Windows XP question
  • henrysin44
    • Apr 2013
    • 109
    Windows XP question
    I have a Dell 9200 with a win xp coa tag on the top of the case. I dont have a xp disk so i bittorrented an iso intending to install with my genuine serial. However i can't continue the install without entering the pirated serial. Is their a way to change the pirated serial to my genuine serial when the install is finished?
    I have salvaged and fixed 18 TVs (1 DLP), 22 LCD monitors, 8 stereos, network stuff, and more laptops and computers than i can count.
    Service Menu/Factory Reset Codes for TVs
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: Windows XP question
    is it the same version? I use iso'd (untouched) XP OEM disks all the time and it never rejects the OEM (DELL, HP, whatever) sticker as long as they're the same edition
    M$ does have a tool that lets you change your key, but I forget the name offhand
    • c_hegge
      • Sep 2009
      • 5219
      Those pirated ISOs are normally XP Pro Corporate edition (as it doesn't need activation). Those won't work with the XP Pro OEM product keys. You need to find an XP OEM disc.
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        here ya go
        • mockingbird
          • Dec 2008
          • 5484
          Uranium-235 -
          Does that tool allow you to actually use keys interchangeably from OEM to Pro or vice versa? I think not. I think it's just the equivalent of "Change Product Key" in msoobe.exe /a.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            You need the dell edition of the disc... they're the same as regular discs minus not needing a key code (looking for an SLIC key in the BIOS instead). Since all they care about is the correct code in the BIOS, Either the home or pro version of the dell version image will work.
            I personally use this one for my dell builds:
            http://thepiratebay.sx/torrent/41825...XP_PRO_SP3.ISO
            (I probably should seed it again, sorry!)
            As far as I can tell it's clean... no hacks or cracks, so I can post it.
            sigpic
            (Insert witty quote here)
            • mockingbird
              • Dec 2008
              • 5484
              AFAIK, it's not that the discs don't need a key, but I think that the key is entered in the "unattended" section of winnt.sif. You can rig those discs to ask for a key (And also get back the windows repair ability for that matter) by removing the unattended section, so I think the difference between the OEM and VLK discs are deeper than that. Either way, that Dell OEM disc you linked will work fine.
              After setup, run "c:\windows\system32\oobe\msoobe /a", then pick "I want to telephone", then "Change Product Key", then close it.
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                yeah I forgot about that. I've actually used that before. I used the tool once or twice when windows was activated, but MSSE and some components thought it was not. I think it uses a separate activation system that works in special cases
                Rat you don't need a dell oem disk. Fuck I can use a HP oem disk on a dell, and put the dell key in during the install (for pro, afterwards for home), it will still work
                I do it for custom builds all the time
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  I think Retail (and possibly Student's Edition) discs can be modded into OEM too. Just need to copy the disc to HDD, or extract the ISO if it's an ISO file, then edit the setupp.ini file.
                  More info:
                  http://www.thetechguide.com/howto/setuppini.html
                  http://wiki.lunarsoft.net/wiki/Product_IDs
                  • mockingbird
                    • Dec 2008
                    • 5484
                    The setupp.ini method will result in the install not accepting any key if you try to convert VLK to OEM or something like that.
                    • c_hegge
                      • Sep 2009
                      • 5219
                      I've used standard XP OEM SP3 discs lots of times with Dell PCs, and never had it not work.
                      • LLLlllou
                        • May 2011
                        • 201
                        Google oembios changer, there's a utility that will make any version of XP into an OEM version that auto activates once it sees the correct slic data in the BIOS. Used it a few times when I couldn't find a Dell or HP disk. It works fine, but it's a pain in the ass to find the corect OEMBIOS files. The download links keep getting nuked.
                        • henrysin44
                          • Apr 2013
                          • 109
                          thanks guys!
                          • japlytic
                            DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                            by japlytic
                            In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                            Tried (only with keyboard/mouse connected):
                            • BIOS + database update
                            • Using latest Windows 11 image built with official image creation tool
                            • Previous setup version for Windows 11 installer
                            • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                            • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                            • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                            06-19-2025, 04:59 PM
                          • rheyntau
                            ASUS C202SA CHROMEBOOK TOUCHPAD NOT WORKING AFTER INSTALL WINDOWS 10
                            by rheyntau
                            CAN ANY ONE HELP ME WITH THIS PROBLEM....ASUS C202SA CHROMEBOOK TOUCHPAD NOT WORKING AFTER INSTALL WINDOWS 10 ..IT WAS ELAN TOUCHPAD..I DOWNLOAD A DRIVER BUT ITS NOT WORKING IT SAYS "WINDOWS FOUND DRIVERS FOR YOUR DEVICE BUT ENCOUNTERED ERROR.....THE HASH FOR THE FILE ISNOT PRESENT INTHE SPECIFIED CATALOG......."
                            07-06-2025, 07:22 AM
                          • baletak
                            Lenovo T490 - motherboard serial - windows licence lost - after corrupt bios chip replacement
                            by baletak
                            had T490 with faulty bios chip. Bought chip out of ebay and soldered on. Laptop starts and works however serial numbers of laptop and motherboard do not match.
                            I have updated laptop model number.
                            1) I did not find the way to update laptop serial number - I have this one.
                            2) I dont know where to get my motherboard serial number and how to update it. Is it somewhere physically on the mainboard? How do I update it?
                            Hope to find someone to help me with this as I am hitting dead end at the moment.
                            Many thanks
                            Miro
                            05-23-2025, 01:21 AM
                          • ivtec
                            install Linux on Windows 10 | Install Ubuntu on Windows 10 using Virtualbox ?
                            by ivtec
                            Has anybody installed Linux on Windows 10 using Virtualbox? and since my old PC will have support after oct 25 and won't update to 11 , i just want to use win 10 for Music notation program and use Progdvb iptv player .
                            01-17-2025, 12:54 PM
                          • bohaboha
                            how to install gl usb2.0 uvc camera device driver on windows 10
                            by bohaboha
                            Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
                            but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
                            any help?
                            01-26-2025, 08:33 PM
