What are the 'actual' effects of old electrolytics in a vintage radio?
  • Crystaleyes
    • Sep 2021
    • 493
    • Brazil
    Hi all.
    Just trying to get a better understanding of electronics in general, and although I know that it can be general practice to replace any electrolytics in vintage gear, I was wondering 'what' are the effects from these failed components?
    I can see that a shorted cap acts as a short circuit and therefore a power drain, but what else might it cause?
    Similarly, an open cap won't be smoothing any signals but is there anything else?
    I'm sure this is basic 101 but I'm not at school, so just learning as I blow things up...
    Fortunately I'm blowing lots of things up
  • andrewsawesomr
    • Jun 2022
    • 101
    • United States of America
    Re: What are the 'actual' effects of old electrolytics in a vintage radio?
    From what I've seen, failing or failed Electrolytic capacitors can cause low or no audio output from the speaker.
    • Crystaleyes
      • Sep 2021
      • 493
      • Brazil
      Welcome to the forum
      Thanks for that. I suppose I should expect that from caps which are failing towards shorting.
      • lti
        • May 2011
        • 2551
        There are also caps in series with the audio signal, and those failing open or with high ESR would cause low audio. If they fail shorted or leaky, then they won't block DC anymore.
        I've also had bad caps cause stuff to sound really strange (like distorted sound with weak bass).
        • Crystaleyes
          • Sep 2021
          • 493
          • Brazil
          Cheers.
          I have repaired various easy-fix failed amps but as it is not my 'thing', I have never given it much tought.
          It only just dawned on me that it should be indicative from the symptoms as to what kind of capacitor fault is the cause.
          It's all helping
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            The easy one is "mains hum" (50/60Hz) heard through the speakers when the big filtering capacitors are failing.
            You can also have failure of frequency filters like in my post here, then it may make really really bad noises as lti said above:
            https://www.badcaps.net/forum/showthread.php?t=93004
            • Crystaleyes
              • Sep 2021
              • 493
              • Brazil
              Thanks for the info, but here's another question...
              There is the mains hum and all the caps have been changed. The two large outputs were originally 1000uF 25v and were replaced with 2200uF instead.
              Could this extra value be creating the mains hum?
              As a sidenote, only one channel is currently working, the other has a short, which as it turns out was the reason for the initial lack of volume.
              Before that channel was isolated, there was no hum...
              I suppose I'll find out soon enough once I find the short...
              • keeney123
                Lauren
                • Sep 2014
                • 2536
                This article is good at explain twisted pair and why they are use.
                https://audiouniversityonline.com/twisted-pairs/
                When I work for UMass I remember one of the professors showing me how to twist a pair of wires for a 100MHz ring counter that was used for capturing events in Physics Experiment at Brookhaven National Lab. It was done with a hand drill, and I remember the professor telling me that it created 128 Ohm impedance. The object was not to twist to tight or to lose. That was way back in 1981.
                  • 31084
                  a failed dc blocking cap in valve circuits can cause transformers to burn up from exess current flow
                  • desert-rat
                    • Mar 2014
                    • 4103
                    There a couple of YT videos on the different kinds of capacitors , why there used in that circuit , ect.
                    • Crystaleyes
                      • Sep 2021
                      • 493
                      • Brazil
                      Great information.
                      Thank you very much!
                      • Crystaleyes
                        • Sep 2021
                        • 493
                        • Brazil
                        Tbh I have never even heard of a 'blocking cap' but it is now catalogued in my subconcious archives.. So cheers.
                        This 'thing' is an old (1960's) Philips receiver/amplifier which is all solid state, so this won't apply right here.
                        Managed to get both channels working however the one that had failed is distorting.
                        Amongst other things, the channel had a failed germanium AC128 32v 1A PNP which I've replaced with a couple of different PNP's (to test) but that makes no difference.
                        Considering that all the electrolytics and a few ceramics have been replaced, then what else in a circuit might distort the signal?
                        Enclosing the section in question...
                        Any pointers are appreciated.
                          • 31084
                          if you have a stereo device you can find the fault by swapping parts between the 2 channels
                          • keeney123
                            Lauren
                            • Sep 2014
                            • 2536
                            I would make sure the transistor you replace for the germanium transistor is another germanium transistor. The characteristics of a silicon transistor is different and could very well cause distortion. Here is a link to explain that.
