Iwill MPX2 won't boot
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Iwill MPX2 won't boot
    166 is enough, i think my CPUs won't go that far, they are the 1.4 gig after all... Just a question, does it have PCI locks? Coz otherwise i can't see how you did 173 with it.
    A working TV? How boring!
    • Shodan486
      • Nov 2009
      • 203
      If you mean you have your 1,4gig tualatins, you may use only one and even for that one you need that converter for voltage adjusment. Tualatins work with FSB VTT at 1.25V, Coppers work at 1.5V I reckon and the VP6 is the 1.5V one...it's the AGTL operation that clearly specifies which bus to be used with which CPUs.
      PCI bus is not locked and yes, the board works flawlessly because Abit understood only certain hardware MIGHT work with such high value of frequency - approx. 43MHz, thus they did not bother fitting the board with LAN, Audio and stuff (of course BIOS provides the Enable / Disable function, but why to make an OC board more expensive). Everest clearly stated the value to be true, so yes, it is possible to run it still at this level of stress. VIA Vectro USB2.0 / Firewire PCI extention card and Realtek 8139D are used in this system alongside with the AGP 7950GT, which runs OC'd at the AGP bus (86MHz) and is OC'd itself, GPU from 500MHz to 625MHz - no problems.
      Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        The AGTL thing wouldn't be a problem, it can be modded. However i'm quite certain my SATA controller will not run at 43MHz PCI, so for now i'll pass. And i need onboard LAN at the very least.
        • privato89
          Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
          by privato89
          I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
          Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
          Let's begin:
          Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
          03-26-2024, 06:37 AM
        • Luke Anders
          Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
          by Luke Anders
          A few details about the laptop itself:
          Name: Lenovo Legion 5
          Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
          BIOS Version: GKCN60WW
          EC Version: GKEC65WW
          Serial Number: PF39AQ7Z
          Board Model: NM-D562 Rev 3.0
          RAM: 16GB Installed, DDR4 (brand new)
          NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
          I bought this laptop recently from eBay as a faulty device....
          10-12-2024, 05:13 AM
        • hinisa
          Xiaomi router freezes at boot after re-capping
          by hinisa
          I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
          When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
          After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
          Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
          07-08-2023, 05:58 AM
        • NolesFan
          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
          by NolesFan
          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
          10-24-2024, 06:36 PM
        • praveenramavath
          Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
          by praveenramavath
          Hello All,
          I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
          https://www.hifivision.com/threads/m...-screen.98243/
          Troubleshooting Summary: Majority Internet Radio - Flash Chip
          04-26-2025, 09:08 AM
