TCL 43s405 4k TV only runs on lower power mode. Sound like a capacitor issue?
  • link626
    • Feb 2019
    • 36
    I've gone through 2 of these power supply boards.
    Same issue on both. If I use TV at full brightness, full power, the screen will start blinking; go black once every 2 seconds.
    It was fine for months before exhibiting this issue.
    If I lower the brightness, and run it in low power mode, the blinking stops.
    Attached photo below is the board.
    Do you think this blinking is a capacitor issue?
    These are all HEC brand cheapo caps, except the 82uF which is YST brand.
    I cannot find spec sheets.
    I desoldered all the caps from the board and measured them.
    47uf measured 45.53 and 46.52
    680uf measured 683 and 678
    100uf measured 97.8 and 98.88
    10uf measured 9.56
    82uf measured 75.64
    33uf measured 30.18
    On the Hot side of the board, the 82uf cap differs most from its rating.
    On the cold side of the board, the 33uf cap differs the most.
    Would this blinking issue be from the hot side or cold side?
    I recently bought panasonic caps to repair a pc monitor, and they all measured higher than their rating.
    So this makes me suspicious of these cheapo caps.
  • neilc6
    • Nov 2015
    • 1550
    Re: TCL 43s405 4k TV only runs on lower power mode. Sound like a capacitor issue?
    You are describing symptoms of bad LED backlights, not a bad power supply board.
    • link626
      • Feb 2019
      • 36
      I doubt that, because when the tv first started blinking, I just replaced the power board, and the blinking was fixed.
      I didn't touch the backlight strips.
      Now 4 months later with the replacement (used) board, the TV is blinking again.
      This board design/components must be defective, and the blinking probably shows up after 2-3 years.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Have you checked the capacitors ESR values?
        • rounin
          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
          by rounin
          🛠 Original Issue
          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
          04-19-2025, 01:18 AM
        • ugamazing
          by ugamazing
          12-17-2024, 07:05 PM
        • shahnld
          Lenovo legion 5 pro startup issue
          by shahnld
          Good day Experts
          I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
          A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
          And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
          08-24-2025, 12:31 PM
        • ahmarzo
          Acer laptop battery draining issue
          by ahmarzo
          Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
          Help me to diagnose this issue as there is no shortage in the inputs MOSFET
          08-02-2025, 06:39 AM
        • elmark
          HP 15-cw1002ua strange keyboard issue
          by elmark
          HP Pavilion 15-CW1002UA
          S/N 5CD0251CBC
          P/N 7KE54EA
          Hello guys!
          I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
          It powers on OK and has no other issues except the following:
          • CAPS LOCK does not work at all
          • Fn button toggles Flight Mode
          • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
          • (with SHIFT pressed: 't%' and 'y^' respectively)
          I initially thought it was a keyboard malfunction (internal short, etc.),
          but when I press and hold...
          06-27-2025, 01:10 AM
