Ratdude's Main rig V3.5
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Finally... I have a final list of specs and part sources for my next personal workstation build.
    here's a part list:
    From V3, I am resuing:
    -Supermicro EATX case
    -Seasonic 600W PSU (may upgrade eventually, as 600W is kinda on the edge for what I'm doing)
    -2x AMD Opteron 285, 2.6Ghz dual core
    -16gb Kingston ECC DDR400
    -4x 73gb 10K WD raptors, w/ 3ware 9500s-4lp+BBU, RAID 0
    -Mitsumi Floppy/card reader combo, firmware upgraded for SDHC (may swap to a dedicated reader w/usb port if the floppy proves useless)
    -Hauppauge HVR-1600 (currently in a repurposed V2, will be pulled for the build)
    From stuff I had sitting:
    -Liteon DVD-RW, SATA. yes, brethin, this is the drive you traded me ages ago... it's being pulled from a HP D530
    -LG PATA DVD-RW: Found the other day at a goodwill for $4, I may use it elesewhere.
    - Regarding opticals, the future goal will be a DVD burner and a BD drive of some sort, both SATA, and at least one having lightscribe (since I have a buttload of lightscribe DVD+R's, got 60 for $9)
    -2x 120mm Arctic F12 CO PWM 2BB fans: I ended up buying 3 after I messed up and broke one
    -2x Stock AMD 940 coolers with 5k PWM fans added- combo of some spare coolers and the original fans from V2's 604 HP coolers. Very short wires, hopefully they'll reach .
    Sourced from other members:
    -Tyan S2895 Thunder K8WE w/SCSI and universal (flex) SLI bridge: gg1978 happens to both have one, is willing to sell it, and lives not far off a travel route I take almost every weekend. I'll hopefully be picking it up this coming friday...
    -2x Nvidia Geforce 8600 GT(s?), SLI'd- Bought of brethin after negotiating a decent price... I was going to get 9600's but given the relative difficulty of sourcing 9600's at a comparable price (Would have been about 30% more expensive on ebay, and only if I sniped my ass off). I've in the meantime redone the thermal compound/pads and cleaned the dust bunnies out of the heatsink on both cards.
    The reason I'm not sure if it's a GT or GTS is the chip's model no. shows as a GTS chip but Brethin told me they were GT. The cards have generic Nvidia branding, so no indication there. Based off google image searching, I actually think the cards are indeed GTS given image searching:
    GTS: http://videocards.productwiki.com/nv...orce-8600-gts/ (mine looks like this one)
    GT: http://videocards.productwiki.com/nv...force-8600-gt/ (mine doesn't look like that)
    It also has nothing but poly caps... so no recap required.
    And FYI, I didn't go for an 8800 GTS or two becuase of power draw, cooling, and reliability issues ( I already have one 8800 GTS 640mb in the junk bin, failed reflow, also takes 2 slots). These cards only use one slot, so combined with my case's mesh bracket fillers (lots of airflow cutouts), the fact there is only one slot between the cards shouldn't be an issue.
    OS wise, I'm going to run 7 x64... I've read of people getting it to work no problems... The SLI may be the only hiccup, as I've never set it up before... to those that have, is it fully HW, or is there a separate driver/SW setting to make it run? Is it part of the GPU driver, chipset driver, or a driver all it's own?
    I've attached a PSU calc. report of the build... I think my 600W will cut it... I think.
    Comments or questions? (Any "you shouldn't build workstations, buy a celeron instead" posts will be deleted, please be constructive).
    sigpic
    (Insert witty quote here)
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Ratdude's Main rig V3.5
    SLI is simply a setting in the nVidia control panel; as long as you've got two identical cards and sli bridge installed... just to clarify that
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Whew. Relief (since there is no nvidia-released win 7 driver for the chipset, as that's pre-loaded in 7)
      sigpic
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Well, the motherboard does have to be SLI-capable but I think that's a hardware thing not a software thing. I think you're fine.
        • brethin
          • Dec 2008
          • 1907
          They are 8600 GTS not 8600 GT as I stated in the forsale thread.
          https://www.badcaps.net/forum/showthread.php?t=29474
          GTS > GT IMO. You got a good deal and I was happy they went somewhere they would be used.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            Sure is. One of the platform's selling points actually.
            To those playing at home: Topcat used to have this model mobo as his main rig:
            https://www.badcaps.net/forum/showth...light=polyfuse
            He SLI'd a pair of 7600GT's...
            sigpic
            • brethin
              • Dec 2008
              • 1907
              I agree 8800 GT or GTS would have been power hogs for you. The 8600 GTS in SLI will do all you need it to do on this rig v3.5.
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                My thoughts exactly.
                I remember what a power hog and BGA killer the 8800 GTS of doom was. I still have it in a desk drawer.... looks pretty and smells good (never did get all the rosin paste flux off it from the reflow), that's all you can say for it. Literally a paperweight (and a good one due to the massive heatsink )
                Sure is. Thank you sir for confirming the model and for doing good business.
                The GT was actually the equiv. of a 7600GS in the mainstream lineup... The GTS being the new GT. (but cost wise, a 7900 GS at launch )
                My only worry was power consumption... but as I found out, it's not a major issue as the old setup apparently drew about the same amount (recommended PSU in the high 500's)
                sigpic
                • brethin
                  • Dec 2008
                  • 1907
                  If you find the 8600 GTS's not doing what you need I do have 2 8800 Alpha Dog GT's (tested in SLI) and a 750w HP (Made by Delta) PSU that will give you all the power you need. I can't just do a swap but I will give you full credit for the 8600's if you want to upgrade.
