I'm recapping a M2A-VM HDMI motherboard. The chipset heatsink (passive) is known to become very hot and watching how "brownish" got the motherboard (pic. 1 & 2), I decided to (at least) renew the thermal paste, maybe add also a fan, should the mb turn on...
Unmounting the heatsink I discovered a square of foam around the central area, where the chipset stands (pic. 3 & 4); it seems to be placed over the SMDs (pic. 5).
I really have no idea how to replace the foam, so I'm carefully scratching the old paste without touching the foam and I indend to reuse it as is; in the process of unmounting, the foam got away from a little spot (pic. 3), but 95% is still there.
What's for this foam? It's just mechanical: to help place the heatsink flat?
Should I replace/remove it?
Thank you for any advice.
 which is what this site is about!
 which is what this site is about! ). I'll probably add a 80mm-5V-powered fan over the NB heatsink and the mosfets (this is an HTPC, silence is required). I'll have to build some sort of support first, keeping in mind the little space I have between cpu and PCIe.
