The Roach-top thread
Re: The Roach-top thread
How about putting it in a cooler with dry ice? This would both freeze them suckers and deprive them of oxygen.
Another thing that I read is to heat suspected items. Usually clothes are mentioned, and it is said to put them in the dryer and heat to 150 F. My dryer has a rack for drying things you want to lay flat, but I think roaches could escape the dryer method before being cooked.Last edited by Time2Retire; 01-01-2013, 08:27 AM.Comment
woulden't dry ice kind of...destroy the motherboard?Cap Datasheet Depot: http://www.paullinebarger.net/DS/
^If you have datasheets not listed PM meComment
heres a guys response. dosen't sound like a bad idea
http://www.doityourself.com/forum/in...es-laptop.htmlCap Datasheet Depot: http://www.paullinebarger.net/DS/
I think heat should work well to kill the roaches and their eggs. After washing the motherboard, put it in the oven at 100C to 105C for 1 to 1.5 hours. This will also dry it faster. No damage will be done at this temperature. Just don't forget to remove the CMOS battery (if there is one)
The plastics - I don't know how much heat they can take in the oven, but I think really really hot water will work for those. Generally, 70C and above will kill most bacteria so I doubt the roach eggs will survive (provided the exposure time is long enough). I think 1 hour in hot water over 70C ought to get rid of them.
That leaves only the LCD display... hot water is definitely not a good idea here and I don't know if the oven will damage it. Perhaps if you set it in the oven at a low temperature, like 80C or so for a few hours. But I have never tried this, so I will warn you that I do not know what the outcome of this will be. If you have an old monitor you don't mind possibly sacrificing for some tests...Last edited by momaka; 01-01-2013, 10:16 PM.Comment
well well here we are again. I found one roach dead inside it after being for 15 or so days in that igloo with an exposed paper towel of that dupont advidon. Found one big dead roach inside it, and a few small ones.
funny things with this top. After taking it apart, down to the MB/Case and screen, it booted fine. Slowly put it back together. When did it stop turning on? touchpad. There was some nibbling on the edge of the touchpad where it hooks into the mb, one of the contacts came unglued and was shorting with another. I was kind of suprised this caused a no-power reaction, instead of a no screen, shutoff in x seconds, or no working touchpad problem. I got the sharpest pair of scissors I could find and cut across right where the contact bends. Essentially cut the contact length in half.
shoved it in, booted. No working touchpad. tried it again. worked! glad the microcontroller or usb (whatever this one uses) didn't fry from the short
also, one of the outerboards caused a turn on-turn off to happen, till I wiggled the cable around and taped it down. Thats a bad sign, Probably a bad cable, and just luck I got it in a good position
Played Fallout 3 on it last night when I finally finished it up, plays better than it does on my GTX 285, even though it takes longer to load
good side: J and M/A didn't have to buy a used $250 motherboard
bad side: this huge asus top has two massive output fans (one cpu, one GPU, GPU runs hotter), that blow out hot stinking roach shit smell, and probably will for the rest of its lifeCap Datasheet Depot: http://www.paullinebarger.net/DS/
lol slow loading times? put an ssd in there man if the second drive bay isnt already filled up.
the guy won't spend that kind of money :PCap Datasheet Depot: http://www.paullinebarger.net/DS/
Yea I was going to say the same thing yesterday
"The one who says it cannot be done should never interrupt the one who is doing it."Comment
I recently got a free PC from Craigslist to refurb and sell, inside was shredded paper and rat droppings from what seemed like a rat's nest. I blasted away at it with an air hose, then doused it with Lysol a few times and then with Febreeze and let it sit outside for a few days. By the time I sold it, it only had a faint smell of Febreeze.Comment
yea that roach laptop looks like a nightmare. i hope this little country of mine lives up to its reputation of being clean so i wont have to deal with such a severe infestation.
i dont even know what to do. my ez way out wud be to junk the casing and run the system as a skeleton open air test bench system...
hahaha~
<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
This is the time of year to look for those PC's that got screwed up over the winter. People are doing their spring cleaning and they end up just tossing the things to the curb. Now watch what you bring into your home. Most of these things failed because of roaches mice, and rats getting in them. If you have lightning storms in your area it also never hurts to go on a war ride a few days after a big one. You just might find a fine PC with nothing more wrong with it than a blown fuse in its power supply."It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
John Paul Jones
Rod SerlingComment
by Flaku_34Introduction:
Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...13 Photos-
04-18-2024, 12:47 PM -
by jolivaresHi everybody.
i'm looking for the black tape inside apple's devices.
Is the tape tha covers the shield on the mainboard. when you take it out, loses the adhesive.
It is very thin.
can somenone help me to find it for a better repair?
Thanks, God bless you. -
by PedroGG90Hi everybody .
I have a hp pavilion dv 9500 ef laptop that i think is designed to boot only if battery is inside , and my battery is dead .
Any way to bypass it and make it work from power brick only without the need of a battery ?...02-15-2024, 08:19 AM -
by RinxxHello guys. So, I bought this "dead battery" Macbook Air 2015 A1465 hoping to make it good enough for personal use.
When I got home, it turned on right away but indeed, battery was stuck at 1%. But after around 5 minutes it died and wont turn on again, no lights on charger.
Opened the laptop, lots of ants inside, cleaned it up with isopropyl alcohol. Found that PPDCIN_G3H_INRUSH capacitor was shorted, so replaced it and re-assemble it.
Laptop turns on fine for about 15 mins, did a reset and while reinstalling Macos, the laptop became intermittent, charger... -
by CatisfactionHi all,
since my second device of this model number now died due to Canon being service unfriendly, I'd like to reset the counter myself.
This model of printer seems to be on non of the eBay sellers and other suppliers support lists for the Canon Service Tool. Other forums suggested the v5103 version of the tool, which did not work unfortunately.
Has anyone maybe experience with this exact model?
Thank you!07-02-2025, 07:46 AM - Loading...
