No brand is safe due to rampant counterfeiting!
  • gg1978
    • Dec 2004
    • 431
    Re: No brand is safe due to rampant counterfeiting!
    Originally posted by willawake
    do you have pics?
    I don't have pictures of the particular board, but they're the United Chemicon LXV series at 6.3V. I've replaced about 4 of these boards, and i have one that hasn't seen enough use to fail yet, although i'm sure if i put a Tbird 1.3 on it, and ran it for a few months straight with Prime95, it would probably pop the caps.
    • japlytic
      • Oct 2005
      • 2086
      I meant to say that a smaller rated capacitor (a 2200uF 35V or even a 10uF 50V unit) hidden in a 6800uF 50V can.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        on Chemi-con site dated March 31 2006
        Buyer Beware
        To all of our Customers:
        Recently, we have seen a substantial increase in the number of incidents of counterfeit Chemi-Con capacitor products in the marketplace.
        Please protect yourself: only purchase Chemi-Con capacitor products from officially "FRANCHISED" Chemi-Con Distributors and Representative WorldWide!!!
        • linuxguru
          • Apr 2005
          • 1564
          Damn - I just bought some LXZ that looks genuine. I thought that only Rubycon was popular target of counterfeiters.
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            if you deal with known good supplier then dont worry.
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              #26
              here is another thing to watch out for when buying boards - lookalikes. not exactly what chemicon is talking about in their warning though. anyway if the board is only examined quickly from far away they appear to be chemicon KZG but actually they are Evercon.
              evercon
              evercon and one KZG in the middle, from the bottom. evercon are not even using consistent bung style. i have about half with one style and half with the other, same date codes.
              evercon and one KZG in the middle, from the top
              • japlytic
                • Oct 2005
                • 2086
                I'd be shocked if I manufactured equipment using Nippon Chemi-Con capacitors, finding some were counterfeit.
                I think you should ask Nippon Chemi-Con about the counterfeit capacitors, mentioning the "Evercon" brand with pictures.
                • linuxguru
                  • Apr 2005
                  • 1564
                  #28
                  Evercon is not a counterfeit, merely a passing look-alike (with different printed markings). It's very easy to distinguish an Evercon from a Chemicon. It's harder to distinguish a small Samyoung from a Chemicon.
                  The problem is with counterfeits that use exactly the same markings and text, down to the font, as the original. So far, I have encountered only suspect Rubycons (usually large cans and a few YXG) and a few Panasonic (of undocumented/outsourced series - HFA, HFE, FF, FJ). In some cases, the suspects turned to be authentic, but with non-standard can dimensions - Rubycon YXG 1000uF/6.3v in 8x12 is a case in point.
                  • PeteS in CA
                    • Aug 2005
                    • 3576
                    • USA, Unsure of Planet
                    #29
                    If a customer has sufficient volume, companies such as UCC will do semi-customs.
                    PeteS in CA
                    • japlytic
                      • Oct 2005
                      • 2086
                      Found something about fake capacitors (can-type for AC) on http://twilight.saic.com/qawg/scitre.../APPENDIXA.htm
                      Polished surfaces scratched or dented
                      Termination lugs scarred
                      Buildup of debris and dirt in termination guards
                      Plain packaging (no manufacturer bar codes)
                      Some might mark higher than normal voltage ratings on the capacitors, then someone gets annoyed when they fail prematurely.
                      • DixiePenguin
                        • Mar 2008
                        • 77
                        • Philippines
                        #31
                        Just a quick question. I have a bunch of what appear to be Chemicon except in the middle of the shield logo is a dot. Can is black with silver graphics. I had not encountered any with the dot in the center of the shield before.
                        Are these legit?
                        Thanks,
                        Bill
                        Thanks,
                        • DixiePenguin
                          • Mar 2008
                          • 77
                          • Philippines
                          #32
                          Sorry,
                          I meant to add that they are LXV series that Chemicon's site says are power supply caps, but I pulled them from an old socket 7 motherboard.
                          Bill
                          • DixiePenguin
                            • Mar 2008
                            • 77
                            • Philippines
                            #33
                            Here are photos of the caps I was asking about, are they similar to the ones you noted? These are 1500uf 10v LXV pulled from an old socket 7 board.
