Weird USB issues
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Weird USB issues
    My main rig is haing the following USB issues:
    - The internal card reader will stall/freeze after a while
    - The USB hubs on the monitors I installed cause a no-POST when connected to the Onboard USB
    The USB is at least partially fed off the 5Vsb (as the card reader LED is always on, even when powered off). When running, the measured VCC at the port is 4.84V
    My system is based off a Tyan K8WE... with a 600W seasonic PSU (kinda on the edge of it's output specs, I'm drawing maybe 550W or so)... I haven't recapped it.. while it's full of Su'scons I haven't had any other issues...
    Any other suggestions on where to look for the problem?
    sigpic
    (Insert witty quote here)
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Weird USB issues
    Bump. Is 4.8V an acceptable USB voltage?
    sigpic
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      most USB devices will run on as low as 3v. with the exception of those USB to 2.5 HDD converters that like to kill drives
      Follow the white rabbit.
      • mariushm
        • May 2011
        • 3799
        Yes, it's within the limits according to standards. At the connector... the cable itself may have some voltage drop as well.
          master hoarder
          • May 2008
          • 12175
          I doubt that. Get yourself a kill-a-watt meter and check wall power usage. I bet even that is not 550W at peak usage.
          Some motherboards power the USB ports from the 5VSB rail. Check 5VSB caps in PSU or replace if in doubt.
          4.85V on USB seems a little lower than what I am used to seeing, but it should still be okay.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            I know you'll disagree, but running a PSU load calculator, it was just around 550W. Given the PSU's heat output under load, I'd believe it.
            The PSU could use a recap... full of su'scons, probably dried out. I thought 4.85 seemed low too (hence why I posted it).
            sigpic
            • mariushm
              • May 2011
              • 3799
              screw psu calculators, i'll have to agree with momaka.
              Get a kill-a-watt, they're cheap. I'll bet it hovers around 250-300 watts. (or get a multimeter/clampmeter and measure current but be careful )
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                I'm sure it draws more than that... there was a 400W psu requirement for the board... Add twin GPU's...
                sigpic
                • mariushm
                  • May 2011
                  • 3799
                  The requirement for 400w is to make sure the power supply can provide enough amps on 12v. Saving stupid people from using those 20$ crap power supplies on newegg.
                  mb eats 30-50 watts, each cpu eats about 60-90w, ram about 3 watts each module, hdd about 6-10w each...
                  As for twin gpu's... the gpu will pull a maximum 60w from slot , 75w from each pci express 6pin connector and rarely the two gpus will both run at maximum and when you run games you won't have both cpus at 100% etc etc
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Whatever. Given that I've gotten one of the two USB hubs to work today, my guess is an LCD issue... I've never torn them down... me thinks at least one has cap issues that are causing that LCD's hub to act goofy. FWIW my LCD's are Dell Ultrasharp 1801FP's.
                    sigpic
                      master hoarder
                      • May 2008
                      • 12175
                      The hubs in the LCD are likely powered by the LCD monitor's PSU and not by the PC. So it probably wouldn't hurt to crack open those 1801FP's either.
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        That's what I meant...
                        sigpic
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          opened it up, broke a cable. damn my luck.
                          The PSU board has a bunch of capxons, not bulged. Will replace anyway.
                          Yup. Dead. Ripped a flat flex. I can't get a replacement, so I'll have to blow $25 on another 1801FP the next time I'm up north... in the mean time I have a similar 1703fps that is mixmatched but I'd take it over 1 monitor (or two fixed VGA LCD's).
                          In the mean time, at least I have the caps to order...
                          sigpic
                            master hoarder
                            • May 2008
                            • 12175
                            Is it between the video/logic board and t-con or t-con and panel? If the former, you could just solder extremely thin cables from the video/logic board to the t-con... if you have a steady hand and the nerves, that is. (I don't have the latter).
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              Nope. A long thin one between the button/LED board and the logic board... yeah, I could solder it... but I have my reasons for not (not a lot of clearance, etc.)
                              If a new LCD were more pricey... but at $25 a pop, I'll grab yet another one, and keep this one for parts...
                              sigpic
                                master hoarder
                                • May 2008
                                • 12175
                                Aw, cmon, then. That's an easy one! Probably no more than 10 wires total there, if even that many. With some 28 to 30 AWG wire, you can have it running in as little as 30 minutes.
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  maybe use old 80 pin wire if i have a long enough bit? the only con is is I no longer have a bezel connector... i'll have to clip and unclip the board.
                                  sigpic
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    having gone in, it looks a bit too fine of a pitch to solder by hand in my basement... if I HAD to I would, but it looks tight. much finer than 80pin wire, that is (like twice as tightly cramped)
                                    I may try it for laughs later but for now I'll leave it.
                                    sigpic
                                    • Pentium4
                                      CapXon Be Gone
                                      • Sep 2011
                                      • 3741
                                      I have the same exact PSU as you, and I recapped it. Let me know if you want a list of the caps used and I can send the specs to you. It's well designed but, the fan spins insanely slow which doesn't help those Su'scons at all!
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        Iirc I have the list but since you actually did it, send it.
                                        sigpic
                                        • dfear
                                          Lenovo Thinkpad X1 Yoga Gen 1 - weird issues
                                          by dfear
                                          I am trying to fix a "LENOVO THINKPAD X1 YOGA TYPE 20FQ / 20FR" laptop.
                                          It's a 1st gen X1 Yoga and it has a couple of strange issues. I think they are related to either:
                                          1) damaged ME region in the firmware/BIOS.
                                          2) The version of the ME firmware is too old.
                                          The two issues I am having are:
                                          1) The laptop will shutdown, but fails to power off the laptop. If the laptop is forced powered off, then it can ONLY turned on again if:
                                          a) The charger is disconnected.
                                          b) The reset button is pressed.
                                          c) The power button...
                                          02-21-2022, 08:19 AM
                                        • bigbadbios
                                          MSI Raider GE66 Short/ no power - weird issues please help
                                          by bigbadbios
                                          Hi, I have a MSI Raider GE66 i7-10750h, Rtx2070 Super
                                          It will not turn on.
                                          Found IC TI 1225C getting hot on back of MB.
                                          Replaced said IC. Plugged laptop in and heard a pop/smell burned smell. Inspected and I see NOTHING physically burned or damaged including the IC. Now on the power supply i have about .5 volts compared to 20v before.
                                          I am lost at what to do now, your input is greatly appreciated. I spent a fair bit on this one in hopes it's fixable.
                                          Thanks for your time.
                                          07-01-2023, 06:50 AM
                                        • gretti
                                          MSI Z370-A Pro, works but does not power off or reboot and USB issues
                                          by gretti
                                          I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
                                          The MSI BIOS included the ME firmware for the board. The size...
                                          10-16-2025, 02:14 AM
                                        • Kyleadonis
                                          Sony KLV-37S400A Weird Issues
                                          by Kyleadonis
                                          I have a Sony TV that after a few minutes it makes a pop sound through the speakers and then completely switches off and then powers back on by itself, the green LED goes out and then back on again. Since I replaced all the caps on the inverter and power supply its shutdown intervals are longer. I haven't replaced the main filter cap but now I'm just lost on what to do? I've tried resetting but no luck. Anyone know what else to do?...
                                          11-13-2021, 09:24 AM
                                        • SoulFreeze
                                          Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
                                          by SoulFreeze
                                          Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
                                          After repairing the above issue, I realized the following remaining problem,
                                          Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
                                          The computer recognizes headphones are connected and displays a popup in windows
                                          Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
                                          06-21-2025, 09:53 AM
