How do I unplug this??
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Hi, everybody. I am taking apart an HP vs17e monitor. I need to get to the power board. I am stuck with this:
    https://www.badcaps.net/forum/attach...1&d=1420549731
    How do I unplug this? Thanks!!
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
  • selldoor
    Slow Learner
    • 7870
    Re: How do I unplug this??
    Cant tell from that picture where it is? can you do other shots from further away?
    Is it same as HP19 -see herehttps://www.badcaps.net/forum/showthread.php?p=256240#post256240 perhaps pics there will help or you can point out which socket you are at if the boards are the same
    • Koda
      • Aug 2011
      • 317
      • Macedonia
      That seems to be the flex cable from the display, just pull upwards with a bit of force because those things are usually glued on the underside, after the flex is free you can unplug the cable from the T-CON board.
      Pics would help.
      Guns don't solve problems. I'll take 12
      • TechGeek
        Computer Geek
        • Jan 2015
        • 2254
        Pics would help.
        I have a picture in my post. Just click on the thumbnail or the image link.
        sigpic
        • TechGeek
          Computer Geek
          • Jan 2015
          • 2254
          Also, after I unplug it, how do I plug it back in without it being a pain in the rear?
          sigpic
            Need to see this top view.
            http://s807.photobucket.com/user/bud...tml?sort=3&o=5
            http://s807.photobucket.com/user/bud...?sort=3&page=1
            • TechGeek
              Computer Geek
              • Jan 2015
              • 2254
              I figured it out on my own. There is this silver panel with a screw that is SO HARD to get out. I FINALLY got that screw out and unplugged the cable. Thanks for the help anyways!
              sigpic
              • survivalbloke
                HP ENVY 360 - no power, taking no current
                by survivalbloke
                HP ENVY x360
                15-dr1072ms
                SN 8CG0215FQ6
                Prod 13Q17UA#ABA
                Board# 448.0GB12.0011
                This device came in as no power. It is taking 0a current. I noticed a little liquid damage to the LCD connector and cleaned that off. I have 19v at the input mosfets, and on the opposite side of the board, there are several (diodes?) which all have 19v. There is a cap there which has 19v on one side, but 6.5v on the other - how?
                The only other live power rail I have found on the board, is 16V on one of the coils. There doesn't seem to be a 5V or 3.3V present. A couple...
                12-11-2024, 08:26 AM
              • slimmy182
                MacBook Air M1 A2337 820-02016 not booting, taking 5V 0.42A and 2.173W
                by slimmy182
                Hello, a friend give me this M1 Mac Air, he said that it simply stop working. Apple preventive is replacing motherboard.
                Model is MacBook Air M1 A2337, logic 820-02016, not booting, and taking 5V 0.42A and consuming 2.173W.
                Once disassembled is very clean, no water damage at all. Visual ispection reveal no visible problem. Flir camera point to two hot point:
                C81DC PP3V8_AON_VDDMAIN
                And
                Q5800
                What should I test as next step?
                Thank you very much!
                02-01-2024, 01:08 PM
              • gurj1979
                Xbox one 1540 not taking disc
                by gurj1979
                My Xbox one has stopped taking discs. Sometimes it will trip the power supply and no orange light neither.
                If I'm lucky it will randomly take it after about 10 power reboots.
                I got a new drive, swapped over the board but same thing.
                So I swapped over the motor driver IC, but still same problem.
                Is this turning into a motherboard problem rather than the drive or PCB itself ?
                Help please.
                08-11-2023, 03:31 PM
              • Maksioja
                MSI Katana GF66 - no power on, taking 20v, 0,055A.
                by Maksioja
                Hi guys,
                It's my first post, because till now I found everything on this forum, but I'm little bit stuck now, so I'm asking you for help. It's my first gaming laptop, so I need some advice .
                I bought defect MSI GF66 Katana with GTX3060 GPU.
                First when I open it - you can easily notice - somebody open it before, but I didn't found any tech working for it, just maybe somebody open it for cleaning.
                What I did so far:
                Replaced parts:
                • ALC233 - was exploded
                • APL5934C - was exploded
                • 2x FDPC5018SG - went shorted when I took out UP1666Q.
                • UP9512Q
                09-30-2024, 08:26 AM
              • caspian
                Asus K555U taking extra current
                by caspian
                Dear Members,
                This laptop used to work with a 19v 3.4A adapter.
                After 4 years of using it, now, the adapter's output voltage drops to 17v when windows loads up. Then the laptop suddenly turns off.
                Today, I have connected a 19.8v 4.5A adapter to this laptop. Then the adapter's output voltage dropped to 19.4v but the laptop worked fine.
                In addition, I noticed that the cpu power coils get warm to about 50'C but the mosfets are cool.
                All the voltage rails on the mainboard are fine without any reduction except for the 19v rail. All the ICs and coils on the mainboard are...
                05-31-2024, 01:36 AM
