The ghetto mod thread
	This is a sticky topic.
 Re: The ghetto mod thread
 Hand made air diverter (plastic sheets from fruit packaging - all held together by a good amount of hot glue ). It forces the air from the fan to be pushed into the heat sink fins. Similar to this (my HP Pavilion 8756C): ). It forces the air from the fan to be pushed into the heat sink fins. Similar to this (my HP Pavilion 8756C):
 https://www.badcaps.net/forum/attach...1&d=1353298522
 ^ Actually, that's an old picture. Now I have a bigger diverter that goes all the way to the heat sink.
 Originally, HP had the fan (a dual ball bearing 0.30A Delta) mounted on a plastic duct and the fan was sitting about 3 cm above the CPU heat sink with no air diverter behind it. To make sure the heat sink was cooled, they had the fan blowing on full blast (12V). And like any other good Delta fan, this thing was pushing lots of air and making lost of noise. Even worse, the plastic duct was resonating and amplifying the noise, so the PC was very loud. Considering the CPU in this PC is a tame 850 MHz Pentium 3, the computer really doesn't need to be making all of that noise.
 So, the first thing I did was eliminate the fan duct - I just hung the fan with wires from the top of the case. That alone cut the noise by half. Next, I turned down the fan speed with a cheap $0.99 fan controller. Of course, that lowered the air flow. Therefore I had to make sure that all of the air from the fan went to the CPU heat sink - and that's what this plastic diverter accomplished.
 Right now I have the fan running at a very low speed - just enough for it to spin. And even so, the CPU heat sink still feels cold even under 100% CPU load, regardless of how hot my room is (usually 27-28C in the summer).
 Thank you.Originally posted by goodpsusearchThis actually looks amazing! I like it!
 I have another plastic box like that. I'm thinking about making another amp. My uncle gave me an old box of chips and components he had collected over the years when he used to be interested in electronics (which was quite a while back). Among the stuff are some nice amplifier ICs. So I'll see what I'll do with that box .
 I was suspecting it was some aerodynamic trick . .
 Let's continue terrorising your eyes . .
 That cardboard duct securing exclusive cool air from the front for the NH-D14, ontop the 960T X4 3.0 unlocked to X6 & OCed to 4.1, lowers CPU temps by ~4º C.Comment
 I will fight terror with terror!
 Here's a GeFoce 7600GS of mine I got for free:
 https://www.badcaps.net/forum/attach...1&d=1353381100
 ^ Custom heat sink is made from an Xbox 360 GPU heat sink. Had to do only minor trimming and cutting to make it fit.
 Now the back side:
 ^ we have a Xbox 360 heat sink retention bracket holding the heat sink via 2 screws. Since there were ceramic caps on the opposite side under the GPU, I had to raise the bracket. That's what the 2 wood pieces do. A piece of nail is placed on top of them and used by the retention bracket as a swivel so that the tension on each side of the heat sink is even. To make sure the wood pieces and the nail swivel do not move if there's a slightly loose tension (there shouldn't be, but just in case), I hot glued them to the video card.
 Finally, note the lower MOSFET on the left - that's the reason why I got the card for free (the original 20A one was shorted). The replacement in that picture is a 85A MOSFET (a 85N02G) taken again *gasp* from a Xbox 360. Let's see the video card try to make this one go short
 And finally, something to cool the heat sink with:
 ^ Yup, that's half of a Xbox 360 fan set cut with a jig saw . The fan is a 70 mm Delta screamer. I only have it hooked up to 5V because anything more will make the video card fly away - that's how powerful those things are. . The fan is a 70 mm Delta screamer. I only have it hooked up to 5V because anything more will make the video card fly away - that's how powerful those things are.
 I didn't know cardboard is UL 94V0 -approved . .
 How to know the CPU in your computer is overclocked too much...
 - the ducts start catching fire
 I must admit, if you never told us that duct was made from cardboard, I wouldn't have never guessed it. Looks very well cut and formed.Last edited by momaka; 11-19-2012, 09:28 PM.Comment
 That half-of-a-fan of yours has raised the bar a lot , but I'll try. Cavemen RAM sinks cut to shape from 60mm wide, 2mm thick aluminium strip. , but I'll try. Cavemen RAM sinks cut to shape from 60mm wide, 2mm thick aluminium strip.
 Your move . .
 The relatively hard cardboard from photobooks makes great stuff for PC air ducts, flexible enough but also rigid enough, after a bit of origamiI must admit, if you never told us that duct was made from cardboard, I wouldn't have never guessed it. Looks very well cut and formed. . .Comment
 Hehe, thanks, I do take that as a compliment
 I think that 7600GS with the half-fan IS the most ghetto working computer mod I have right now. I do have one that is more ghetto but it isn't "working" quite yet (and probably won't be, but we will see ) - pictures for that one coming perhaps later this week. ) - pictures for that one coming perhaps later this week.
