Does the Oak OTI067 have a splash screen / initialization message at bootup?
  • Scruit
    • Apr 2022
    • 12
    tl;dr ... Question: Does the Oak OTI067 have a splash screen / initialization message at bootup?
    More detail:
    Working on "Uncle Sherman", my Mitsubishi MP-3200 386 from 1988. Before I start up old computers I have a process where I disassemble, test for shorts, visually inspect, capture EPROM images etc.
    My T866II+ give me a "pins not detected" error on the EPROM from the Oak-based (OTI067 GPU but apparently a no-name card??) I assumed the EPROM was bad, ordered a replacement and figured I'd program a downloaded ROM image to it.
    When it got time to try to fire up the PC for the first time I used a Trident TVGA8900D, which gave me the ROM splash screen / initialization message. Then RAM test, KBD error and FD error (those aren't plugged in yet) All looked good.
    For poop and giggles... I mean "completeness and due diligence"... I put the Oak card in. It also fired up and POSTed, but I don't get any splash screen / initialization message from the card. First thing I see is RAM test, etc.
    So either the card supposed to have an initialization message, and its absence is a symptom of the bad EPROM... (doubtful, tbh) Or there is no splash screen, the card is fine, and my EPROM reader and that particular EPROM are just having "personality clash". (my theory)
    Thoughts?
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
  • Chrissygizmo
    by Chrissygizmo
    02-10-2025, 12:33 AM
  • spice_disc
    Vizio TV M50-C1 reboot cycle and static on screen
    by spice_disc
    I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
    The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
    09-08-2024, 02:37 PM
