AE20218 Milliohm Meter Kit, 0.1 Milliohm Resolution, Four Wire Measurements bought one
    • Jul 2011
    • 6070
    I have been in need of a mega ohm meter for a while but just could not make up my mind to which one I want to buy and this one has a couple of things going for it can also be used on a computer to display a resistance graph plus it is a kit that you put together supposedly the only parts installed are the surface mount components
    I will probably make a rechargeable battery pack for so it can be used as a portable device and anywhere
    I kind a wish that it had a higher resistance value higher than 240 ohms at 10 milliamperes on high range but it is what it it
    On the lower range it is 24 ohms at 100 milliamperes I am wondering if this voltage is to high when troubleshooting a circuit board will it activate components at a test voltage of 5 volts
    I have been using my blue ESR meter for troubleshooting short circuits and it somewhat works fairly well but it not the perfect solution for what I really need to use it for one reason is that if it sees a short it does not go as low as I would like it to go because once is registered a short it stops and that reading
    https://www.ebay.com/itm/264294130216?var=563873131846
    I am going to buy the one that is used in the automotive troubleshooting it made from the same manufacturer of one of my battery operated battery tabbing machines that I have they seem to make good quality devices
    https://www.fnirsi.com/products/hrm-10
    Resistance measurement range is up to 200Ω and the voltage measurement range is up to 100 V. The device must not be used with a DC voltage higher than 100V. Do not apply AC voltage under any circumstances.
    I might be making some high voltage battery packs in the future so this is the reason for considering this testing device as well
    • 31260
    this reminds me, i was experimenting with the Fnirsi meter yesterday and on a whim i metered a bad cap i just removed.
    it actually gave me the same ESR as my component tester did!
    i need to scope this thing and see what it's using to do tests!
      • Jul 2011
      • 6070
      If you do scope out the bad capacitor can you please post the results from your scope I would be very interested in this
        • 31260
        i'll give the capture-mode a try
          • Jul 2011
          • 6070
          I finally got this kit in the mail but I have not had time to put it together yet maybe this weekend but we will see between I have some thing that might be more pressing to get done instead but we will see what happens
          • chth96
            by chth96
            03-09-2024, 10:03 PM
          • wnlewis
            New wire for my RDE3340 Whirlpool electric range
            by wnlewis
            OK. I got the rocker switch figured out thanks to the good advice on this forum.
            Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
            This is a Whirlpool RDE3340 electric range.
            The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
            Where may I find parts...
            01-08-2025, 11:21 PM
            12-31-2023, 06:04 AM
          • emeskay
            Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
            by emeskay
            We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
            08-06-2024, 07:13 AM
          • technicalspecialist
            Vintage fan repair, copper wire question
            by technicalspecialist
            I currently have a customer's vintage fan on the work bench to repair.
            It uses an induction motor with 4 poles. One of the poles is open.
            I couldn't find the break so i cut off the original wire.
            I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
            I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
            The enamelled copper...
            03-16-2023, 12:54 PM