                            https://robertkeeley.com/2013/09/germanium-transistors/
                            • Crystaleyes
                              • Sep 2021
                              • 493
                              • Brazil
                              Very good point. I fact, it had dawned on me that I could compare the two channels' voltages, and had just finished drawing up a complete list of all the voltages from the schematic, which I can compare to the actual readings.
                              Seeing as it is highly possible that the silicon replacement for the germanium isn't helping, then that can easily be switched over to confirm, one way or the other.
                              • Crystaleyes
                                • Sep 2021
                                • 493
                                • Brazil
                                Just about to confirm that one...
                                • Crystaleyes
                                  • Sep 2021
                                  • 493
                                  • Brazil
                                  So...
                                  Using the same AC128 germanium on the bad channel resolved the problem...!
                                  It is not 'quite' as clear as the other channel, but I think once connected up, that only an audiophile would clock the difference.
                                  This receiver/amp goes into one of those cabinet/furniture art deco pieces with the multi-play record deck,which my gran used to have, so really, I doubt that at 31W max that it will even be noticeable.
                                  Famous last words.
                                  Thanks again for the input chaps... Even though I was aware of the audio heads preferring ge in older stuff, I had no idea that germanium or silicon affected the sound so much. Now I do.
                                  We live and learn!
                                  and... I'm gonna twist together both the input and output wires!
                                  • keeney123
                                    Lauren
                                    • Sep 2014
                                    • 2536
                                    So...
                                    Famous last words.
                                    We live and learn!
                                    It is important to keep those germanium transistors cool. Make sure the components around the transistor are with-in specifications. You do not want to overdrive those transistors any anyway. You also might check to see if you can locate a used one that maybe has no damage.
                                    • Crystaleyes
                                      • Sep 2021
                                      • 493
                                      • Brazil
                                      Thanks for all this advice. Most appreciated!
                                      Astonishingly, I found an AC128 in my components vault, down in the dungeon.
                                      Btw, these are the square ones with a hole through (photo), which enables them to fix to the large heatsink.
                                      All the nearby components are original, to spec, or as near as possible (i.e. the 1.6uF is now a 2.2uF and the 125uF is now 150uF). All the transistors are as specified in the schematic.
                                      The only components which I went 'off-piste' with were the 2 x 2200uF in place of the 1000uF main output caps, and a 100uF instead of a 64uF on the balance.
                                      As for the one channel quality. Turned out it is the cable which is bad, for when the connectors were switched the channel quality switched too.
                                      So, now after 30 years the record player and aux input are working, however the radio is still dead. There is a empty space where the decoder board went...
                                      Radio stations only play shit anyway!
                                        • 31084
                                        a cap that reads higher uF than it's marking usually indicates it's internally failing.
                                        the internal electrical leaking fools the cap meter.
                                        • UserXP
                                          Vintage SONY Digital Clock Radio ICF-C12W no audio
                                          by UserXP
                                          Dear all,
                                          I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                                          i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                                          My question is, do you know of this brand of capacitors and how bad are...
                                          07-21-2025, 08:35 AM
                                        • shelby5041
                                          clock radio / radio lifespan?
                                          by shelby5041
                                          hi
                                          ive got a modern digital clock radio approx 15yrs old
                                          my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                                          since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                                          the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                                          it uses very little power just a few watts i would imagine that may have something...
                                          09-14-2024, 03:30 AM
                                        • praveenramavath
                                          Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                                          by praveenramavath
                                          Hello All,
                                          I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                                          https://www.hifivision.com/threads/m...-screen.98243/
                                          Troubleshooting Summary: Majority Internet Radio - Flash Chip
                                          04-26-2025, 09:08 AM
                                          HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                          09-12-2024, 02:00 PM
                                        • Omron
                                          Kenwood KDC 3051G Car Radio permanently stuck in Demo Mode please help
                                          by Omron
                                          Hello Guys! I have trouble with my car radio Kenwood KDC 3051G I hope someone more knowledgeable can help me, I tried everything in my power that I stumbled upon online.
                                          My radio is permanently in demo mode, it says Press Volume Knot Cancel Demo and when I press it nothing happens.
                                          - Tried to unplug radio and plug it back in into power,
                                          - Tried to reset radio by holding reset button key for 5,10,30 seconds while in power and without power, plugging it back in, it wouldn't work.
                                          - Tried to hold 3,6 while turning it back on and then pressing 1,2...
                                          05-23-2024, 01:27 PM
