The ghetto mod thread
This is a sticky topic.
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    #361
    Re: The ghetto mod thread
    Originally posted by TELVM
    Rubber bands rock!
    There seems to be some clear plastic sheet between fan & heatsink, what's that for Momaka?
    I like this mod by Momaka and I might use it.
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
    • Dan81
      SNES-powered
      • Oct 2013
      • 1866
      #362
      My ghetto mod for this year must've been a cooling fan to cool myself because it was hot in here. I simply used an Allied AL-8400BTX PSU (the one I've repaired in the PSU section here) and a 92mm AVC 12v fan wired up on the PCI-E connector (at least it's worth something ) along with a jumper wire between green and black. (PS_ON and GND)
      Main rig:
      Gigabyte B75M-D3H
      Core i5-3470 3.60GHz
      16GB DDR3-1600
      Samsung SH-224AB DVD-RW
      Delux MG760 case
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8716
        I wonder if my Coolmax PSU fix is ghetto enough... It this jury rig a kludge, bodge, or ghetto fix?
        https://www.badcaps.net/forum/attach...7&d=1501352814
        The two brown jumper wires were added by me to fix the burned track underneath.
        If I had twisted the wires together and left them above the board, epoxied down or not, then I suppose it would count... LOL
          • 31304
          i draw the line at bodging psu's - i dont want to risk anything downstream.
          • diif
            • Feb 2014
            • 6978
            • England
            #365
            That's not a bodge but a photo of the very rare solder sloth upside feeding on some vegetation.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8716
              A lot of these are calculated risks I suppose. Main reason why I went ahead and kludge/bodge fixed this is because this is in the primary circuit - if primary fails, everything is down, anyway - unlike if the control circuitry is bodged, then the output could go out of spec and cause downstream damage. The burned tracks were too weak to reuse so I had to use the solder to make up for the loss of the foil.
              I figured that the main risk of repairing this is repeat insulation failure, and that I spent extra effort trying to ensure that it doesn't fail again. I'm not sure how others would have repaired this damage, or could have just treated this as a total loss/parts unit (which I was intending this PSU to be when I first got it).
                • 31304
                i would have cut the burned section of pcb out, and rebuilt it with epoxy.
                then probably lined or partially butchered the casing!
                  master hoarder
                  • May 2008
                  • 12175
                  #368
                  Go for it. Just beware that those rubber bands dry-rot and degrade very quickly. When I made that mod, I didn't know better. Luckily I didn't use the computer like that. I replaced the fan with a better one and got rid of the rubber band.
                  Exactly.
                  There's no guarantee you won't get a bad PSU even from a reputable manufacturer that manages to burn itself out and the rest of your equipment. With repaired PSUs, at least I know what was wrong and what I fixed and how I fixed it.
                  lol
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    #369
                    Here's one from yesterday/today. A vestel taken off the wall still with two HDMI cables plugged in.
                    I possibly should have looked on ebay for a board and I wasn't given the remote so haven't tested it yet.
                    I will be sealing the wires once I've tested the repair as they are bare strands of copper and not coated magnet wire.
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8716
                      Maybe we need a different thread for bodge/kludge jobs and leave this one for the ghetto, I think that HDMI fix is too "professional" to be a "ghetto" fix (and perhaps my burned track fix too...)
                        master hoarder
                        • May 2008
                        • 12175
                        #371
                        Dang, I thought I've done some fine trace repairs, but never so many next to each other. I admire your patience for this one.
                        On that note regarding removing equipment with the wires still connected... I had a 17" CRT monitor that I forgot was plugged in the wall. So when I lifted it up and started moving it, all of a sudden the CRT pulled away from my hands and fell on the floor. Surprised the crap out of me when that happened. Luckily I have a carpeted floor so nothing broke. Also had a similar accident with the VGA cable plugged in another CRT monitor. But them D-SUB bastards are built tough and made to handle rough handling (lol ).
                        As for ghetto mods, I am working on a video card + fan upgrade for one of my old PCs. Just made a metal bracket to hold an 80 mm fan to the case where the add-on card screw to. Will take pictures when it's done.
                        Yeah, I thought about that too when I made the "Worthless/Pointless" repairs thread. I figured that since a lot of my ghetto repairs are worthless, I wouldn't need to... but now I see that we may need one indeed. In fact, you can see that a lot of the "mods" I posted here in the past are actually repairs.
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          #372
                          Thank you for your kind words Momaka, it was you worthless/pointless repairs thread I was looking for, perhaps I should have tried harder (used search).
                          The repair probably took about an hour on and off, so pointless from a labour point of view vs cost of a replacement board maybe, but more an exercise in can it be done. Certainly quicker than waiting for a replacement board if I can find one.
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            #373
                            You guys should see my (soon-to-be-old) work computer.
                            A working TV? How boring!
                              • 31304
                              T12 soldering iron stand.
                              ingredients:
                              1 weller iron stand - base section for weight.
                              1 joke stand from china.
                              1 pencil eraser
                              2 M5 screws.
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                #375
                                ingredients:
                                1 pencil eraser
                                2 M5 screws.
                                Nice work
                                  • 31304
                                  it's actually more comfortable just throwing the iron onto a "V" instead of poking it into a spring!
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    #377
                                    Indeed. That's pretty similar to how I made the stand for my soldering station as well.
                                    *Edit*
                                    Looks like I even posted this a while back:
                                    https://www.badcaps.net/forum/showpo...&postcount=290
                                    • kc8adu
                                      • Nov 2003
                                      • 8832
                                      • U.S.A!
                                      #378
                                      anyone remember wordless workshop?
                                      • piernov
                                        • Jan 2016
                                        • 4439
                                        • France
                                        #379
                                        Power Mac G4 Quicksilver PSU replacement
                                        Original PSU failed, no power at all, and I didn't know how to fix them back then (6 years ago). So I took an ATX PSU and modified the connector's wiring.
                                        And I added a laptop power brick (from a Compaq Armada 4120) to feed the +24V line (with 20V but it works) as I was using the original Apple display which doesn't have an external power connector. Before that the +24V was feeded by the +5VSB.
                                          master hoarder
                                          • May 2008
                                          • 12175
                                          #380
                                          Ha, nice! I think I've seen people do/suggest that here before on BCN when those proprietary Apple PSUs bit the dust. It works, so why not.
