New bluescreen message...
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    So i just set my main monitor here on the dual-PIII to 1400x1050. Like so.
    I shut down the computer and went to the beach, had a few with my friends, then back to the hood, had a few more , and finally back home. I turn the computer on to find a blue screen, PAGE_FAULT_IN_NONPAGED_AREA. I restart it only to find another one, IRQL_NOT_LESS_OR_EQUAL. Now, i know those screens are usually caused by overclocking, and i am overclocking, but it's been perfectly stable so far. So wondered if the problem was caused by my recent resolution change.
    I rebooted in VGA mode, and sure enough, no BSOD. However i couldn't enable the second screen after the VGA mode reboot, so i set the resolution to 1280x1024 on the main and rebooted again. Sure 'nuff, worked fine. I've set the main monitor to 1400x1050 again and disabled the second screen. I wonder if it'll boot fine tomorrow...
    So i propose a new designator for bluescreens: MAXIMUM_RESOLUTION_REACHED
    A working TV? How boring!
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: New bluescreen message...
    PAGE_FAULT_IN_NONPAGED_AREA = Unstable RAM. (May be a bad RAM slot.)
    IRQL_NOT_LESS_OR_EQUAL = Unstable core. (You can get this error when Linpack fails.)
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • lti
      • May 2011
      • 2551
      I have seen two "new" BSODs. On one, the screen halves had been switched around (right half on the left side of the screen, left half on the right side). On the other, the computer crashed with several errors at the same time. I watched the text scroll up the screen for a second before it finally stopped. There was also one section of text that appeared twice - once near the top of the screen and once again just before the only visible STOP error code (0x000000c5). There were also sections of text that normally only appear in the IRQL_NOT_LESS_OR_EQUAL message. I would guess that there were at least five errors at the same time.
      • toastygoodness
        • Jul 2005
        • 813
        I get those even though I know my RAM is definitely stable (couple days of Core Damage and Memtest). I just have faulty drivers for gfx and audio interface on one install (something's messed up). I would just check your drivers. If you know your oc is good, then it may be your board. What gfx card do you have?
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          It had nothing to do with the board or RAM. It had purely to do with the resolution and the desktop arrangement - i use EnTech iRotate to get a secondary 17" LCD in portrait mode, because the video driver doesn't have this option by itself. Without the secondary monitor enabled the system booted just fine.
          The video card is a Radeon 9800 Pro 256MB but that's soon to be changed for a HD4650 or 4670. I'm using Omega drivers.
          • RJARRRPCGP
            • Jul 2004
            • 6304
            Looks like the CPU has gotten stable, those look like processor-related errors,
            usually when you OC the core too high or require a Vcore bump.
            Arc A770 16 GB
            • RJARRRPCGP
              • Jul 2004
              • 6304
              I had back luck with those, the first one I got second hand was fine at first, but when I wasn't even in Windows, gave corrupted video and then when I rebooted, also a corrupted BIOS screen!
              And sometimes, moving it around helped! Suspect it's a solder joint problem,
              I have a gut feeling that it could be.
              But, it was junked a long time ago, that was in spring, 2007.
              And I did almost make a 3D Mark test! It seemed to be fine if it didn't even get moved by a 32th!
              It works fine intermittently!
              Could this be a bad BGA solder job?
              Arc A770 16 GB
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                Mine was bought second hand too, but i've had it for several years. It's also overclocked and voltmodded... i am using aftermarket cooling though.
                It sometimes displays a colored dot or two when i'm watching a movie and the scene is very dark. It could do with some ramsinks, but i always forget. Otherwise, it's never been trouble.
                • toastygoodness
                  • Jul 2005
                  • 813
                  Yep, definitely graphics driver issue then, since you are using Omega+iRotate. It's probably out of spec for the driver or something, something is making it throw a fit. Since you're going to upgrade anyway, might as well just hold out and start fresh with your new gfx card. Is iRotate the same thing as Powerstrip?