 But to keep the thread flowing, I'll post a few more pics of another video card I modded in a similar fashion...
 A Radeon 9500 Pro / 9700.
 https://www.badcaps.net/forum/attach...1&d=1353991011
 ^ the heat sink is again made from an Xbox 360 GPU heat sink, as is the retention bracket, lol:
 Another shot of the retention bracket:
 ^ yes, that's a piece of a wooden block. It sits right under the center of the GPU die, so the force from the heat sink won't bend the PCB and crack the BGA joints on it.
 Another shot:
 ^ This one shows the half fan I used in the 7600GS above. Originally, I was going to use it with this Radeon card but decided it was too heavy and bent the PCB too much so I decided to use it in the 7600GS instead. I do have the other half of that fan, though, so I can always put 1 on this card too
 And here's the whole setup:
 And the reason for this mod - I have 3 more of these Radeon 9700 cards that are working and only 1 heat sink that fits them (a Chinese replica of the 9800 Pro heat sink, that is - but it's well made). So that means I need at least 3 more heat sinks. And I say at least because I have 4 more 9700s that still need to be fixed/re-flowed so with some luck I can have up to 7 of these.
 Another specialty of mine is custom power connectors for power adapters. This is the first one I did:
 I found this boombox in the trash many years ago. It worked fine on batteries but not on AC. The primary on the transformer inside it went open circuit. I can actually probably repair it now since i have a temp. controlled soldering station that can desolder the traffo (back when I did the ghetto connector mod, I didn't have that station, so that wasn't an option)... But I like making those plugs. The power adapter you see in the picture is (IIRC) 15V, 4A from a laptop. The bulk amp cap is rated for 16V (hence the "16VDC in max" note I put).
 Since that mod, I have made quite a few other connectors. Even the camera that took all of these pictures uses one for the power converting cable . The tone controls for my headphone amplifier are another example. Up until last week or so, the tone controls were still on my breadboard and the way my computer connected to them was through some home-brew audio jacks made of wood and staples. I suppose words aren't much good in showing this. I'll try to take a few pictures of these things this week and post them. . The tone controls for my headphone amplifier are another example. Up until last week or so, the tone controls were still on my breadboard and the way my computer connected to them was through some home-brew audio jacks made of wood and staples. I suppose words aren't much good in showing this. I'll try to take a few pictures of these things this week and post them.
 I also have a non-computer ghetto mod that I just completed just last Friday - I converted an old 9.6V battery drill we had to use a Xbox 360 203W power supply. No pictures yet, but I'm sure you can imagine . .
 Planning on some crazy overclocking there?Cavemen RAM sinks cut to shape from 60mm wide, 2mm thick aluminium strip.
 http://www2.picturepush.com/photo/a/...g/11451510.jpg
 Looks good, though. I like how you removed the sticker on the RAM and put it on top of the heat sink - that way you don't have to remove the heat sink to see what kind of RAM you had in there (plus, the RAM chips cool better).Comment
 On my computer (the old Compaq from my earlier post), I made a heatsink for the clock generator chip from heatsinks from two old CD-ROM drives. I stacked the two heatsinks on top of each other and soldered them together.
 That transformer doesn't look big enough to power a boombox. Maybe you can ghetto mod a bigger transformer into it. If the transformer has a thermal fuse inside, you could do a ghetto mod to bypass it like I did to a Harbor Freight cordless drill battery charger.I found this boombox in the trash many years ago. It worked fine on batteries but not on AC. The primary on the transformer inside it went open circuit. I can actually probably repair it now since i have a temp. controlled soldering station that can desolder the traffo (back when I did the ghetto connector mod, I didn't have that station, so that wasn't an option)... But I like making those plugs. The power adapter you see in the picture is (IIRC) 15V, 4A from a laptop. The bulk amp cap is rated for 16V (hence the "16VDC in max" note I put).Comment
  Nice mod, but I don't know if you realize that 99.9% of the members on this forum are males Nice mod, but I don't know if you realize that 99.9% of the members on this forum are males
 Well, it's a small boombox anyways. I don't remember the exact rating of the speakers or the amp IC, but I think both were rated under 10W total. The traffo IMO looks big enough for 0.5A at 12V continuous and maybe 1A peak, so it should be good enough. Or maybe you're right, I don't know. The primary is open, though, so it likely has a blown thermal fuse as you suggested.Originally posted by ltiThat transformer doesn't look big enough to power a boombox. Maybe you can ghetto mod a bigger transformer into it. If the transformer has a thermal fuse inside, you could do a ghetto mod to bypass it like I did to a Harbor Freight cordless drill battery charger.
