Furmark and prime, same time, burning smell.
  • Heihachi_73
    • 713
    Re: Furmark and prime, same time, burning smell.
    Originally posted by gilly1984
    The psu looks crap inside, I now have a 300w psu in my pc and its fine, no funny smells when playing dead island.
    Fuhjyyu smoke, don't breathe this.
    • gilly1984
      • 751
      Originally posted by TELVM
      Could this be the reason my pc is so noisy? Its not super loud but its annoying.
      Could it be the air bouncing off the grill?
      Do NOT touch heatsinks when testing for voltages as they may be LIVE!
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        It says "High Efficiency" on the label. Doubt it
        • Behemot
          • 4845
          • CZ
          #44
          Yes, it lowers airflow and can create turbulences on the grill on higher speed.
          I am personally removing it on all my PCs. From time to time even cutting brand new holes for fans if there is not enough (e. g. older cases with single 80mm position). Quite simply:
          • the more fans, the lower RPM you need for the same airflow
          • the bigger the fans, the lower RPM you need for the same airflow
          • the lesser the air restrictioins, the lower RPM you need for the same airflow
          Low RPM=low noise.
          • gilly1984
            • 751
            My fans are not controlled, my exhaust is wired with just the + and -, and my intake (when used) is wired the same. No pwm on either, so they are full on all the time.
            Think i may get ghetto and put a stupidly big fan on it taking up most of the side panel.
            If i do, would it be best to blow in or suck out?
            • Behemot
              • 4845
              • CZ
              #46
              I have fixed speed too. The thing is, I have chosen the speed so low I can't heard the fans Actual count gives me 8 fans ATM.
              • c_hegge
                • Sep 2009
                • 5219
                Stick a dust filter behind it hand have it blow in. That will be the end of your dust problems.
                • gilly1984
                  • 751
                  How have you got them low speed? I have no fan controllers, just on of off.
                  • gilly1984
                    • 751
                    Not too mithered about dust now, the hoover is at hand.
                    • Behemot
                      • 4845
                      • CZ
                      #50
                      Furst, just soldered sesistors in. Now, I am making my own version of those Noctua adapters in 10, 20 and 40 ohm versions so it is modular
                      But in my computer I have the original ones since I have mostly Noctua fans
                      • gilly1984
                        • 751
                        Sort of got it.
                        Bed time now. 6:10am
                        • c_hegge
                          • Sep 2009
                          • 5219
                          I still prefer side panel fans blowing in - filtered or not, otherwise, you'd be fighting the CPU fan
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5042
                            • US
                            #53
                            my current PC (i7 PSU died) I OC'd a nforce 750i to put my 2.66 6750 to 3.2. My side of my case is off and I have two small full speed fans blowing directly on the NB HS, one set to blow right into another. that sucker stays at 43C under stress. I'm afraid to take it higher cause its an nvidia chipset ya know
                            • howardc64
                              LG 65UQ8000AUB no backlight burning smell
                              by howardc64
                              Only 3 years old. Owner said backlight went out and burning smell. Didn't bother plugging in to check if had power LED. Just opened the TV rear and found shorted bridge rectifier diode on the backlight circuit on the PSU. SF26G (400V 2A super fast recovery rectifier link ) diode replace with SF26 (what I had on hand) Google AI said G = Green Components.
                              Burn looked pretty bad on the board but just was blackened carbon coating material. Scraped and cleaned off quite well and clean solder pad for the new diode.
                              06-07-2025, 10:38 PM
                            • stormanimal83
                              Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
                              by stormanimal83
                              Hey....
                              Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
                              my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can“t understand...
                              01-18-2024, 02:15 PM
                            • taurtnt
                              ASUS Prime Z490-P boardview
                              by taurtnt
                              need ASUS Prime Z490-P boardview diagram
                              Hi, I have an ASUS Prime Z490-P motherboard, it doesn't start and I need the boardview diagram, if anyone can help me
                              01-24-2025, 10:26 AM
                            • lezsimply
                              Low resistance reading on 3v line, Asus Prime H310M-A R2.0 desktop motherboard
                              by lezsimply
                              Hello Everyone and Good Day,
                              I've got an issue with this desktop motherboard. It does not power on, Asus Prime H310M-A R2.0. I tested 33ohms reading on 3v line on the ATX connector. It beeps on continuity mode. I tried injecting voltage from 0.9v at 1.5amps and no current being drawn. I raised the voltage to 3v @ 4amps and now I only get 22mA on current. I checked with thermal camera and there is no part heating up. I'm afraid of going further the safe voltage. What could possibly causing the line to be shorted. 5vsb has no short. I get 0.9v on positive pin of power switch. There's...
                              11-22-2024, 03:14 AM
                            • ignacio.ino27
                              Vaio DA0HK1MB6E0 MBX-247 Burning any EC
                              by ignacio.ino27
                              Hello to all.
                              I have this Sony Vaio QUANTA HK1 DA0HK1MB6E0 MBX-247 that is burning the NUVOTON EC when you connect it to power supply.
                              1) The +3vpcu line is going to a direct short after connecting the motherboard to power supply.
                              2) I discovered the EC NUVOTON was shorted. After removing it the short gone out on that line (+3vpcu) but... (If i quit the EC the 3.3v are pressent on +3vpcu because the shorted component was quited)
                              3) There were no shorts after soldering the new EC NUVOTON. But after connecting the board to power supply the EC keeps burning...
                              05-07-2022, 05:24 PM
