Windows XP question
    Windows XP question
    I have a Dell 9200 with a win xp coa tag on the top of the case. I dont have a xp disk so i bittorrented an iso intending to install with my genuine serial. However i can't continue the install without entering the pirated serial. Is their a way to change the pirated serial to my genuine serial when the install is finished?
    I have salvaged and fixed 18 TVs (1 DLP), 22 LCD monitors, 8 stereos, network stuff, and more laptops and computers than i can count.
    Service Menu/Factory Reset Codes for TVs
    Re: Windows XP question
    is it the same version? I use iso'd (untouched) XP OEM disks all the time and it never rejects the OEM (DELL, HP, whatever) sticker as long as they're the same edition
    M$ does have a tool that lets you change your key, but I forget the name offhand
      Those pirated ISOs are normally XP Pro Corporate edition (as it doesn't need activation). Those won't work with the XP Pro OEM product keys. You need to find an XP OEM disc.
        here ya go
          Uranium-235 -
          Does that tool allow you to actually use keys interchangeably from OEM to Pro or vice versa? I think not. I think it's just the equivalent of "Change Product Key" in msoobe.exe /a.
          "We have offered them (the Arabs) a sensible way for so many years. But no, they wanted to fight. Fine! We gave them technology, the latest, the kind even Vietnam didn't have. They had double superiority in tanks and aircraft, triple in artillery, and in air defense and anti-tank weapons they had absolute supremacy. And what? Once again they were beaten. Once again they scrammed [sic]. Once again they screamed for us to come save them. Sadat woke me up in the middle of the night twice over the phone, 'Save me!' He demanded to send Soviet troops, and immediately! No! We are not going to fight for them."
          -Leonid Brezhnev (On the Yom Kippur War)
            You need the dell edition of the disc... they're the same as regular discs minus not needing a key code (looking for an SLIC key in the BIOS instead). Since all they care about is the correct code in the BIOS, Either the home or pro version of the dell version image will work.
            I personally use this one for my dell builds:
            http://thepiratebay.sx/torrent/41825...XP_PRO_SP3.ISO
            (I probably should seed it again, sorry!)
            As far as I can tell it's clean... no hacks or cracks, so I can post it.
            sigpic
            (Insert witty quote here)
              AFAIK, it's not that the discs don't need a key, but I think that the key is entered in the "unattended" section of winnt.sif. You can rig those discs to ask for a key (And also get back the windows repair ability for that matter) by removing the unattended section, so I think the difference between the OEM and VLK discs are deeper than that. Either way, that Dell OEM disc you linked will work fine.
              After setup, run "c:\windows\system32\oobe\msoobe /a", then pick "I want to telephone", then "Change Product Key", then close it.
                yeah I forgot about that. I've actually used that before. I used the tool once or twice when windows was activated, but MSSE and some components thought it was not. I think it uses a separate activation system that works in special cases
                Rat you don't need a dell oem disk. Fuck I can use a HP oem disk on a dell, and put the dell key in during the install (for pro, afterwards for home), it will still work
                I do it for custom builds all the time
                  I think Retail (and possibly Student's Edition) discs can be modded into OEM too. Just need to copy the disc to HDD, or extract the ISO if it's an ISO file, then edit the setupp.ini file.
                  More info:
                  http://www.thetechguide.com/howto/setuppini.html
                  http://wiki.lunarsoft.net/wiki/Product_IDs
                    The setupp.ini method will result in the install not accepting any key if you try to convert VLK to OEM or something like that.
                      I've used standard XP OEM SP3 discs lots of times with Dell PCs, and never had it not work.
                        Google oembios changer, there's a utility that will make any version of XP into an OEM version that auto activates once it sees the correct slic data in the BIOS. Used it a few times when I couldn't find a Dell or HP disk. It works fine, but it's a pain in the ass to find the corect OEMBIOS files. The download links keep getting nuked.
                          thanks guys!
