LCD monitor backlight
  • stevo1210
    • Oct 2006
    • 4156
    I have a question about the CCFL backlight found in LCD monitors. I have two HP L1950 LCDs which I am using in my dual monitor setup. I got these second hand a while ago and they've been great LCD monitors overall, haven't had a problem at all with them.
    A few days ago (after months of use) I discovered that when you go to "information" in the OSD, it tells you the back light hours. The main monitor (1) has 3200 hours on it, the secondary monitor (2) has 4590 hours on it. Now I don't see a problem with these displays AT ALL. Colour is great and they aren't dim though I will say that the LCD with higher back light hours is slightly dimmer and a tiny bit more yellowed in colours than the latter as expected due to the hours difference.
    But then I was looking up this stuff since I'm getting interested in this "backlight hours" feature, but then to the death of all glory, these CCFL bulbs only last 5000 hours and then die?
    I did the maths and worked out that if an LCD is left on 24/7 (which many are), that's about 7 months straight 24/7? I've seen LCDs in workplaces and shops even older than these stay on 24/7 for more than 18-24 months without a problem. :S
    Can someone enlighten me on this stuff? (not in the mood to get new displays... yet).
    On a side note, I ALWAYS buy my IT stuff second hand for peanuts because I don't see the point of buying brand new or current top of the line etc. if all I do is browse the net and watch Youtube.
  • stevo1210
    • Oct 2006
    • 4156
    Re: LCD monitor backlight
    Anyone?
    • c_hegge
      • Sep 2009
      • 5219
      Only 5k hours doesn't sound right. if that twas the case, I'm sure I'd be seeing a LOT more dead LCD panels than I do.
      • b700029
        Banned
        • Sep 2010
        • 640
        Unless there has been catastrophic failure (loss of vacuum/filling gas, broken electrode) CCFL do not suddenly stop working unlike incandescent lamps. Typical lifetime is 50K hours to 50% brightness.
        • Krankshaft
          • Jan 2007
          • 2328
          I've got at least 12k backlight hours on most of my HP 1955s and they don't seem dim or yellowed at all.
          Check the color temperature function in the OSD. On my monitor I can adjust the intensity of red, green, and blue or use Kelvin presets which adjust them for me.
          5k is nothing for a CCFL.
          • lti
            • May 2011
            • 2558
            I think the 5000 hour lifetime is listed in the specs so people will freak out and buy a new monitor after that time period.
            • gdement
              • Jan 2007
              • 690
              It's been a long time since I looked into it but I believe the operating brightness makes a huge difference in the bulb's lifespan. I always keep my backlights pretty dim, I don't see the point running them really bright. That makes them look good in store displays but it's not necessary. At most, it might take a few minutes to get used to the dimmer setting, then you won't notice anymore.
              I just checked - my main desktop LCD is on 0 brightness. I used to have it on 15% but I changed to 0 when there was a power outage. I never remembered or cared to change it back. It looks normal to me.
              I bought a twin of this monitor on ebay 2 years ago, it was noticeably a bit discolored compared to mine. When I checked the hidden menu they both had almost identical POH.
              I saved pics of this so I just looked it up:
              My original monitor was at 16.4K POH, 89K panel cycles
              The ebay monitor was at 16.8K POH, 34K panel cycles
              The previous owner probably had it on factory default brightness, while I had been using 15%.
              Mine is now up to 28K POH, and I'm pissed off because I just accidentally RESET the damn thing. Shit.
              • lti
                • May 2011
                • 2558
                There are a lot of people that run their monitors at 100% brightness and throw a fit if you turn the brightness down to 99%. This seems to place a lot of stress on the backlight inverter as well as hurting my eyes and making the CCFLs wear out more quickly.
                The CCFLs might only last 5000 hours at full brightness in some monitors.
                • Dammon
                  Ensign
                  • Jun 2010
                  • 36
                  I'm running my monitor at 30% and that's plenty bright for me. At higher brightness levels, there's some noticeable backlight bleeding at the edges.
                  • DanPoka
                    by DanPoka
                    02-15-2025, 05:05 AM
                  • Zilicon
                    NEWSYNC B27F165 MONITOR HAS NO BACKLIGHT. board no: JY85QS_UPH_LS_R10.3
                    by Zilicon
                    Greetings everyone.
                    Please I need help with the above monitor.
                    Below is the summary of what happened and what I have done:
                    The monitor started by turning off 2 seconds after it was turned on. It displayed with a backlight when it turned on. However, the standby light remains on after it is turned off on its own, I have to press the power button again to turn it on, but it will go back to standby after 2 seconds.
                    The backlight driver IC is 0b3350cp.
                    I applied a 370k SMD resistor on the CMP pin which is pin 6, while the other...
                    11-07-2023, 09:12 AM
                  • turmix
                    AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                    by turmix
                    Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                    The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                    At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                    During another reassembly, I made a mistake, and...
                    01-29-2024, 03:48 AM
                  • keepread
                    Dell monitor PSU vs Dell laptop PSU
                    by keepread
                    Hi there!
                    Someone gave me their old monitor, it's Dell S2715ht.
                    The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                    Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                    10-30-2025, 04:45 PM
                  • Chiro
                    DIGMA PRO Art M Monitor 5K IPS 60hz only backlight
                    by Chiro
                    The monitor has no visible external damage and has not been dropped. Currently, the backlight is on, but no image is displayed. I have replaced the power and HDMI cables, and connected it to my laptop (the graphics card detects the monitor, but no image appears). The service menu is also unresponsive. Could anyone share insights on troubleshooting or repair options for this issue?
                    07-06-2025, 02:21 PM
