Hard Drive Swap - to clone
  • Daltex
    • Aug 2010
    • 5
    I bought 4 identical computers when setting up my network. One computer has bad caps and I'm waiting for the new ones to arrive to attempt to repair it. OS is XP pro.
    I need to put the data and functionality of the down computer back in the network asap.
    Would it be possible to just swap the hard drive out of one of the identical computers with the one I need?
    All of the searching I have done is returning questions about swapping to different setup computers or new HDD to existing computer.
    Thanks in advance!
  • digge
    • Apr 2006
    • 296
    Re: Hard Drive Swap - to clone
    As long as the hardware is exactly the same it shouldnt be a problem. In worst case scenario you get a bluescreen but nothing bad should happen to the contents on the disk.
    • Daltex
      • Aug 2010
      • 5
      I'll give it a shot. Thanks for the quick reply. I'll post back the result.
      • acstech
        GrumpyModerator
        • Jul 2007
        • 1432
        Windows might detect hardware changes and request to be reactivated. Or it might not. It depends on how many hardware changes it had previously. Other than that, if all the hardware is the same it should work.
        A man convinced against his will is of the same opinion still.
        • Daltex
          • Aug 2010
          • 5
          Thanks acstech- I may wait until I get the new caps and just leave the hard drives where they were. If the swap knocked out another computer, I'd be up a creek.
          Thanks for the advice!
          • Krankshaft
            • Jan 2007
            • 2328
            I believe XP uses the MAC address and some info from the bios to determine if it's the same PC. If those don't sync up it will ask you to reactivate. It may give you 30 days or it may not allow you to log on and require immediate reactivation before you can use the OS.
            If you have a Retail version it will reactivate on the new comp and deactivate the old comp you can do this as many times as you want.
            If you have an OEM version it's locked to the old machine and can't be used on another machine. That's why retail versions cost more than OEM versions.
            If it's a volume license as long as it's the same brand PC it won't bother you at all with activation. For example Dell had special XP Pro install discs which were volume licenses and only automatically activated (no need for an Internet connection) on Dell PCs.
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              if these are truely identical get 3 more kits.you will be better off to fix them at a time of your choosing rather than theirs.
              • Hondaman
                • Sep 2008
                • 1092
                A link:
                http://www.helpwithwindows.com/Windo...ctivation.html
                another link:
                http://aumha.org/win5/a/wpa.php
                Write down the Volume IDs for the various drives at the time you activate each copy (look in the partition table). You could even make the Volume IDs the same on every disk before activation, I suppose.
                I had to re-activate my 32-bit XP (online) when I turned on the RAID feature of my BIOS (I think that counted as a drive controller change). (Not sure why I did this, I don't use RAID.)
                I forgot to write down the Volume ID before I reinstalled 64-bit XP (twice in the last 6 months, same exact hardware) but I re-activated online with no problems.
                • digge
                  • Apr 2006
                  • 296
                  Usually reactivating even OEM isnt a problem. Just tell them you reinstalled it from the disk delivered with your computer. At least ive never had them turn me down at microsoft when calling them asking for activation.
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    The trick for OEM is your are allowed to replace the mainboard if it failed (not if you upgrade)
                    So if you need to call for activation remember to tell them your old mainboard failed and you got a new one on warranty or whatever
                    • Daltex
                      • Aug 2010
                      • 5
                      I think my new caps should arrive today so I think I will just recap the bad board and forgo the hard drive swap.
                      I really appreciate all of the input recieved of this project.
                      If my soldering skills are up to par, I'll recap the other 3 boards. I've already pulled the cover on one and the 2200/6.3's under the hard drive are bulged of course.
                      Thanks again and I'll keep you posted of the results.
                      BTW: If you are new to this recapping stuff- Badcaps.net is the best for getting your caps. Most excellent customer service!!
                      • federalhouse
                        **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                        by federalhouse
                        I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                        **Background:**
                        I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                        **What I've Tried So Far:**
                        1. I accessed
                        08-01-2024, 07:03 PM
                      • tmcw
                        PC case - Hard drive rails
                        by tmcw
                        A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
                        So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
                        I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
                        Now, the case is a CiT Gaming Case, and...
                        05-22-2022, 12:04 PM
                      • madura2010
                        DAY11AM6E0 hard disk drive and optical disk drive not detected
                        by madura2010
                        Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                        i checked the connectivity of ribbon=good communication with hard and motherboard
                        changed hard disk and checked=3f0 error persist
                        sata power=+5v available
                        Then checked data capacitors=all good
                        Then checked data lines path connectivity to pch=all good
                        reflashed...
                        03-12-2023, 09:09 AM
                      • ash91
                        Hp pavilion 15 not detect hard drive
                        by ash91
                        Hello gentelmen .... this is my first post and sorry for my bad english,
                        so my proplem is my laptop keep losing hard drive even if i but the
                        hard disk in the cady (the box that can replace the dvd rom with hard disk)
                        when i turn the laptop on the massage that said no boot media found pop on
                        the hard disk is fine and to be sure i try another hard
                        i also update my bios to the last update
                        the 5 volt is present on the hard connector on the motherboard
                        the dvd rom work fine when i but a windows dvd in it
                        also when i boot from flash...
                        06-07-2023, 01:45 PM
                      • karto95
                        Repairing a Seagate hard drive with damaged logic board
                        by karto95
                        I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
                        I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
                        If anyone has any suggestions or experience with this...
                        03-21-2023, 04:05 AM
