Test CPU without damaging motherboard?
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    OK so somebody gave me an Intel Q9300 CPU:
    http://ark.intel.com/products/33922/...333-MHz-FSB%29
    But he claims that it's broken because he was doing some sort of voltage mod and it got shorted.
    He's like "you can have it but don't kill your mobo"
    i found this http://www.hothardware.com/articleim...42/small_3.jpg mine is missing the 4 tan thing in the middle and one of the blue thing... is that bad?
    I've got an ECS/Elitegroup motherboard, that IIRC supports 1333 Quad cores.
    Can I test the CPU without risk of mobo damage? How do I fix the CPU?
    I really want this to work,
    thank you!
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Test CPU without damaging motherboard?
    Originally posted by shovenose
    ... How do I fix the CPU?
    dude, once the CPU is shorted, its gone forever!
    -Ben
    Muh-soggy-knee
    • dumpystig
      • Jul 2011
      • 485
      You may as well go suck eggs as try and 'fix' a CPU shovey. If I were you I'd just install it in the mobo and see what happens - keep your fingers crossed it doesn't end up going
      System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFP
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        fixed.
        yeah, when its shot, its shot. not fixable. Trash (unless you need a socket protector for board storage).
        sigpic
        (Insert witty quote here)
        • dumpystig
          • Jul 2011
          • 485
          Didn't see that one ratty, yet it's right above the one I used????
          • c_hegge
            • Sep 2009
            • 5219
            Just stick it in that ECS board of yours. It's a few years old now, so it's gonna die in a few months anyway.
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              Just because I can't afford a $500 Gigabyte motherboard doesn't mean my $40 ECS board is crap! I haven't had a single issue, and it runs great under high load for about 12hrs/day (SMP F@H)...
              • shovenose
                Send Doge Memes
                • Aug 2010
                • 6575
                Could it kill my motherboard?
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5042
                  • US
                  of course, i've seen it happen
                  I saw my dumbass ex-boss try to upgrade an old HT P4 sony by putting a pentium dual core inside it...I told him P4s run with higher voltage and it might not work.
                  silicon burning smell next. a quick 'told you so' followed
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    Oh I've put my Core 2 Duo E6600 that's currently in the ECS board in about 3 different P4-only boards, wondering why it doesn't work, until I realized the chipsets dont' support it.
                    Neither the CPUs nor the boards were toast, though!
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      The "tan things" are ceramic caps. Most of the time, those are there to filter high-frequency ripple going to the CPU so the CPU may actually still work without them (but maybe not very reliably). I'm not really sure what the "blue thing" is - I would guess a resistor most likely... and very likely the CPU won't work right without it (and by that, I mean it probably won't get recognized by the board, assuming that it hasn't been damaged in any other way).
                      As for whether or not this CPU can damage your board - I'm not quite sure.
                      If your board supports quad cores, then I would guess most likely not. Normally the PWM controllers for the VRM MOSFETs have the option to shut down if they are overloaded. But who knows if ECS actually decided to use that option.
                      • Uranium-235
                        Comrade Glimmer
                        • Aug 2007
                        • 5042
                        • US
                        of course a cpu can damage a board, not necessarily one will
                        there could be a direct short between the vrm and something hooking to the northbridge
                        • shovenose
                          Send Doge Memes
                          • Aug 2010
                          • 6575
                          This is an odd choice:
                          1. Put it in and see if it works,. Pros: could have a working free quadcore Cons: killed mobo
                          2. Replace resistor, then do option #1
                          3. Toss it. Pros: no risk on motherboard Cons: missing out on quad core epicness...
                          What do y'all think, should I do it?
                            master hoarder
                            • May 2008
                            • 12175
                            • Bulgaria
                            There's also option 4...
                            4. put the CPU on a shelf and wait until you get a better or more crappy board than your current one. If it's better, move your Core 2 in that and use the ECS to test the quad. If it's more crappy - well put the quad core in it and see if it blends .
                            • shovenose
                              Send Doge Memes
                              • Aug 2010
                              • 6575
                              Too impatient for option 4, even though that's a very good idea
                              That's what I might end up doing...
                              Anybody want to test a CPU for me?
                              :P jk
                              • shovenose
                                Send Doge Memes
                                • Aug 2010
                                • 6575
                                I've circled in red the missing components.
                                • c_hegge
                                  • Sep 2009
                                  • 5219
                                  ...I can't afford a $500 Gigabyte motherboard
                                  That's what MSI are for
                                  doesn't mean my $40 ECS board is #@*&. I haven't had a single issue, and it runs great under high load for about 12hrs/day (SMP F@H)
                                  My experience with ECS has been very different to yours. I tried a couple out for myself a few years ago, and they both died after only 6 months. At work, they don't show up particularly often in PCs, but when they do, they are usually dead. With Gigabyte, nearly every second computer I work on has a gigabyte board, but I still see just as many ECS boards go in the bin as Gigabyte. I don't see that many MSI or Intel boards in the bin either. I used an MSI board in My grandma's PC (socket A). It's still going strong to this day.
                                  Back on topic, I'd say go with options 2 and 4.
                                  • smason
                                    • 1652
                                    Yup, confimed. Those are "tan things" alright!
                                    Hey, if you can write your own browser, a few "tan things" are hardly a challenge.
                                    A few more smileys just so you know I'm just messin with you.
                                    • shovenose
                                      Send Doge Memes
                                      • Aug 2010
                                      • 6575
                                      lol
                                      • shovenose
                                        Send Doge Memes
                                        • Aug 2010
                                        • 6575
                                        Well, I tried it in my other S775 PC (Dell Optiplex 745) that usually Beeps and makes a loud fan noise when you stick a 1333 FSB CPU in (I've tried)...
                                        anyway, it smelled like shit and didn't even beep...
                                        I was afraid I fried my mobo but I put a Pentium Dual Core back in and it's fine... (I didn't want to put the E6600 in again in case it would kill the CPU...
                                        Result: bad CPU, no mobo damage!
                                        • glovecaps
                                          Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                                          by glovecaps
                                          I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                                          My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                                          The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                                          11-25-2024, 04:23 PM
                                        • Docus
                                          Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                                          by Docus
                                          Hi everyone 😀,
                                          I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                                          To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                                          Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                                          1. I already own the exact same model, but its plastic chassis is badly damaged.
                                          06-10-2025, 04:24 PM
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                          ASUS P5GC-MX motherboard recap
                                          by momaka
                                          Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                          This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                          So here is what the motherboard looked like with its original caps:
                                          CPU VRM area up close…...
                                          01-27-2021, 11:59 PM
                                        • Mess
                                          Motherboard diagnostic beginner advice
                                          by Mess
                                          To save you some time: the most important bits are in bold.
                                          Some further examples/explanations or to the side & in grey - you can probs skip them if it's TLDR for you. Sorry, I've got ADHD & tend to over-explain stuff - just like I'm doing right now 😅 Briefness is for poets not me 🙈
                                          Please help!! 🎶I'm just a girl in a world that wants to scam me out of lots of money for any tech stuff/repairs 🎵 Seriously tho, I'm poor&I can't afford to get laptop diagnosis, especially if it ends up needing a new motherboard. Where I live, all the tech shops are run by very...
                                          09-12-2024, 07:02 PM
