The ghetto mod thread
This is a sticky topic.
  • lti
    • May 2011
    • 2558
    Re: The ghetto mod thread
    Originally posted by momaka
    Interesting. I wonder what would cause that.
    This is the same DVD recorder that I was messing with about 10 years ago, and I dug it back out to use as a DVD player a couple years ago when I was trying to get a StarTech SVID2USB2 working in Linux. This problem appeared last summer when I was setting up my laptop (also using this DVD recorder as a test video source). It looks like something screwed with the gamma curve. If I fix it, it will be worthy of the "pointless repairs" thread.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8716
      Dammit. Shattered my GPU's fan when cleaning it today. Don't stop the moving train.
      Ended up using zip ties to attach a standard 80mm fan to the shroud. I suspect I still needed to use the shroud (it's one of those dual slot Radeons). The zip tie's ratcheting head wouldn't go through the fan screws or the thin slots I was abusing on the shroud so I didn't need to stick the end into the ratchet head, nor was it long enough anyway.
      Sorry no pictures ... yet... question is whether I can find a half height 12mm thick replacement 80mm fan with screw holes 90mm diagonally apart, instead of the typical 100mm diagonal 25mm thick fan that's currently ghetto-attached for now...
      GPU is at 60°C ...
        master hoarder
        • May 2008
        • 12175
        #543
        Bwah. Where's the "this thread is worthless without pictures" smiley when you need it?
        I guess I will use this instead:
        Probably eBay... though the replacement GPU fans are a bit over-priced IMO.
        If height is not an issue, I don't see why not keep the 25 mm -thick replacement fan. I guess the only reason to replace it if it's a higher airflow and lower pressure fan... which most 25 mm thick fans are. If the fins on the heatsink are really close together, then you should find a thin 80 mm fan, as those typically generate higher pressure (due to more "narrow" fin pitch)... or perhaps just use a 70 mm fan??
        If noise is not a concern, a 70 mm fan from a socket 754 / 939 / AM2 heatsink screaming on 9-12V should cool things pretty well.
        GPU is at 60°C ...
        Not good, especially for ATI/AMD cards.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16959
          Ask and ye shall receive!
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
            master hoarder
            • May 2008
            • 12175
            #545
            WOW. Thank you! I honestly didn't expect this kind of quick response (and smiley update/addition.) This has got to be the only forum I've seen things like that. Really cool, though! (And hopefully I'll try to refrain from harassing newbies when they ask a question in a new thread and don't provide pictures. )
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8716
              You know, other than the fact it probably doesn't cool as well, and the fact it's wasting 3 PCI slots... might need a double take.
                master hoarder
                • May 2008
                • 12175
                #547
                Ah well, if you're not using the PCI/PCI-E 1x slots, then it's not really a waste.
                Fan looks like it's from a cheapo PSU, though... and if so, I'm guessing it's rated for 0.14-0.16 Amps. Thus, it's probably not the most powerful or efficient thing in the world, and probably the reason for the high temps too. Though on that note... I can't quite figure out what AMD/ATI HD series this card is. It has a 6-pin PCI-E power conn, so it has to be HD x770 series or higher (so maybe 6770 or 7770?) Doesn't look like an AMD/ATI OEM either. If it's an HD6850/7850, then that stock cooler would be at least partially responsible for the high temps too, as it looks a bit inadequate (for the 120W TDP of those cards.)
                  master hoarder
                  • May 2008
                  • 12175
                  #548
                  The ghetto mod thread - laptop rubber feed repair
                  Since this thread has been awakened, here is something I did recently (actually, yesterday.)
                  I've been piecing together / playing around with a few junker laptops this week. One of them was missing a rubber foot on the bottom, which made the laptop very wobbly on a hard, flat surface (and kind of annoying even, when typing on it.)
                  So, I had an idea!
                  Let's take a busted Sacon FZ apart:
                  Do you see where this is going?
                  A few drops of contact cement later, and this was the result:
                  ^ Yes, that's the rubber bung from the busted cap. Fortunately for me, that vented Sacon FZ cap was so dry in there, that I didn't really need to clean the rubber bung with anything too harsh or "exotic" (e.g. acetone, toluene, and etc.) Nope, just sanded it down a bit (it was about 0.8-1 mm too wide for the plastic hole on the laptop's body), wiped both surfaces with IPA, put contact cement on both, and glued it all together. Simple as that!
                  The best part is, now the laptop doesn't wobble anymore at all. It's like that rubber bung was meant to be there.
                  Also, it's a good (re)use for busted/vented caps. I've actually though of using the rubber bungs of capacitors as rubber feet for a long time... but just never found a convenient time to try it. Well, now I have.
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16959
                    Now that is absolutely a class act and an insult to the maker of the crap cap (a good thing)!! This one has gotta be one of the year's 10-best!
                    Team : 49813
                    Join in!!
                    Team Stats
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      #550
                      Best post in this thread so far momaka!
                      (Well, technically I guess it is not ghetto since it looks perfect too!)
                      • televizora
                        ghettomodmaster
                        • Nov 2016
                        • 957
                        #551
                        So, yet another Dell 760 with faulty PSU. Caps plus broken fan fins. I don't understand how the fins of this fan can be broken. And because it was 10mm thick and I couldn't find 12mm thick fan around and the metal was bent to accommodate 12mm fan, I used a hammer to flatten it, so I can install 15mm thick 60mm wide fan.
                        After this the PSU started to turn on on it's own. I found out that somehow between the ground and PS/ON wires - Black and green the heat shrink of the capacitor I installed got scratched during the installation, because the place for it is between the wires and too small. So, it was shorting green to black via the aluminium canister of the cap.
                        This was ghetto mod.
