Need Help Reparing Ants infested Macbook
  • Rinxx
    • Sep 2020
    • 9
    • United States Of Mars
    Hello guys. So, I bought this "dead battery" Macbook Air 2015 A1465 hoping to make it good enough for personal use.
    When I got home, it turned on right away but indeed, battery was stuck at 1%. But after around 5 minutes it died and wont turn on again, no lights on charger.
    Opened the laptop, lots of ants inside, cleaned it up with isopropyl alcohol. Found that PPDCIN_G3H_INRUSH capacitor was shorted, so replaced it and re-assemble it.
    Laptop turns on fine for about 15 mins, did a reset and while reinstalling Macos, the laptop became intermittent, charger gets disconnected randomly again and again. But everytime, it boots back up.
    The issue gets worse and worse. When I was about to sleep, it can't turn on for more than around 10 seconds anymore. Sometimes no light on charger. Then, next day I tried turning it on again, died after the boot chime and won't turn on anymore. Orange light still present.
    So, opened the laptop again, while charger plugged, found that PPV42_G3H inductor is warm. Then unplugged, checked resistances, PP42_G3H inductor had 50 ohms even though the voltage is present at 3.4v. Also found that PPDDR_S3_REG has only 5 ohms.
    Lifted the PPDDR_S3_REG inductor and low resistance is on the load side. Injected 1v, it pulls around 0.2 amps but can't feel anything hot. (Don't have a thermal cam unfortunately).
    Is this machine done for? Asking just incase there is any hope left lol. Should I try injecting more voltage? Any tips is appreciated. Thanks and sorry for the long read.
    Link to schematic & boardview https://www.badcaps.net/forum/docume...atic-boardview
    Last edited by Rinxx; 08-12-2025, 11:13 AM. Reason: Uploaded boardview and schematic
  • mon2
    • 14813
    Gross.
    Review this flow chart. On a positive note, your chassis is very well documented:
    G3 to S3 State for Ivy Bridge Haswell and Broadwell - LogiWiki
    • petehall347
      • Jan 2015
      • 4451
      give it another really good cleaning , ants leave a real mess .
      • Rinxx
        • Sep 2020
        • 9
        Originally posted by mon2
        Gross.
        Thanks, I have poked around for voltage and even have PM_SLP_S4_L but the short is what prevents it from turning on it seems.
        If it's a short on capacitor or something, I will have 0 ohms instead of 5 ohms right?
        • Rinxx
          • Sep 2020
          • 9
          Flooded the board again with alcohol, still short.
          Washing it with warm water, soap and little amount of vinegar as a last ditch resort. Let's see how it goes
          • Rinxx
            • Sep 2020
            • 9
            After thorough cleaning and washing with water. Short still present, i guess this board is toasted
            • mon2
              • 14813
              What is the 820-**** number on your board?
              • Rinxx
                • Sep 2020
                • 9
                It's 820-00164-A.
                So, it turns out that the short was on the memory (dram chips) not the CPU, I removed all memories and now short is gone. Tried soldering ram chips from a dead CPU A1466, after soldering the chips, measured all resistances again, no shorts that I can find.
                But problem is the board is still not turning on. Haven't tried putting the board into the chassis and press the power button, but afaik it should turn on when charger is plugged.
                I have PM_PWRBTN_L, I have RSMRST and PM_SLP_S5_L which i believe to be towards the final power sequence. Not sure how to move forward, please suggest.
                PS : Memory replacement isn't the same brand, original was Hynix but replaced it with Elpida. But both of them are 8 Gbit LPDDR3 memories, so I assume it to be fine?
                • mon2
                  • 14813
                  Review this article:
                  PM SLP S4 L Timing
                  • Rinxx
                    • Sep 2020
                    • 9
                    PM SLP S4 L Timing
                    Thanks to the article u linked, I found out that i dont have pp1v2_s3 which is also linked to ppddr_g3h. While i was trying to find out the reason, the RAM chips died again. 150-200 ohms dropped to 11 ohms or so.
                    So I lifted the ppddr_g3h coil, then plugged the charger, the coil pad has 2 volts instead of 1.2v. I wonder this is what's killing the ram chips, or can it be because i lift the coil?
                    • Rinxx
                      • Sep 2020
                      • 9
                      Well, the cpu literally blew up while diagnosing. I even fixed the ddr rail issue, problem was the dram controller, replaced it and got normal voltage now.
                      This is the second time cpu shorted on me while diagnosing. There was nothing wrong on the cpu rail (atleast not that i know of). Everything was working except the ppddr rail. Sadge
                      • envym
                        by envym
                        Hi everyone!
                        06-27-2025, 08:54 AM
                      • Flasman90
                        Macbook Pro DFU Restore Issues
                        by Flasman90
                        I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                        - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                        - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                        08-30-2025, 10:27 AM
                      • tobeend
                        Bypass mdm macbook m2 ventura
                        by tobeend
                        1. RESET MACOS WITH IPSW
                        a. Power off MacBook, press and hold the power button to enter Recovery
                        b. Open Disk Utility, remove Macintosh HD
                        c. Reboot, connect to the network to Activate Mac.
                        d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                        d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                        e. Release the other keys, but keep holding the Power key for another 10 seconds
                        f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                        05-26-2023, 07:18 AM
                      • SarcasticOP
                        General question about MacBook power rails for repair.
                        by SarcasticOP
                        I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                        • PPBUS_G3H (12.6V-12.8V)
                          • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                        • PP3V42_G3H (3.42V)
                          • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                        • PPVRTC_G3H (3.3V)
                          • This
                        12-12-2024, 05:50 PM
                      • obelix24
                        A2941 Macbook air 15” - 5V 0a
                        by obelix24
                        I’m working on one macbook air 15” m2 that was water damaged.
                        keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
                        i’ve put macbook in shelf and order new screen so i can fully repair it.
                        Now i got the screen and macbook stays at 5v 0a.
                        i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
                        i don’t have schematics so i don’t know where to start can someone help me?...
                        03-27-2025, 01:19 PM
