Turn the wayback machine to 30-pin SIMMs
  • Logistics
    • Apr 2007
    • 721
    Because I have the bug like a lot of people on this board, and just like to dink around with old hardware, I've often has fantasies about recreating old hardware with new technology so that it's smaller or faster, whatever. For example, remember 30-pin SIMMs? Back then we were actually concerned with how many nanoseconds they ran at because you could actually notice a difference between say 60ns simms and 100ns simms. Or at least we thought we could.
    Anyway, I was wondering how comparable the speed of a 60ns SIMM would have been compared to the actual memory bus. What if you put modern chips with access speeds below 10ns on a 30-pin SIMM? At what point would the access speed of the chips be faster than the bus for a 30-pin SIMM?
    I just think it would be cool to create new CPU's and RAM which completely max out the capabilities of the older motherboards. I dream about it... a lot. Am I sick?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Turn the wayback machine to 30-pin SIMMs
    Sick? Not quite. What you are thinking of is not impossible, but 30-pin SIMMs is a bit old already. I used to have a pimped out system running on 68-pin SIMMs. ASUS P55T2P4 motherboard, Pentium-MMX 200 @ 292MHz under an Athlon XP cooler, 96MB SIMM, with tweaked timings and all.
    I don't know how accurate Everest's tests are, but with the read and write speeds i would be at the P4 level, and the overall memory latency shot up right there under Core 2 Duo. I still have the screenshots lying around somewhere. That machine would boot XP (installed just for kicks, it ran 98) in 30 seconds flat from power switch to desktop. Of course, it was tweaked too, with the bare minimum of things running, but i'm still amazed that was possible. Ran Diablo II quite respectably.
    AFAIK, mobos with 30-pin SIMMs support 5x86 or Pentium Overdrive processors at most, so you'll eventually bump into the CPU limitation. Also, weren't 30-pin SIMMs limited to 4MB or something per stick? Whereas they made 68-pin ones in up to 128MB. That they're close to unobtanium, that's a different point. However, 32MB ones are still pretty common, so you can get 128MB on a typical Socket 7 motherboard. I have a cool Compaq in my closet with 8 (eight!) SIMM slots, but i'm not giving that away.
    A working TV? How boring!
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      I have a 30 pin simm
      on my keychain
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        That was such a 90's thing.....hahaha
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • villiam
          • Jun 2012
          • 16
          Hi logistics, you might find this interesting. Remember Commodore Amigas? Believe it or not a German company individual computers is producing new accelerator cards for these machines today! The CPUs run at comparable speeds to the original 80s/90s expansion cards, (~25-48 MHz), but boast ~30% performance boost due to using more modern SDRAM. Maxing out old machines is a lot of fun, if you're sick, you're not the only one.
          • BigTroll
            • Sep 2010
            • 1317
            • LAMBDA SOND
            My 1991 Macintosh quadra had 65MEGS of 30 pin ram not to mention 2 megs of video ram and built in 10base eithernet, was really ahead of its time. 25Mhz 68040 POWER!
            My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
            • larrymoencurly
              • Oct 2004
              • 960
              Some of these came with a junked motherboard. 70ns with parity, vintage 1991, chips vintage 1989 NEC brand, apparently a kit.
              Do old SIMMs ever have collector value? I saw some where each chip was in a metal can, and they were from IBM.
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                I remember getting the 56k modem in my sisters windows 95 computer to work after her fiance upgraded it to a massive 48M.
                I learned later she only went online to look at porn back then
                • tmwalsh
                  • Jan 2009
                  • 119
                  Simms with 30 pins? I remember 2114 individual 4k static ram chips with 16 pins. And they were expensive. And 4116 dynamic ram that could be swapped out and replaced with 4164's to quadruple the memory. I had an Atari ST that came with 512K which I bumped to 1Meg by piggybacking and running 'blue wire' CAS and RAS signals. Solder most of the pins to the original memory, and then jumper three {I think} pins that were bent upward and the wired to the GLUE chip ... maybe.
                  Thirty pin simms are too easy.
                  tom
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    In my digital applications class last semester (I'm an EET student at Purdue in New Albany, a freshman last sem), I got to wire an array of those using a discreet tri-state buffer IC in addition to one (and later, two) 2114 ICs.In a bit I'll post my report from that lab which includes schematics.
                    Edit- Attached the .pdf of the report.
                    Last edited by ratdude747; 08-02-2012, 10:01 PM. Reason: Forgot that the 74LS148 was only in the stuff we did "on paper."
                    sigpic
                    (Insert witty quote here)
                    • lauren
                      Lurker
                      • Jun 2011
                      • 22
                      ^ With your report, it has your name on it. Not sure if you want to fix that or not.
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        No problem. I have similar documents uploaded on the site already and I have not had trouble. It's not like my email is in the document as well.
                        sigpic
                          ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                          This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-12-2024, 03:28 PM
                        • CG2
                          Janome DC3050 Sewing Machine Pedal Resistance
                          by CG2
                          OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                          Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                          04-14-2023, 07:53 AM
                        • Soulzink
                          Samsug washing machine. Power supply DC41-00189a board issue
                          by Soulzink
                          I am trying to fix a samsung washinmachine power supply main board.
                          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                          The power supply board reference is the following: DC41-00189a
                          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                          04-19-2025, 06:26 AM
                        • unimatrix93
                          How to stabilize AC voltage to CNC machine
                          by unimatrix93
                          Hello there everybody, I'm not sure if it's the right topic to ask this but I hope so.
                          I have a CNC machine wired to 3-phase 230V AC.
                          It's a smaller CNC machine with a 3500W motor, do it does not uses much power.
                          The problem is, when the residents come home and put load on the network, the voltage can drop to around 207V which is fine for most household items but by CNC machine stops working from this.
                          I contacted the electricity company but they refuse to help me solve this problem.
                          So I started to look around for some DIY...
                          03-17-2025, 05:52 AM
                        • xdever
                          820-01700 not booting, 4V PP2V5_NAND_SSD0 but 2.5V when the machine is off.
                          by xdever
                          I got a 820-01700 of a friend that doesn't turn on. I read that a typical issue with these boards is the TPS62180 generating the NAND voltages, so this is where I started looking. Sure enough, PP2V5_NAND_SSD0 is 4V when the machine tries to turn on (I try to determine this by measuring PP2V5_NAND_SSD1, which is 2.5V as it should in this case. The PP0V9_SSD0 and PP1V8_SSD0 power supplies for the SSD are on at the same time when PP2V5_NAND_SSD0 is 4V). The extremely weird thing is that when the machine is off (PP2V5_NAND_SSD1=0, PP0V9_SSD0=0 and PP1V8_SSD0=0), PP2V5_NAND_SSD0...
                          01-15-2025, 08:44 PM