                        Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
                        1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8716
                          LOL, Great idea, I have a laptop with a missing foot as well that has been bugging me, hoping that I could find the foot one day. Now this tells me I need to go through my jar with all the bad caps I still haven't thrown out yet...
                          • dmill89
                            • Dec 2011
                            • 2534
                            I ordered a GPS mount for my motorcycle, but it is shipping from Belgium and thus will show up "eventually", so I came up with a temporary solution until it arrives with a piece of 3/4" copper pipe and some spray paint.
                            First I mashed the ends flat with a vise:
                            Then drilled some holes with a Harbor-Freight drill press:
                            Test Fitting (it bolts up to 2 existing screws for the "dash" trim):
                            Final product after a coat of black spray paint (the included Garmin mount with the u-bolt mounted RAM ball is attached to the pipe):
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8716
                              BTW, do 3d-printed solutions of any sort count as ghetto, or are they too modern to be so?
                                • 31304
                                3d printing does not count,
                                it's fabrication - not modification.
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8716
                                  But if it's replacing a missing/broken piece...
                                  Oh, and what's even more fun is when you're trying to replace an aesthetic piece that's outward facing...and you get this layer lined, usually wrong color item (who ever has just the right color filament on hand?) replacing a fairly visible piece that should have been simply replaced...
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    #557
                                    Thanks guys!
                                    Yeah, it's sad when a cap maker's caps are more useful as other things than caps. In the case of Sacon FZ, even this rubber bung is a bit crap. The original laptop feet are fairly soft (can easily sink a little when pressed with something sharp, like a nail) and grip really well. The FZ bung grips just OK, but the rubber isn't anywhere near as soft and has a little "plastic-y" feel to it. That's actually what allowed me to sand it down (to size) very easily with just regular sandpaper. Good rubber is hard to sand with just sand paper!
                                    Heh... well, if you do see the original laptop foot, you CAN tell there is a difference. (I'll see if I can snap a pic tomorrow, if hopefully it isn't too cloudy and dark like today.) In terms of function, though, it works just the way it should.
                                    Unfortunately, the other two junker laptops I have don't have round feet like that, but rather rectangular ones... though I don't see why I can't use more cap bungs even for those.
                                    https://www.badcaps.net/forum/attach...1&d=1621117790
                                    Holy crap, 92 Euro just for that mount?!?!
                                    For that price, I'd keep that "ghetto" -fabricated mount and just roll along with it. (And I put ghetto in quotes, because that looks really good. Can't even tell it's not a factory part, at least from the pictures. )
                                    Yeah, but it still isn't factory original or a direct factory replacement part... so I don't see why not post those anyways.
                                    • dmill89
                                      • Dec 2011
                                      • 2534
                                      It doesn't looks too bad, but the "ghetto" mount does kind of block the top of the speedo (of course right between 60 and 80 mph, about the most common highway speeds) and tach a little from the riding position (not too big of a deal since the GPS shows speed which is more accurate anyhow, the speedo on the bike reads a little high as is pretty much standard for BMW). I already ordered the "official" mount and it already shipped so returning it at this point (once it shows up) would require paying return shipping that would be nearly 1/3 of the purchase price, otherwise I may have skipped it if I thought of (or rather stumbled across I found an article for a similar mount made from a cut-up weed-eater, I didn't have a junk weed eater to cut up, but I figured I could do something similar with copper pipe) the "ghetto" solution earlier.
                                      How the "ghetto" mount looks from the eye-level of the rider:
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        #559
                                        The ghetto mod thread - laptop rubber feed repair comparison
                                        Alright folks, as I said, I'd take a few more shots of that laptop to show the original vs. fixed rubber foot. So here is that:
                                        The Sacon FZ bung is ever so slightly taller than the original rubber foot... but not by much, and the laptop doesn't seem to wobble. So as long as no one turns the laptop around to look at it, they probably won't know the difference. That said, this is a "junker" Sony VAIO laptop with Centrino 1.7 GHz and 512 MB of RAM, so not like I will be selling it to anyone. If I can get the few non-working keys on the KB fixed (namely, Backspace, Enter, and Delete - all of which are hard to go without) or just replace the KB and increase the RAM a bit to 1 GB, it might do OK as a general purpose Windows XP laptop for me to use. FWIW, it's fairly light and I like its design.
                                        Perfect!
                                        Now you have a valid excuse when a cop pulls you over for speeding (or driving too slow?) Either way, most people always travel around 70 MPH on the highways (at least around here), so +/- 10 MPH should be within the realm of acceptable.
                                        I guess that's BMW's built-in "feature" perhaps to make motorcycle riders drive slower, huh?
                                        • eccerr0r
                                          Solder Sloth
                                          • Nov 2012
                                          • 8716
                                          Well as said I had to do the same ghettomod.
                                          And here's our patient... a Centrino 1.6GHz laptop with 1.5GB of RAM. Its Ethernet is shot as far as I can tell, which is unfortunate, it's an old Gbit Ethernet. But anyway our victim^H^H^H^H^H^H^H guest of honor is a 470uF 25V capacitor.
                                          It's a part of the Elite. That blew its top.
                                          Seems to have a nice bung like the Sacon FX...
                                          So the first attempt is to massage it to make it drop its bung. The cap of course is crimped so rolling it along to massage and make the aluminum can a bit flatter so the bung would slide out.
                                          Well at this point the bung still wouldn't come out.
                                          So I ended up squeezing the can like a tube of toothpaste and pried the thing out.
                                          It sure did not want to drop the bung! But finally with a bit of encouragement with a screwdriver, and the laptop as a new leg to stand on.
                                          I just need to figure out some good adhesive so it won't come out again... or why bother, still have an army of Elites and CapXons to follow suit...