 Funny you mention the cordless drill battery charger. The batteries for my 9.6V craftsman cordless drill still hold a little bit of charge but the charger blew the thermal fuse last time I tried to use it. Hence why I decided to mod the drill to use a power supply.Comment
 Let's keep the party going. Ghetto-silencing of HDD:
 Couple slices of Slot-A heatsink thermal-pasted and fixed with zip-ties to the windward side to keep heat at bay, then a jacket of EPS, then another jacket of corrugated box. Then enjoy the silence.
 I was inspired by this masterpiece, crowning work of the ghetto-modding:
 Hahahahaha!! Love itI love putting bad caps and flat batteries in fire and watching them explode!!
 Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
 does that hard drive really make that much noise my computer drowns out the noise of my hard drives i got a 500gb blue and 1tb black.My Computer.
 AMD APU A4-3300 2.5ghz 1mb cache
 Motherboard GigaByte GA-A75M-S2V
 Kingston HyperX Blue DDR3 8GB (2x4GB)
 SB Audigy 2 ZS [B800] Sound Card
 500GB WD Caviar® Blue™
 1 Terabyte WD Caviar® Black™
 2 Terabyte WD Caviar® Black™Comment
 I agree that adding noisy fans would defeat the purpose. However they could be silent fans, or standard fans silenced with resistors or software control to lower rpm & noise.
 That's the problem, once you've silenced the rest of the comp the HDD/s emerge as the main source of noise/vibration . .
 Most people don't care much about comp noise, but I'm paranoid on the subject. As on the other hand I'm also paranoid on cooling, conciliating both makes an interesting challenge . .Comment
 I need to add some fans or something to this Hp of mine. Its too quiet! Back in the day I had and OC'ed AMD k6 with four large fans in the box. It souned like a Helicopter taking off all the time."It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
 Mark Twain
 "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
 John Paul Jones
 There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
 Rod SerlingComment
 What parts are you worried about???As on the other hand I'm also paranoid on cooling, conciliating both makes an interesting challenge . .
 I don't think the HDD silencing rigs shown would work very well, because the heatsinks strapped to the HDDs are exposed to the outside world and transfer the vibrations, defeating the muffling - therefore, why bother with such a setup???Comment
 Not really worried now, after I finished fiddling it behaves. Idling @ 21C ambient:
 As you well say the heatsinks are a weak spot in the sound-proofing, but I didn't want to fry the HDD in the process, so had to compromise. However after the guetto-mod noise from HDD is 25% or less of what it was, and vibrations are now zero. Fair enough.I don't think the HDD silencing rigs shown would work very well, because the heatsinks strapped to the HDDs are exposed to the outside world and transfer the vibrations, defeating the muffling - therefore, why bother with such a setup???Comment
 Unless you leave a few small fans in there, like in this picture . .
 http://img401.*************/img401/9...lent05bva3.jpg
 Nice mod, though. I really need to try something similar for some of my HDDs as well. This old IBM Deskstar DTLA-305030 in my daily-use P3 computer drives me nuts sometimes. Actually, I don't think I'll be able to silence it, even if I used 3x the insulation you did. When it's reading/writing lots of random files, it sounds as if the heads are literally banging on the platters. I've never heard such loud heads in a hard drive before. Bearings are quite noisy too. And as a bonus, the HP case it's in has great acoustics, so all of that noise is amplified at least 10x.
 Oh and that thing runs hot too. It's 20 to 21C in my house right now, and it still manages to run at 36 to 40C. In the summer when it's close to 27C in the house, this thing easily reaches 44+C. I can't even imagine how hot it would run in a tight insulated enclosure. (On a sidenote, my laptop is much worse, though. The hard drive in it - a 20 GB Hitachi Travelstar - goes to a whopping 55-58C in the summer. I think I saw it at 62C once or twice as well ) )
 Yeah, that egg carton is the icing of the cakeOriginally posted by c_heggeHahahahaha!! Love it . .
 I got some pics of some ghetto projects coming soon. Was busy this last week/weekend with some other DIY projects, so I still haven't taken the pictures out of my camera.Comment
			by CapLeakerI've got here an ECU 89661-42840 from an 03 Toyota RAV4. Got the usual transmission problem that is ECU related. Symptoms are not shifting as it supposed to, no shift etc. Turn the car off, wait a minute and back on and it will work again for a bit. I think she's in limp mode here or something.
 Anyway... There are tons of those RAV4 that have this problem. My problem with it is, that it's a right steering import vehicle and the dealer can't read the ECU.
 I went all over the ECU resoldering a whole stack of resistors, no problem. BUT I am stuck on resetting the transmission...
			by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
			by flibidyI have here a Magnum IA.100 which belongs to my parents.
 The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
 Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
 What Ive done........8 Photos-
 01-01-2025, 01:26 PM
			by tehmatixHi,
 Anyone have knowledge about this component D3950 ( I suppose to be BD3950) , an application note or equivalent.
 Thank you
			by SMDFleaCopying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
 Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....-
							Channel: BIOS Requests ONLY!
- Loading...