                            Sorry the pics are not better. All my good cameras are 35mm still out of digital step, I guess.
                            Bill
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Not Chemicon.
                              That is old Sam Young logo.
                              http://capacitor.web.fc2.com/pqrst.html#samyoung
                              Mann-Made Global Warming.
                              - Dr Seuss
                              • Scenic
                                o.O
                                • Sep 2007
                                • 2640
                                what about Rudoycons? lol
                                • JEWilson
                                  • Sep 2007
                                  • 369
                                  • Scotland, United Kingdom
                                  #36
                                  Originally posted by kc8adu
                                  i have seen this with other parts.sanken and toshiba power transistors for power amps.
                                  motorola transistors esp mj150xx types.
                                  it was hell finding a dist. with genuine motorola parts when a customer needed some cnc motor drives rebuilt.they had some counterfiet parts from the last place that rebuilt them.they would run with no load on the motor but under load they went off with a bang!
                                  Per post
                                  https://www.badcaps.net/forum/showth...hlight=X-power
                                  Might it be possible, the 2K2611 I got from a seller in China are fakes?
                                  I ask, as only when a load (only 4 HDDs) are attached to the PSU,
                                  it fails to start. For all other intents and purposes, the PSU appears
                                  good. I thought it might be the protection circuit and most recently,
                                  thought about pulling the startup resistors to test them.
                                  Any advice appreciated
                                  Thx
                                  • japlytic
                                    • Oct 2005
                                    • 2086
                                    I found a Chemi-Con 400V 22uF LXF unit in a DVD player, which had an "X" vent having different angles. They discontinued LXF series units years ago, and they never made a 400V unit of that series.
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      Originally posted by Phil_123
                                      Like this?
                                      sorry to bring up an old pic, but that is the funniest bad cap picture i have seen in a while! bump for historic purposes!
                                      sigpic
                                      (Insert witty quote here)
                                      • kc8adu
                                        • Nov 2003
                                        • 8832
                                        • U.S.A!
                                        #39
                                        hey at least when it explodes it will be contained!
                                        • ratdude747
                                          Black Sheep
                                          • Nov 2008
                                          • 17136
                                          i wonder if the fact fuhyyu primaries are so lightweight has anything to do with that...
                                          sigpic
                                          • Mark D
                                            Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
                                            by Mark D
                                            The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
                                            10-29-2024, 03:15 PM
                                          • SurrealMustard
                                            What parts can be salvaged from a plasma with a damaged display panel?
                                            by SurrealMustard
                                            I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
                                            03-09-2025, 08:29 PM
                                          • DynaxSC
                                            Asus Rog Strix B360-I Gaming - Parts Identification
                                            by DynaxSC
                                            I have an Asus Rog Strix B360-I Gaming with missing parts. I know there is a resistor missing for sure, but nearby it seems there might have been also a transistor or mosfet. Below the picture of the area on the board with the missing parts. The interesting area is inside the rectangle.
                                            I'd appeciate if somebody could make a detailled picture of this area from a working board and post it here. Getting the parts values would also be helpful. The revision of the board is 1.02 .
                                            Thanks in advance...
                                            08-23-2023, 07:56 AM
                                          • Rainy
                                            Knockoff/Counterfeit parts
                                            by Rainy
                                            Has anyone seen these?
                                            So far, I've had like 3 counterfeit parts.
                                            One was a TCON board in a guy's TV. I did everything to eliminate the short as far as to drilling out part of the board, and there was some sort of short inbetween the two sides of the board.
                                            Now I'm sitting on two power supplies that seem to make voltage out of thin air.
                                            Not sure what to do. I prefer not to get these bullshit counterfeit Chinese parts as it causes me a ton of trouble between my repairs and sellers.
                                            I have a hunch somewhere they are being swapped in...
                                            10-10-2018, 04:06 AM
                                          • lorins_core
                                            BQ24800 to can it be replaced with these parts BQ24780S
                                            by lorins_core
                                            Hello to all.
                                            may I have a question about these Semiconductor parts BQ24800RUYR? can it be replaced with these parts BQ24780SRUYR?
                                            I need some good advice and also some information about it. thank you and God Bless...
                                            05-10-2024, 07:56 PM
