Hi all again,
I'm trying to migrate from my PIII setup to this dual athlon XP, using Iwill MPX2 mobo. I'm sure I have seen a huge thread somewhere here about this board having some problems with Ati Wonder cards and so, I recall Topcat being the originator, but anyways, I have a problem with it.
I have two of these, one is v1.3, second 1.5 - both display similar behavior. When I turn the computer on, it turns off after a few seconds...can do this all day, no change, only the v1.5 holds on for a minute or so, then turns off, or does the same as the v1.3. I'm using AthlonMP 2600+, which has a 16x multiplier, which may be a problem, no? Max for this mobo is 15 (at 133FSB). I tried using single or both CPUs, I do have a EPS12v compatible power supply, tried even that, nothing changed, still does the same. Power supply is a Fortron Epsilon 700W.
PLEASE HELP
PLEASE HELP
