Exploded transistor
  • jasonbay13
    • Jul 2014
    • 195
    • usa
    Exploded transistor
    i have a 500w psu that died on me a few years ago. still had it around so i decided to open it up and see if it could be fixed. 1 bulged cap, others way high on esr. and i've never seen this before; an exploded transistor.
    http://pontoppidan.info/lars/repairs...ed_2sc1318.jpg
    like the one in the picture, but top half. if i can find a replacement transistor and caps think it will start working again? and have you ever had an exploded transistor?
    • 31204
    Re: Exploded transistor
    foto's of the board?
    someone may have one to get the part number.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Usually transistors don't die/explode unless something else caused it to explode. Quite possibly the bulged caps caused its demise. My guess is that this transistor was part of the 5VSB circuitry, but yes having a picture of the board would be helpful to debug.
      Of the overstressed transistors I've had, most just burned a hole through the case but with the heat involved, cracking like that isn't out of the realm of possibility at all.
      • SteveNielsen
        Retired Tech
        • Jun 2012
        • 2327
        I've seen a couple of them go like that. I've seen an IC with a chunk blown out too. It's kind of rare.
        • jasonbay13
          • Jul 2014
          • 195
          • usa
          well, it gets stranger. i had 2 psus that did nothing at all when plugged in. one had a blown transistor and another (one of the bigger ones) which i couldnt get number from.
          the other has only 1 exploded transistor which i'm gonna replace, along with the bad caps and hope it works.
          its a c945, any cross-reference on this i might be able to salvage from my other boards?
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            General purpose NPN. Here's the basic data sheet for it.
            I'd check the other parts around/connected to it.
              • 31204
              2sc945
              • TechGeek
                Computer Geek
                • Jan 2015
                • 2254
                Did that thing get 400VDC to it? Something rated for 5.2V or 6.3V gets 400VDC to it, it's probably going to explode, like that transistor.
                Permanently Retired Systems:
                Kooky and Kool Systems
                sigpic
                • SteveNielsen
                  Retired Tech
                  • Jun 2012
                  • 2327
                  2sc945 is not the same spec as c945.
                    Generally when a transistor part is <letter> + <3 digits> it is a Japanese-style part number beginning with "2S".
                    • SteveNielsen
                      Retired Tech
                      • Jun 2012
                      • 2327
                      That may well be true, however in this case it isn't. Look at the data sheets for the two. They are not the same transistor. That doesn't mean a 2sc945 can't be substituted for a c945 in some circuits, but the 2sc has a significantly lower power dissipation limit and a greater current gain. 2sc is also rated for 50v, the c is 60v.
                        • 31204
                        it's also one of the most common japanese transistors on the planet.
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          According to a datasheet I found, the C945 has a breakdown of 50V. The 60V rating is the collector to base voltage rating.
                          Also, they have different Hfe classifications. (O, Y, GR, BL)
                          I did find that the C945 is rated for 400mW, and the 2SC945 is 250mW.
                          The ratings might differ from manufacturer to manufacturer. Either way, 400mW seems a little much for a heatsinkless TO-92 package!
                          Muh-soggy-knee
                            • 31204
                            you can do over 1w in that type of package.
                            take a look at ZTX753!!
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              It's rated for 200C vs the 2SC945's rating of 125C. Also, once it goes above 130C, the maximum allowable power dissipation decreases.
                              I'd never run parts over about 100C, unless it is a resistor. The hotter parts run, the less reliable they will be. (Though most people don't seem to care about that...)
                              (Also, reminds me of the minimum load resistors in PSUs, right up against cheap capacitors ... the extra heat helps kill the caps faster!!!)
                              That's as far as I will argue.
                              -Ben
                              Muh-soggy-knee
                                It looks like the Chinese specmanship.
                                This C945 by STANTON is rated at 250mW.
                                So if you look around it will come up with lots of numbers.
                                I would trust the Japanese spec of the (2S)C945.
                                  • 31204
                                  the blown one has a logo that looks like mitsubishi
                                    1W in a TO-92? Good luck on that. The standard thermal resistance for that package is about 150C/W. Sure, if your ambient is 0C you might be able to do it. But for all other reasonable applications, stay around 0.5W maximum.
                                    There are extended-height TO-92 packages that may also have additional copper inside of the package; this may increase the power dissipation rating. But a standard TO-92 cannot dissipate a watt. The ZTX75x specify a rating of 175C/W, so even that cannot dissipate a watt unless you are at 25C and can tolerate a 200C junction... that's extremely optimistic... If you heatsink it sure - but heatsinking a TO-92 is silly, you should use a TO-220 or a surface mount package (D2PAK, etc) if you want a heatsunk device.
                                    • canadaboy25
                                      What is normal?
                                      • May 2013
                                      • 509
                                      Take apart the base of one of those curly CFL light bulbs. Those usually have a bad cap or an exploded transistor in them.
                                      canadaboy25
                                      -Sometimes the light at the end of a tunnel is an on-coming train
                                      • ben7
                                        Capaholic
                                        • Jan 2011
                                        • 4059
                                        +1
                                        I've also seen popped/overheated film capacitors and resistors that have holes in them (burnt out).
                                        One had a transistor that had popped in half :P
                                        Also, I hate fusible resistors, I think they are a fire hazard when overloaded, but not severely overloaded. They are flameproof, but it doesn't stop nearby items from catching fire. Even the plastic cfl lamp base WILL burn if given a heat source. It just won't (well, shouldn't) continue burning on it's own.
                                        Muh-soggy-knee
