MSI Raider GE66 Short/ no power - weird issues please help
  • bigbadbios
    • May 2021
    • 8
    Hi, I have a MSI Raider GE66 i7-10750h, Rtx2070 Super
    It will not turn on.
    Found IC TI 1225C getting hot on back of MB.
    Replaced said IC. Plugged laptop in and heard a pop/smell burned smell. Inspected and I see NOTHING physically burned or damaged including the IC. Now on the power supply i have about .5 volts compared to 20v before.
    I am lost at what to do now, your input is greatly appreciated. I spent a fair bit on this one in hopes it's fixable.
    Thanks for your time.
  • mon2
    • 14660
    Re: MSI Raider GE66 Short/ no power - weird issues please help
    Link or post the schematic in the schematic forum, if available.
    Start with the power adapter - disconnect it from the logic board. Measure the voltage to ground of this power adapter. Do you have ~19 volts on this adapter?
    If yes, continue.
    Often, as per the detailed article above by @Piernov, the power adapter connector on the logic board will follow with 2*DCin mosfets. These mosfets are controlled by a local charger IC.
    Locate these parts on your logic board and share the topside markings of the mosfets and the charger IC.
    Very likely, the fault is in this area and often, with the 2nd DCin mosfet.
    Once you find the mosfets = 8 pin package (each). Measure the voltage to ground of each mosfet pin.
    Pins 1-2-3 will be bonded together = SOURCE pin.
    Pin 4 is the GATE pin and used to enable / disable this mosfet.
    Pins 5-6-7-8 will be bonded together = GATE pin.
    Mosfet is like a solid-state relay. If the mosfet is N-channel, then the GATE pin must be HIGHER than the voltage being passed between the source / drain pins.
    For N-channel, often the gate voltage should be ~25 volts since the adapter voltage is ~19 volts. The charger IC will likely be the BQ series from Texas Instruments and it uses the REGN pin voltage of ~6 volts to BOOST the ACDRV pin to drive the 2*DCin mosfets.
    That is, gate voltage = REGN voltage + adapter voltage = 6 volts + 19 volts = 25 volts.
    Start with the above review to check on the voltage of each DCin mosfet.
    • bigbadbios
      • May 2021
      • 8
      If yes, continue.
      So I found a mosfet by the battery connector that is shorted I believe, when removed it restores 20v to the board. I am assuming that one of the two big power supplies next to it may be to blame? A little stuck right now.
      • Stevedb
        Stevedb
        • Feb 2018
        • 624
        • Belgium
        I would suggest make hd picture front and back with all voltages on the coils also resistance to ground with no power to the board.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          1225C is your 3V/5V pwm IC. Since it was getting hot, its worth to check resistance to GND on pin3/13 for 3Vldo and 5V ldo respectively. Resistance should be measured without any power source connected.
            MSI Gaming GE66 Raider 10UG-452DC Raider Notebook GE Specification for Upgrade or Repair
            This specification for the MSI Gaming GE66 Raider 10UG-452DC Raider Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GE66 Raider 10UG-452DC Raider boardview and GE66 Raider 10UG-452DC Raider schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
            09-07-2024, 03:10 AM
            MSI Gaming GE66 12UHS-470NL Raider Notebook GE Specification for Upgrade or Repair
            This specification for the MSI Gaming GE66 12UHS-470NL Raider Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GE66 12UHS-470NL Raider boardview and GE66 12UHS-470NL Raider schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-07-2024, 05:50 AM
            MSI Gaming GE66 12UH-472NL Raider Notebook GE Specification for Upgrade or Repair
            This specification for the MSI Gaming GE66 12UH-472NL Raider Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GE66 12UH-472NL Raider boardview and GE66 12UH-472NL Raider schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            MSI Gaming GE66 12UGS-474NL Raider Notebook GE Specification for Upgrade or Repair
            This specification for the MSI Gaming GE66 12UGS-474NL Raider Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GE66 12UGS-474NL Raider boardview and GE66 12UGS-474NL Raider schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            MSI GE Raider GE66 - 12U Notebook GE66 Specification for Upgrade or Repair
            This specification for the MSI GE Raider GE66 - 12U Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Raider GE66 - 12U boardview and Raider GE66 - 12U schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
            09-07-2024, 06:11 AM
