Please help identify this grease.
  • Sirgu
    • Nov 2013
    • 24
    • Estonia
    Hey.
    I hope this community has some people experienced on lubricants and greases of electronics industry.
    -Check this picture and tell if you can determine this yellowish grease in right side.
    It is widely used by quality brands in their products, where you meet plastic-against-plastic friction and/or bunch of plastic ratchets etc.
    If anyone got interested there`s a gallery below with further explanations. Overall it might help leading to solution if someone has a hunch.
    Thanks!
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Please help identify this grease.
    What about some of this ?
    http://www.electrolube.com/products/...ricants_other/
    No personal experience, but it's what i'd buy if i was in need of some plastic grease it's fully synthetic.
    Last edited by diif; 04-01-2015, 03:58 PM. Reason: maybe talking rubbish about the mineral oil..deleted
    • ComputerGuy1
      • Apr 2015
      • 8
      Not sure
        • 31065
        the mint-green stuff is the best.
        but i dont know what it's called or where you buy it.
        as it's for small plastic gears, maybe try the radio-controlled car/model comunity.
        • Sirgu
          • Nov 2013
          • 24
          • Estonia
          EDIT:
          Misspelled name of white grease on main picture. Yea, it's Smar TF as repeatedly written in later context.
          Thanks for very useful link!
          Looks like I am about to start further searches towards Electrolube SPG (the one you linked) and Electrolube CG60 (even more similar) as these seem to match the most.
          Haven`t heard of such thing before. Let me know if there`s smth more that would come to your mind about it. Seems complicated to google it.
            • 31065
            the mint green stuff used to be found in a lot of VCR gears.
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              I used Dupont Teflon Dry Film lubricant on a 12" fan who's bearing have worn off the oil impregnated surface. I ran the fan every day for 3 months before I gave it away. Just have to use a generous portion to start with. I suppose any Teflon silicon mix grease will work on gears. I have even used heat sink compound when I had no other lubricant.
                • 31065
                your missing the point, the stuff he's talking about is super slippy unlike silicone grease,
                but it wont be thrown off the gears at high speed or get thinner if it gets warm.
                • Sirgu
                  • Nov 2013
                  • 24
                  • Estonia
                  ...used to be found in a lot of VCR gears.
                  Tnx for addition. I'll look into that.
                  Meanwhile made this little reminder for myself:
                  Code:
                  [U]Electrolube SPG[/U] (Special Plastics Grease)
                  - the most [COLOR="SeaGreen"]promising info[/COLOR] from Datasheet:
                  * Tacky characteristic; high tenacity to stay in contact zone.
                  * Stays where placed even on vertical surfaces; ideal for plastic lubrication
                  Oil bleed / Separation (IP121): 5%
                  - the most [COLOR="Red"]dubious info[/COLOR] from Datasheet:
                  Colour: Light Brown
                  Thickener: Clay
                  [U]Electrolube CG60[/U] (Contact Grease 60)
                  * Excellent plastics compatibility; suitable with sensitive plastics (ABS/PC)...
                  * Enhances quality of switch; provides smooth operation and extends switch lifetime.
                  * Provides optimal mechanical resistance and reduces electrical background noise.
                  Colour: Cream
                  Thickener: Lithium Complex Soap
                  (none so far)
                  • keeney123
                    Lauren
                    • Sep 2014
                    • 2536
                    Teflon bonds to the gears when it drys it has a curing agent in it when exposed to air.
                    • keeney123
                      Lauren
                      • Sep 2014
                      • 2536
                      Or you can call or email the people at Dow Corning and tell them what you are looking for and I am sure they will help you find it. They are nice people who are very helpful and that is their business.
                        • 31065
                        it's actually listed in old vcr service manuals.
                        • keeney123
                          Lauren
                          • Sep 2014
                          • 2536
                          So you like the color green. How about this https://cdn.badcaps-static.com/pdfs/...c96bbda31b.pdf
                          Or if you like blue green how about this
                          http://www.belray.com/bel-ray-alumin...orse-lubricant
                          Or you can use what they use to use moly grease.
                          • keeney123
                            Lauren
                            • Sep 2014
                            • 2536
                            Or this one http://www.aaaindustrialsupply.com/s...ubricants.aspx
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              Maybe it is similar stuff, but it has been exposed to the air longer, and so it has gelled up a little, and changed color.
                              Muh-soggy-knee
                                • 31065
                                no, the light green colour was a way to identify if the right grease had been used.
                                i really wish i could remember what make it was - then i could just download a service manual to id the grease.
                                maybe it was aiwa or panasonic - i saw a lot of those.
                                it's the same stuff you often see on cd/dvd players lubing the rails for the laser assembly.
                                • ron350
                                  • Feb 2014
                                  • 296
                                  STJ it would be nice to have some of that green VCR grease. I never saw that green grease cake up or separate.
                                  • keeney123
                                    Lauren
                                    • Sep 2014
                                    • 2536
                                    How about this one it is light green. http://www.dowcorning.com/applicatio...0739&type=PROD
                                    • ron350
                                      • Feb 2014
                                      • 296
                                      Thanks Keeney123 Dow Molykote G-3407 is new to me and seams to be another unobtainable product from Dow.
                                      So far the closest grease to the VCR grease (in the US) is Dow Molykote EM-30L.
                                      That Special Plastic Grease sounds good but I can’t find any in the US.
                                        http://machinedesign.com/mechanical-...gears-and-more
                                        PAO based: EM-30L, PG-30L
                                        http://www.amazon.com/Corning-Molyko.../dp/B00B51C76I
                                        http://www.ebay.com/itm/DOW-MOLYKOTE...item3f0be845ad
                                        • thesame
                                          DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                                          by thesame
                                          Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                                          The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                                          02-27-2024, 04:31 AM
                                        • silver60618
                                          Lenovo Legion 7 - Help Identify IC
                                          by silver60618
                                          Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
                                          I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
                                          Any help would be appreciated...
                                          07-02-2025, 12:16 PM
                                        • chth96
                                          How can I identify varistor which have been blew up?
                                          by chth96
                                          I mistakely pluged 100v japanese retro game console to 220v outlet.
                                          So It seems that glass fuse and varistor have been blew up.
                                          I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                                          Is there any way to identify varistor type in my sega saturn PSU?
                                          Any reply would be appreciated.
                                          EDIT:
                                          It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                                          11-26-2023, 08:52 AM
                                        • freakorio
                                          Need Help To Identify Component on Ymain LJ41-05120A
                                          by freakorio
                                          Hi guys , i hope this is the right place , i got Plasma Samsung PS-50Q91H and i need to repair Ymain LJ41-05120A , but those component are burn and i can not identify to replace those part , and the part are blue capacitor and the location are C5105 and C5106 and here i attach the part that need to identify , and one more thing , i also need to replace Zener Diode on location ZD5502 and the part are BZV55C because mine is short but i don't know the voltage because those parts are release with many type of voltage. Looking forward for your kindly reply
                                          05-21-2024, 02:32 AM
                                        • baiceanu_stefan
                                          nm-f251 Schematic, boardview or help identify componente
                                          by baiceanu_stefan
                                          Hello, I have a legion pro 5 16arx8 serial number pf4bf4aw mb code nm-f251 rev1.0 which was dissasembled by the client for cleaning. Now it does start but for 20 secs after that fans run at maximum and then shut down. Found PU8302 burned but cannot identify it the part. It is written eHFAA on it but didn't found any info, no boardview, nothing. Can anyone help identify the part so I can order it from somwhere? Ataching some pictures of the motherboard, serial number and part. Than\k you...
                                          04-24-2024, 12:49 AM
