I have an older Dell Optiplex GX 150 that I referbed off the junk pile. Its a 1Ghz PIII, 512 megs RAM, 40 Gig HD, with two DVD burners installed. Kc8adu recapped the PSU for it. As I have no A/C in my computer room right now it got very warm in there yesterday. I was doing a little DVD copying for my private collection when this Junker started acting up. On the fifth DVD copy it started giving me bogus errors on the burn. I'm thinking its heat related because the metal PC case as well as the Burner trays were very very warm to the touch. There is a place in the case for a large fan. I guess I need one there. Now should I run the fan off a tap on the mobo or directly from the PSU? Will it make any difference in the stabillity of the PC running the new fan off the Mobo?
Old Dell gets smoking hot
Mark Twain
John Paul Jones
Rod SerlingTags: None -
Re: Old Dell gets smoking hot
if there is a place on the mobo for a case fan use it.
the temp control if any will speed it up when needed.
i have a pioneer dvd recorder in this box that runs so hot while recording the disc comes out quite hot.
i can see if you have inadequate airflow how this could overhear the system. -
Almost all Dell systems skimp on a dedicated cpu fan and use a case fan with shroud to pass air through a passive cpu heatsink.
If you changed this config, then do replace the case fan.
For the sake of quietness, Dell systems sacrifice air flow through the psu and case.
Your 1GHz P-3 should hit high 30s to 40C.“We the willing, led by the unknowing, are doing the impossible for the ungrateful.
We have done so much, with so little, for so long, we are now qualified to do anything, with nothing.”Comment
Ok I got the heat problem under control here. I cracked the case and turned it on. The PSU fan was dirty and moving about zero air. The cheap cpu fan was totally locked up! I replaced it with another even cheaper one but it works now at least. As soon as I get up to the shop I will grab a real heat sink and fan for the cpu. I will also get a large fan for the case. The case fan will be run directly off a psu plug, and I'll run the cpu fan off the mobo again. Then again I may change my mind and run it direct from the psu too."It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
John Paul Jones
Rod SerlingComment
Cool! (pun intended).
The only advantage to powering the fans via motherboard jumpers is possibly allow the BIOS and/or motherboard monitoring app to keep a watch of their status. But being a Dell system, you may not have any of these. Off hand, a lot of Dell PCs use Intel brand OEM motherboards, and Intel may have a utility available for download.
Otherwise, Speedfan can be tried, I think there's an option for Dell systems.“We the willing, led by the unknowing, are doing the impossible for the ungrateful.
Not sure if it would apply for this system, but last time I unplugged the case fan on an Optiplex GXa, it wouldn't allow the system to boot.Comment
Originally posted by MaxxarcadeNot sure if it would apply for this system, but last time I unplugged the case fan on an Optiplex GXa, it wouldn't allow the system to boot.Ludicrous gibs!
Saw a few of those systems at the local University auction, $60 a piece... was tempted to grab a couple for the kids.Ya'll think us folk from the country's real funny-like, dontcha?
The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.Comment
I found the cause Mates! At least I think I did. Its the good old Dell PSU thats running smoking hot and heating up the whole unit. I pulled it and put another one in it. I'll let her run a few hours and see if it over heats again. I also added a fan to the case. Here is where I need some feedback from the Savvy PC people reading this. With this PC the CPU fan draws in air from the back of the case. The PSU fan blows out of the rear of the case. The fan I added blows out of the rear too. Should I switch things around somewhat? I was thinking of making the fan I added blow cool air into the case. It moves a great deal of air. I was going to turn the CPU fan around so it picks up this cool air and blows it over the CPU and out the rear of the case, and just leave the CPU fan blowing out the rear as it does now. What do you think? Darn its hot here today. Who wants to meet me at The Gateway Tavern for an Ice Cold Bud?"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
John Paul Jones
Rod SerlingComment
Good Deal!Its hot as the hinges of hell in this room and the PC been on for over an hour. The case is as cool as when I turned it on. None of the exhausted air is the least bit warm. I'm still thinking about changing the fans around as listed above in the hopes of making it all the more cooler.
As for the Dell PSU, I think I'll see if the guts from the cool running one will fit in the Dell PSU Sheet metal case because it fits this PC better. I will at least sodder the long leeds from the Dell PSU into this other PSU.
Mark Twain
John Paul Jones
Rod SerlingComment
The more interesting thing is why the heck is the original psu running so damn hot.
Either it's defective, or overworked. Are the power ratings the same?
If your fan can pump in a lot of cool air flow, it'll work better for your personal lifestyle.
If only you can monitor the interior case temp and cpu temp. then you'll know which orientation is more desirable.“We the willing, led by the unknowing, are doing the impossible for the ungrateful.
Good point WNG.
This PSU was DOA when I bought this thing. Kc8adu recapped it, and got it going. Maybe some other part is failing in it now. Maybe its a bad design and runs hot. I just don't know. Its only a 200 watt unit. The replacement is an old 350 watt unit. Its been on all day and its still cool. I have two DVD burners, and a floopy drive installed. There is also a 40 gig ATA 133 hard drive that I bought new for this thing. I forget what brand it is. The only cards installed are a PCtel soft modem, and my ATI All In Wonder video card."It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
John Paul Jones
Rod SerlingComment
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
Hi, everyone. First post of an actual repair. I'm a technician but a complete newbie with laptops.
So I got this Dell Inspiron to play with.
No charger, so I connected to my bench PSU.
The laptop also didn't include: hard disk (I added one of my own for testing, see below) and wireless PCB (but I doubt this could have anything to do with this particular failure).
------What it did (and didn't do)------
1) I turned it on and it powered on. Powered down in 2 seconds by itself.
2) Removed RAM, changed slot. Same... -
by mrsithHi guys,
I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,... -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
Channel: BIOS Requests ONLY!
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
- Loading...
