[HELP] Asus g732lv ami bios overclocking lock reseting after reboot
  • ArtMov
    • Feb 2023
    • 7
    • Armenia
    Hi guys, i have a problem , my bios resets disabled overclocking lock setting to enable after reboot, please tell me which function can be responsible for restoring the stock config for this option, loading parameters from nvram and so on, like bios ,protection, from asus. My bios made me angry) Set default parameter to disable in amibcp 5 , doesn't help(
    1. I made overclocking lock disabled the default in amibcp
    2. I changed the varoffset to the wrong one, but it led to the programmer, it was very tedious and nervous, I really regretted it, my chip is on the back of the board , after flash bios the problem remained
    3. disabled the runtimevariable protection .
    I suspect that there is some kind of function, shit here ,which loads the value ,enabled, exactly for overclocking lock from nvram, it really infuriates me, every time you start the laptop you need to go into bios and disable ovrclocking lock (
    The most interesting, bios guard , writing security , cfg lock , fprr are not resetting, only overclockong lock.
    I'm praying for someone to help with this..
  • cr4zychriss
    by cr4zychriss
    • Rebrand: PC Specialist
    11-14-2025, 04:04 PM
  • sssssssssssssss
    Need BIOS for HP Pavilion 15-n058sr recovery - Caps Lock blinking twice
    by sssssssssssssss
    I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
    Symptoms:
    • Laptop powers on but no display at all (completely black screen)
    • Caps Lock blinks twice with a pause, then repeats continuously
    • F12 LED stays on permanently
    • No POST, no boot sequence, nothing on screen
    Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
    What I've tried:
    • Hardware reset (battery removal, power
    09-04-2025, 06:45 AM
  • haitham sharabati
    by haitham sharabati
    Hello engineers šŸ˜€,
    I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.šŸ˜
    šŸ”§ Device Info:
    - Model: HP 15-da2007ne
    - Product Number: 8XF55EA#ABV
    - Serial Number: CND0338P0D
    - CPU: Intel Celeron N4000
    šŸ’€ Problem:šŸ˜…
    - Device shows ā€œAdministrator Passwordā€...
    08-07-2025, 04:54 AM
  • pirati
    by pirati
    10-27-2025, 04:20 PM
    by Vesko356
    08-11-2023, 03:27 AM