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    iRotate is from the makers of PowerStrip, yes. All it does is handle rotation, but compared to the whole package, iRotate is free. And most of the features in PowerStrip i have in ATi Tray Tools anyway, i don't want to run them both at the same time.
                    • lti
                      • May 2011
                      • 2551
                      That computer worked fine after updating the BIOS. There was a bug that caused Windows to crash on a cold boot with a random BSOD or a message saying a certain file was missing. When Windows finally booted, there was the chance that it would crash after running for a few hours.
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        Kind of sounds like my issue with my Core 2 Duo E4500 OC, with load line calibration disabled,
                        it will fail to POST on a cold boot and I have to turn it off then back on again.
                        Even during this, it was stable when in Windows and Linpack passes.
                        It seems to be related to not having enough juice to start the E4500.
                        Arc A770 16 GB
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          http://technet.microsoft.com/en-us/l.../cc957625.aspx
                          http://msdn.microsoft.com/en-us/library/ms854226.aspx
                          When you get both at the same time it's almost always bad RAM or a corrupted driver [or system file] that doesn't load right into RAM.
                          Sometimes it's a buggy program that can't keep track of where it puts things in RAM.
                          Mann-Made Global Warming.
                          - Dr Seuss
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5042
                            • US
                            I had that bluescreen when I had the latest radeon driver on a AMD 785 chipset (showed up as a the radeon designation on the device manager), I installed the driver from the MB manufacturer (showed up as AMD 785 on the device manager) and it was never a problem
                            lately the latest radeon driver that designates the integrated vga as its radeon equal has been working just fine, even played max payne 2 on this 880 I built for a customer of mine
                            • mockingbird
                              • Dec 2008
                              • 5484
                              Omega still makes drivers?
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                http://omegadrivers.net/ Latest ones are dated just a few days ago, so the answer is yes. The 9800 runs on an oooooold version anyway, as ATI dropped support a few years ago.
                                • mockingbird
                                  • Dec 2008
                                  • 5484
                                  Last known good driver for my 2900XT is 11.3.
                                  There was series of drivers up untill 11.2 which caused ati2dvag BSOD with the XP drivers and my card, plus older OpenGL games like Jedi Outcast and Academy (Thus including Movie Battles II, which brings my Dual core Athlon 64 and 2900xt down to their knees at 1280x1024 - not bad for a game that runs on a heavily modified 10+ years old Quake3 engine) would crash when they were launched.
                                  11.3 is a bastion of sanctity, sanity, and stability. Anything newer now gives me ati2mtag BSODs.
                                  I've not tried the new 11.7 (Though I think I tried the RC which also gave me BSODs) but I've reached the conclusion that ATI's XP drivers are NOT really UDA (Unified Driver Architecture) to the same extent as nVidia's drivers. If enough people whine sufficiently on their Catalyst forum about the same problem, they *might* fix it (Like we did with Jedi games not working - and they fixed it to their credit). But they are really negligent when it comes to fixing driver issues with older cards. Like when I swap displays from my TV and LCD, under no circumstances will Catalyst remember the resolution of my LCD and forces me to use 1024x768 until I change it manually. Very inconvenient.
                                  Incidentally, I am using the 266.58 nVidia driver for a relatively old GeForce 6600 in XP (And FYI, eventhough nVidia is claiming support for this card in their newer drivers, I can confirm that this is the last driver version that will work at least for the GeForce 6 series in XP).
                                  • hardwareguy
                                    • Jun 2006
                                    • 405
                                    IRQL-NOT_LESS_OR_EQUAL is almost always a driver issue unless you are overclocking. Try uninstalling your video driver and updating to the latest version. Update the chipset driver as well...this is vital on non Intel AGP systems.
                                    PAGE_FAULT_IN_NONPAGED_AREA can be bad RAM, a bad HDD, or a bad driver stepping on some memory it shouldn't have.
