foxconn capacitor issue
  • dirtyrider
    • Jun 2009
    • 4
    hi guys
    this is my first post so hello to all,
    i have recently purchased a motherboard on ebay which was "new", when i recieved it i noticed that one of the capacitors was knocked to the side, now i sent the pic of it to foxconn and they said return motherboard which will leave me down 50 pound sterling because of postage, more than cost of board.
    the capacitor says on it 6I 100 16v, so is this a 100uf 16v capacitor.
    also foxconn states on there x38a board that the capacitors are solid so what type do i need to buy and do you know where i can get hold of one.
    im sorry for asking so much but i dont have a clue, i can solder which is why i want to replace it but just dont know what to replace capacitor with.
    thanks for any help any of you guys/gals can give.
    cheers
    steve
  • dirtyrider
    • Jun 2009
    • 4
    Re: foxconn capacitor issue
    hi guys
    here is a pick of the capacitor
    thanks
    steve
    • linuxguru
      • Apr 2005
      • 1564
      It's a polymer, but I'm not sure which manufacturer. Hopefully not a SACON or similar...
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        Did the legs of the cap break off? They are just fine if they are just bent.
        • dbs
          • Feb 2009
          • 35
          http://search.digikey.com/scripts/Dk...me=565-3053-ND
          if it is broken this one should be a match - .98 plus shipping
          edit: sorry looks like you are not in US - not sure of source but the part number should still be useful - if you are not in a hurry maybe someone could add one of these to their regular order for you and save some of the shipping?
          • dirtyrider
            • Jun 2009
            • 4
            hi guys
            thanks for the reply
            the leg did not break off it is just bent to one side and it is still attached, i think the leg that goes into the capacitor has pulled out from it a bit, i dont know if it is faulty or not because i dont know how they really work.
            it is very firm to the touch and i wrote to foxconn and they said they are not sure if it will be ok or not.
            will it do any harm if i test the board.
            thanks for the link to the caps for sale, i would buy one in a heartbeat cos they are really cheap apart from the shipping as you say.
            so now i dont know what to do, shall i just leave it or get a new one?
            dilema dilema!
            thanks for the help and i hope someone can say if it will be ok
            steve.
            ps, if the leg is still in the capacitor and just pulled out a bit is it ok?
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              replace the cap just to be safe. pulled leg=broken seal
              don't try testing it, you may get an unresponsive board
              and dont buy from them again, they obviously scammed you
              sigpic
              (Insert witty quote here)
              • dirtyrider
                • Jun 2009
                • 4
                hi there
                thanks for good advice, foxconn engineers were onto me today and said just to finish my pc build and boot up the board, they said it wont do any damage and if i do have any problems get back onto them, i dont know if its because of the cap and its position it may not be that important?
                i have ordered replacement caps off big pope and if i have any issues i will just replace the cap as he had ones nearly excatly the same as whats on the board already.
                thanks for all you guys help this is a very friendly and helpful site.
                cheers
                steve
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  no problem :p
                  have fun and be safe when you recap your board!
                  sigpic
                  • cheebster
                    • May 2008
                    • 374
                    Yeah just what i tought, probably just installed that way or a bit bent, it doesnt look 'that' out of position.. happened a lot of time to me, but no big deal, works...
                    • MORETTIGIAN
                      Capacitor detached from PCB – RTX 2070 Super Founders Edition
                      by MORETTIGIAN
                      Title:
                      Description:
                      During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                      I did not notice it detaching, so I am unsure of its original location on the PCB.
                      Procedure performed:
                      - Removed backplate
                      - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                      - Reapplied thermal compound
                      - Reassembled card
                      Observed behavior after reassembly:
                      - GPU powers on and operates normally under...
                      09-18-2025, 12:14 PM
                    • link626
                      TCL 43s405 4k TV only runs on lower power mode. Sound like a capacitor issue?
                      by link626
                      I've gone through 2 of these power supply boards.
                      Same issue on both. If I use TV at full brightness, full power, the screen will start blinking; go black once every 2 seconds.
                      It was fine for months before exhibiting this issue.
                      If I lower the brightness, and run it in low power mode, the blinking stops.
                      Attached photo below is the board.
                      Do you think this blinking is a capacitor issue?
                      These are all HEC brand cheapo caps, except the 82uF which is YST brand.
                      I cannot find spec sheets.
                      07-29-2021, 07:11 PM
                    • chth96
                      If I replace with inferior capacitor, Is it No harm to other IC components at all?
                      by chth96
                      I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                      Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                      It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                      So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                      I know that these capacitor will not last as long as nichicon capacitor...
                      12-22-2023, 04:34 AM
                    • chth96
                      How can I test non-polarized capacitor?
                      by chth96
                      I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                      I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                      And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                      I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                      06-02-2024, 07:31 PM
                    • rounin
                      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                      by rounin
                      🛠 Original Issue
                      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                      04-19-2025, 01:18 AM
