Bad cap reading 4x high?
  • jayjr1105
    • 281
    I have a swollen Sanyo WG 2200uf cap removed from the board and reading 8000uf with an LCR meter and a DMM. I always thought bad caps capacitance goes way down when swollen or leaking.
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
    Re: Bad cap reading 4x high?
    What resistance do you get when tested it in Ohm mode? What ESR do you get when tested with ESR meter?
      • 30917
      high leakage does that.
      • jayjr1105
        • 281
        Starts around 1k ohms then climbs and climbs then, in a split second, goes up to 30k.
        Ryzen 3600x
        FX-8802 Iron
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8662
          I've seen some LCR meters report incorrect numbers on leaky capacitors. The number is wrong.
            • Jul 2011
            • 6018
            First off the ESR 0.24 ohms is a give away any way
            It should be .02 anyway and the UF reading is way off to
            • jayjr1105
              • 281
              I'm not too sure about the ESR accuracy on that cheap test kit. I have thrown brand new low esr caps in there and it's shown way too high esr as well.
              Here is an example. Brand new 1000uf Panasonic FM
              Ryzen 3600x
              FX-8802 Iron
                • 30917
                they are very accurate if they are calibrated.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Originally posted by jayjr1105
                  IBrand new 1000uf Panasonic FM
                  Electrolytic caps are usually +/- 20% of their uF rating. So a 1000uF cap reading 1048uF is okay.
                  The ESR might be a bit high depending on which exact 1000uF cap you have. Check it against
                  https://cdn.badcaps-static.com/pdfs/...404c12c252.pdf
                  --- begin sig file ---
                  --- end sig file ---
                  • jayjr1105
                    • 281
                    I just ordered a .1uf cap to calibrate it. I don't have anything close sadly.
                    I didn't mean the capacitance. I meant the ESR is way too high for a brand new low ESR cap.
                    Ryzen 3600x
                    FX-8802 Iron
                    • Stefan Payne
                      • 1267
                      Yes, smaller ones are usually a bit over that.
                      Bigger ones (=High Voltage) usually are a bit under the specified value.
                      ie for a 470uF capacitor you can assume something around 440uF or something like that...
                        • 30917
                        i recommend a 0.22uf film cap for calibrating.
                        if a .1uf cap is actually 0.099uf the tester wont like it.
                          It looks like the leakage resistance causes the fault capacitance reading.
                          If you put 100K, 47K resistor in parallel with that Panasonic cap, what will it show on your cap meter?
                          • jayjr1105
                            • 281
                            Figures, I knew I should have just ordered a kit like this. http://a.co/3KgqGtE
                            Do you think my ESR readings will improve that much once calibrated? I have tested a ton of low esr caps, never once seeing anything .0X or lower. I thought that LCR tester is just junk.
                            Edit: I can put two .1uf's in parallel can't I?
                            Ryzen 3600x
                            FX-8802 Iron
                              • 30917
                              the parallel method should work.
                              you should read my very long tester thread!!
                              https://www.badcaps.net/forum/showthread.php?t=50720
                              • victor_cj
                                • May 2015
                                • 90
                                • Romania
                                LCR-T4 versus BK 880
                                https://streamable.com/acx9m
                                The art of fighting without fighting
                                • victor_cj
                                  • May 2015
                                  • 90
                                  • Romania
                                  1-6-4 Temperature Characteristics
                                  Aluminum electrolytic capacitors have liquid electrolyte. This electrolyte has properties (conductivity, viscosity, etc.) that have rather conspicuous temperature characteristics.
                                  Electrical conductivity increases as the temperature increases and reduces as the temperature decreases.
                                  Therefore, the electrical characteristics of aluminum electrolytics are affected by temperature more than other types of capacitors. The following section explains the relationship between temperature and capacitance, tangent delta, ESR, impedance and leakage current.
                                  1) Capacitance The capacitance of aluminum electrolytic capacitors increases as the temperature increases and decreases as the temperature decreases. The relationship between temperature and capacitance is shown in Fig. 1-9.
                                  2) Tanδ, Equivalent Series Resistance (ESR), Impedance The Tanδ, equivalent series resistance (ESR) and impedance changes with temperature and frequency. An example of the general characteristics is shown in Fig. 1- 10 and 1-11.
                                  • victor_cj
                                    • May 2015
                                    • 90
                                    • Romania
                                    https://www.youtube.com/watch?v=vzoDurlg_jI
                                    • jayjr1105
                                      • 281
                                      I have never from day 1 of owning the LCR-T4 seen a cap ESR that low. Even with brand new caps. I wonder if there's firmware or something to update. I still have some caps coming tomorrow for calibration.
                                      Ryzen 3600x
                                      FX-8802 Iron
                                      • victor_cj
                                        • May 2015
                                        • 90
                                        • Romania
                                        >0.1uF capacitor for calibration is the reference, Rp and Rs may make a difference.
                                        On the LCR-T4 PCB, 431(TL431) is the reference for ATMEGA328P-AU.
                                        • KYBOSH
                                          OTHER WORLD COMPUTING OWCTB3DK13PSL OWC 13 Port Thunderbolt 3 Dock - Disconnects when READING from External HD at high speeds
                                          by KYBOSH
                                          Weird one and way out of my league but I thought i drop it here in case anyone might have an idea on where to start looking.
                                          I have a Thunderbolt Dock that has been behaving fine for a long time.
                                          Admittedly I have only used it for menial data transfer tasks.
                                          A few days ago I connected a USB-C external hard drive to it and wanted to test the transfer speeds.
                                          I connected the proper high speed cables (USB-C to USB-C) and started the test with BlackMagic Disk Speed Test.
                                          It wrote to the disk just fine. Got nearly 900MB/s+ write speeds but when it came time...
                                          07-31-2024, 12:30 AM
                                          AE20218 Milliohm Meter Kit, 0.1 Milliohm Resolution, Four Wire Measurements bought one
                                          by sam_sam_sam
                                          I have been in need of a mega ohm meter for a while but just could not make up my mind to which one I want to buy and this one has a couple of things going for it can also be used on a computer to display a resistance graph plus it is a kit that you put together supposedly the only parts installed are the surface mount components
                                          I will probably make a rechargeable battery pack for so it can be used as a portable device and anywhere
                                          I kind a wish that it had a higher resistance value higher than 240 ohms at 10 milliamperes on high range but it is what it it
                                          On the...
                                          03-15-2025, 05:10 PM
                                        • ten-d
                                          Nippon Chemi-con 100uf 100v BP electrolytic cap
                                          by ten-d
                                          Hi all!
                                          I just bought a pair of ADS L810 speakers, which I've heard are some of the best speakers from that time (late 70's) into the early 80's. I was super excited to test them out and hooked them up and I was very underwhelmed by the treble. The treble was awfully muffled. I've been doing some restoration work on 70's stereos and a couple of speakers here and there so I am really just a beginner. I do know that capacitors in speaker crossovers filter out the lows to allow only the highs up to the tweeters and mids. Inductors filter out the highs to allow the lower frequencies to...
                                          01-30-2024, 05:18 PM
                                        • eccerr0r
                                          lowest current galvanometer/analog meter (passively powered!)
                                          by eccerr0r
                                          Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
                                          On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
                                          04-16-2025, 12:41 AM
                                          Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                          by sam_sam_sam
                                          I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                          I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                          12-31-2023, 06:04 AM