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5045
                    • US
                    I hate to piss all over this thread...but there will be some quirk with some driver or something that will fuck things up. Always is with the rigs you build. 'Workstation' and 'budget' rarely go together. But good luck, I might be wrong, hope I am
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      The only issue I had with V2.5 was getting 8gb of RAM to be utilizeable under 7 x32... which once worked around was a treat.
                      Last edited by ratdude747; 07-02-2013, 04:01 AM. Reason: Moron here wrote "x64". Not happening on Gallatin Xeons!
                      sigpic
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        I doubt that will be an issue.
                        Not sure I even want 8800's... Part of it is the fact my two pci-e Slots have only one slot separating them. Given how critical cooling is to the 8800 (as I found out with my 8800 GTS), and that they take two slot's of space, It's IMHO too close to run well. However, the 8600 GTS only takes up one slot, which leaves a slot under the upper card which can be free space for the cooler to breathe... and with my heavily vented bracket fillers, it will also make a good exhaust for the cards.
                        My card layout will be:
                        [0] blank/firewire header port (Not sure which yet) *silkscreen for a PCIe 4x slot, no actual slot*
                        [1] 8600 GTS #1 *PCIe 16x #1*
                        [2] blank *PCI slot*
                        [3] 8600 GTS #2 *PCIe 16x #2*
                        [4] blank *PCI-x 100MHz*
                        [5] TV tuner card *PCI-x 100MHz*
                        [6] 3ware 9500 *PCI-x 133MHz*
                        If I had a free PCI, I'd also toss in my sound blaster x-fi (so I could use HDA instead of AC '97)... but given how my only low profile card, the 9500, gets pretty toasty, I figure it wouldn't be a good idea to stick it in slot 4 and putting the xfi in slot 7.
                        I figure that ought to be a pretty good card layout...
                        sigpic
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          After doing some research... it looks like that, aside from the media keys of my fingerprint keyboard, everything in the build can be linuxed... even SLI and the TV tuner. Do I dare... Hmmm...
                          sigpic
                          • Pentium4
                            CapXon Be Gone
                            • Sep 2011
                            • 3741
                            Go for it
                            • shovenose
                              Send Doge Memes
                              • Aug 2010
                              • 6575
                              use Windows.
                              • shovenose
                                Send Doge Memes
                                • Aug 2010
                                • 6575
                                By the way, 4 oldish drives in RAID0 - hope you don't care about your data It'll be blazing fast though!
                                • luke10050
                                  • Mar 2013
                                  • 209
                                  hahaha speaking of 8800 GTS's and their potential to kill themselves, i have one that i need to reflow. bugger quit on me half way thru a game of starcraft 2 with my friends. i was using my motherboards intergrated graphics for close to 6 months (GMA4500) but i did get some gaming done, until my friend upgraded his gpu and gave me his old 9600gt. Good luck with the rig! from memory the geforce 8 series had a LOOOT of problems (mainly the mobile chips though)
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    Good luck. Be sure to use plenty of paste flux... tin whiskers and the like suck.
                                    sigpic
                                    • luke10050
                                      • Mar 2013
                                      • 209
                                      hahaha, thanks for the advice. i actually have two 8 series cards. i have an 8600M GS (kill me now!) and a 8800 GTS 320 (lasted about 5 years) so i guess i cant fault it. best reflow method ive found is using a cheap toaster oven to bake the boards and get them to around 240 degrees. seems to outlast my other reflows (albeit they were done with a gas soldering iron, i know its shit, but its really all i have money for)
                                      Best of luck with your new PC, i hope it doesnt give you too many problems. tbh its a pretty cool idea!
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        Bought the Board and SLI bridge. Coming soon next week... the first build of 3.5!
                                        sigpic
                                        • Dobrowol
                                          Dell Latitude 3520 help with bios build/repair
                                          by Dobrowol
                                          Hello. Ive got problem with Dell Latitude 3520. After power on, no display and fan goes crazy. Standard job, I exported a clean bios from update via pfs extract.
                                          Steps i done and results:
                                          I exported a clean bios from update file via pfs extract.
                                          1. Build clean bios with clean ME, PMC, PCH in flash image tool.
                                          Result: Dead
                                          2. Build clean bios with no changes in ME, new PMC, PCH
                                          Result: Dead
                                          3. Build old bios with clean ME, new PMC, PCH
                                          Result: The same
                                          09-22-2023, 02:43 AM
                                          ACER Revo M2-601 Revo Build i3-6100U Specification for Upgrade or Repair
                                          This specification for the ACER Revo M2-601 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Revo M2-601 boardview and Revo M2-601 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER Revo...
                                          09-12-2024, 03:28 PM
                                        • iotaa
                                          How to build this little device please for my campervan security
                                          by iotaa
                                          You will probably find this funny, and it is, but it's also a project I'd like to take seriously.
                                          I have a campervan and I'd like to avoid thieves to break in it when I am inside it or not.
                                          For this purpose I imagined a simple device that can play a sound based on a vibration detection (in case of intrusion attempt) or by pushing a button manually.
                                          The sound wil be a growling dog, which will deter any thief, thinking there is a big dog inside the van
                                          This sound can be manually triggered by me if I'm inside the van, or played automatically...
                                          09-18-2022, 09:52 PM
                                          NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                          by sam_sam_sam
                                          I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                          I bought this from an eBay seller but unfortunately they only had one
                                          I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                          I bought three of from them to also make battery packs with this output power limit in mind
                                          I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                          04-23-2025, 05:50 AM
