Exploded transistor
    • 30965
    Re: Exploded transistor
    the resistor is usually inside thick tubing.
    and i'v never seen a bad transistor, just bad caps and open heaters.
    maybe the 110v lamps stress the transistors harder.
    • jasonbay13
      • Jul 2014
      • 185
      • usa
      so status update. i replaced the blown transistor with a c1815, and the c5027 switching npn was infinite resistance through all combinations on my meter. replaced that with a 13007. plugged it in and it has voltage to the 5v. but it was making a clicking noise, kinda like the rad meter on fallout :P, whats it called a geiger counter? i unplugged it after that in fear of exposions. any reason its ticking?
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        It might be ticking because of a short circuit. Check to make sure none of the secondary side rectifiers have been damaged (shorted) from the catastrophic transistor failure.
        Muh-soggy-knee
          • 30965
          check any ceramic caps for shorts too.
          • jasonbay13
            • Jul 2014
            • 185
            • usa
            so anyway, i grounded ps_on and checked the 12v voltage, whilst it clicking away. measured 12.1vdc and 25vac. might this be a shorted rectifier as ben7 has suggested?
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              What about the other voltages? It might be instability because of a low load on one of the voltage outputs. That leads to my question, do you have a load on the PSU now?
              Edit: Well, not instability, but rather a very low duty cycle.
              Muh-soggy-knee
              • jasonbay13
                • Jul 2014
                • 185
                • usa
                #27
                no, i had taken the fan off to keep it out of the way, and it didnt work anyway. the fan might have made it click a little slower, but it sounds like it is coming from possibly one of the 2 transistors i replaced. though my meter is not trms, so i dont know if that 25vac is actually accurate or not.
                i could hook it up to my scope though.
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  The ticking might actually be coming from the transformer. That is typical when a switch mode power supply runs at a low duty cycle (because of a very light/non-existent load).
                  Try putting a load on it and see if the ticking goes away.
                  Otherwise, it's possible the ticking could be coming from a snubber capacitor that is breaking down.
                  Muh-soggy-knee
                    • 30965
                    why not just check the rectifiers, diodes and ceramic caps while it's off, instead of stressing the transistors in a way that may kill them!
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      Well yes, there is that approach as well :P
                      Muh-soggy-knee