                                    • Th3_uN1Qu3
                                      Believe in
                                      • Jul 2010
                                      • 6031
                                      • Romania
                                      The interesting bit is that it was an one-time thing - i have been booting with both monitors enabled for the past few days and it's been working fine.
                                      • mockingbird
                                        • Dec 2008
                                        • 5484
                                        Get rid of those Omega drivers...
                                        I don't know what gave you the idea that they're only a few days old... His main page links to ATI drivers, not his own. His actual driver download page only shows two drivers, the XP one dating back to December 2007.
                                        I'm sure you can do better than that.
                                        • rumpumpel1
                                          T490 error message 2203 Skip acknowledgement of an error message
                                          by rumpumpel1
                                          I have a T490 that displays the error message “2203: System configuration is invalid” immediately after the Lenovo logo every time it boots up.
                                          This message must be acknowledged with 'Esc'. On the one hand, I cannot eliminate the problem, on the other hand, I have not observed any other restrictions.
                                          Is it possible to change the BIOS so that this message no longer has to be acknowledged?
                                          MTM 20N3S19L00
                                          system SN PF1X4JP8
                                          board SN L1HF171000X...
                                          01-19-2025, 03:32 PM
                                        • Scruit
                                          Does the Oak OTI067 have a splash screen / initialization message at bootup?
                                          by Scruit
                                          tl;dr ... Question: Does the Oak OTI067 have a splash screen / initialization message at bootup?
                                          More detail:
                                          Working on "Uncle Sherman", my Mitsubishi MP-3200 386 from 1988. Before I start up old computers I have a process where I disassemble, test for shorts, visually inspect, capture EPROM images etc.
                                          My T866II+ give me a "pins not detected" error on the EPROM from the Oak-based (OTI067 GPU but apparently a no-name card??) I assumed the EPROM was bad, ordered a replacement and figured I'd program a downloaded ROM image to it....
                                          04-17-2022, 06:03 AM
                                        • ArtMov
                                          [HELP] Asus g732lv ami bios overclocking lock reseting after reboot
                                          by ArtMov
                                          Hi guys, i have a problem , my bios resets disabled overclocking lock setting to enable after reboot, please tell me which function can be responsible for restoring the stock config for this option, loading parameters from nvram and so on, like bios ,protection, from asus. My bios made me angry) Set default parameter to disable in amibcp 5 , doesn't help(
                                          1. I made overclocking lock disabled the default in amibcp
                                          2. I changed the varoffset to the wrong one, but it led to the programmer, it was very tedious and nervous, I really regretted it, my chip is on the back of the...
                                          03-31-2023, 01:30 PM
                                        • Francesc V.
                                          Technics SA-AX530 in protected mode. Overload message
                                          by Francesc V.
                                          I got a request from a friend of mine to have a look to his amplifier. When switching on "OVERLOAD" was displaying, however from time to time, message disappears and protection was removed.
                                          I took some time in visual inspection (no bold caps, no solder joins, no burnt components neither hot burnt areas). I took some time to measure transistors and diodes. Everything seemed ok.
                                          I realized that when OVERLOAD was on, pin 13 on IC601 (RSN307M44A-P) measured 5V. From time to time, when Amplifier was not protected pin 13 measured the right -1.5V
                                          (Pin 13 goes through...
                                          11-18-2024, 12:39 AM
                                        • tcpip
                                          IdeaPad 5 15ARE05 Possible BIOS message and doesnt boot
                                          by tcpip
                                          My Lenovo IdeaPad 5 15ARE05 only 2 years old shows this message when I start it:
                                          BIInializeLibrary failed oxc0000185
                                          then it doesnt boot and i have shutdown by holding the power button
                                          I did goodle but canot undertand what is wrong and where to start. I have reset bios and also upgraded to newer bios but it didnt make a difference.
                                          sometimes it boots to wondows but very often I it get the above message?
                                          03-19-2023, 10:18 AM
