disabling battery wear popup on windows 7
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Quick question :
    My aunt has a Dell latitude d630 with a worn battery that is always rub on the charger. I'd like to disable the popup in win7 that says to consider replacing the battery. I have a battery in better shape, but I and her don't want to burn a low wear oem 9 cell unit on a system that will only kill such a perfectly good battery.
    I saw no suggestions online as I already know the battery is legitimately worn. Any ideas?
    Ps- worst case she'll try to ignore the popups...
    sigpic
    (Insert witty quote here)
  • brethin
    • Dec 2008
    • 1907
    Re: disabling battery wear popup on windows 7
    Your choices are:
    Replace the battery with a good battery.
    Disable the Power Icon or set device manager to disable "microsoft acpi-compliant control method battery."
    Remove the battery.
    I would just replace the battery with a good one if it were me.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      When you click on the battery icon in the taskbar there is a checkbox that says "Warn me if my battery needs replacement". All you have to do is untick it.
      A working TV? How boring!
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Originally posted by brethin
        Your choices are:
        Remove the battery.
        Given her usage patterns, any battery put in is gonna get roasted by always being charged. She literally never moves it off the charger. Her mobility isn't good either, as she's almost 78 years old and was partially disabled in a car wreck in her teens. All she does is sit in her easy chair and grab it (and a cooler pad) and use it for email, facebook, etc. Unless she goes on a trip where grounded AC power isn't available (not likely), It would be dumb to replace the battery (it's a worn 6 cell, my only spare in usable shape is the spare 9 cell to my other D630 I still own). If the run time goes to shit (relative to her usage), then the battery will be replaced... but for now, I don't see wasting money or really nice batteries here.
        Doh. Last night (before you posted) I looked, it was Dell Quikset whining, not the OS... but I will note that for the next time I see her, which won't be all that long.
        sigpic
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          Uninstall Quickset. It's useless anyway.
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16959
            What does having it on the charger have to do with it?! they stop charging when they're full, and after that they simply maintain teh battery. My netbook comes off the charger once or twice a year, as its used only for car diagnostics. Bastard still holds 7+ hours of charge.
            <--- Badcaps.net Founder
            Badcaps.net Services:
            Motherboard Repair Services
            http://folding.stanford.edu/
            Team : 49813
            Join in!!
            Team Stats
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Li-ion batteries wear very fast when kept fully charged. They store the best at 30% actually... Hence why you either use it or lose it. Idk about your netbook, but I know of several examples where this happened.
              sigpic
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16959
                I think thats a load of hooey.....a couple of my precisions get used maybe once every couple months....they have normal batt life, and the batts are used when I got them....but whatever you say...
                A good example of that is your LiON batt on your LSI raid controller. It's always fully charged, and never allowed to drop to 30% unless the system sits off for months on end. They last about 5 years, which is about the lifespan of them.
                Team : 49813
                Join in!!
                Team Stats
                  • 31304
                  why not just run without the battery if you insist on installing crap that creates popups?
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    The battery is structural (one of 4 feet are mounted it to it).
                    The software is mainly to make the ALS work right... and to provide volume/brightness info when the buttons on pressed (since otherwise in windows, you don't get that by default). Yeah, the ALS sorta works without it (such as under linux) but I've found it trippy and unusable w/o quickset. Sure, if its plugged in all the time, saving power is pointless but if I can make something work for free, why not?
                    Besides, it's not the full screen popups like you have in adware... it's more like a taskbar notification... at least it had a "don't remind me again" option.
                    Topcat- 5 years, ok, fine, still, for the controller, what counts as "OK' to the controller may or may not be comparable. Not to mention the device was designed to always be powered, so I'd image there is some charge controlling magic at play (hence why BBU boards cost so much. Laptops on the other hand (maybe not the precision) were designed to not be on the charger all the time.
                    I do know in the early/mid 2000's when my dad had to provide his own work laptop (since the state of IN gave him a pentium 1 win95 dinosaur to horse around for the longest time), he cooked two batteries that way. One laptop was a Compaq Presario 1200 (AMD K6-2) and a IBM Thinkpad T22 (PIII)... yeah, they were both pretty old (they were overstock.com refurbs that killed thier batts in 2 years after purchase) and technology may be better... but Li-ion batteries still wear the same way- the cells oxide up... IIRC higher charge levels accelerate this process.
                    The only way to slow it in a charged system is what Tesla motors does (and what GM should have done with the Volt)... use an active controller to even out charging/discharging... IIRC laptop batteries still don't do that though (cost reasons?).
                    Here's some links:
                    http://batteryuniversity.com/learn/a...ased_batteries
                    http://www.howtogeek.com/124715/shou...-all-the-time/
                    http://www.dell.com/content/topics/g...en&cs=04#faq38 (ironically they also say it's ok to always leave it plugged in as "it won't overcharge the battery"... dell trying to sell batteries?)
                    If it works for you, fine, but I don't see the point in ruining a perfectly good extended battery (that also fits a laptop I still own) that will never get used. I might as well shoot it with a pistol at that rate... If she's use it, fine... but I don't see wasting expensive parts here.
                    sigpic
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      yes the aging is worse at full charge but the biggie is heat along with full charge.
                      newer batteries deal with this better now.
                      for a seldom used battery run down to about 40% and store in a cool place.just have to plan ahead if you need its full runtime so you can charge it.
                      • brethin
                        • Dec 2008
                        • 1907
                        The battery is not used or worn if you never use it and it remains on AC power so the only thing that will happen to a 0% wear new battery if never used is it will degrade like all batteries do.
                        Your cherished 9 cell battery will not be harmed in her laptop in any way so stop acting like its the last 9 cell battery there is.
                        Your lack of knowledge of Li-ion is making you sound stupid to those that know better so save yourself and just either put a damn battery in her laptop, disable it in the device manager (so it provides that little foot pad you need so bad the laptop to sit on) or remove the battery and run it without one.
                        If you just want the battery for its little foot pad for the laptop to sit on then just gut the battery and use the empty case.
                        • Bowline
                          by Bowline
                          06-11-2025, 10:13 AM
                        • mkdj
                          by mkdj
                          Mark and model: ASUS X571
                          Tests already made:
                          - I have removed...
                          07-14-2025, 09:16 AM
                        • techfreak9356
                          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                          by techfreak9356
                          09-14-2023, 11:10 PM
                          NVDC charger configuration...
                          11-05-2024, 03:28 PM
                        • huzo
                          HP ELITE X2 1013 G3 weird battery issue
                          by huzo
                          Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
                          01-31-2025, 12:09 AM
