:
                                          CPU VRM area up close…...
                                          01-27-2021, 11:59 PM
