Anyone recognise these?
  • Cartel
    • Feb 2006
    • 112
    Alpine 445U
    Just curious what Apline uses these days.
    I think they are Panasonic
    thanks
  • RukyCon
    A Fake Rubycon
    • Jan 2017
    • 816
    Re: Anyone recognise these?
    Photos 1 & 3: 270uF 35V Capacitors. Photo #2: 390uF 25V capacitors. Odd values for capacitors.
    I'm not a expert, I'm just doing my best.
    • aztekk
      • Dec 2015
      • 22
      They're Panasonic, since you didn't bother telling the diameter I can't say the exact series but at least FK,FC,FR have those values. Could be fake ones too.
      • lti
        • May 2011
        • 2557
        They look like FR series.
        • Sparkey55
          • Jan 2010
          • 1523
          Not odd at all. 220-270-330-390-470 all normal steppings.
          • RukyCon
            A Fake Rubycon
            • Jan 2017
            • 816
            Weird, i've never seen them before.
            • Sparkey55
              • Jan 2010
              • 1523
              You obviously have not been into vintage electronics for the last 40+ years of your life.
                • 31267
                or read the datasheets
                • rhomanski
                  nowhere man
                  • 5157
                  • U S of A
                  Or even lived forty+ years?
                  sigpicThe Sky Is Falling
                  • RukyCon
                    A Fake Rubycon
                    • Jan 2017
                    • 816
                    I feel like i'm being shamed right now...
                    I do read datasheets.
                    I've taken apart many electronics new and old and never came across those two values but i have seen other "less common" ones like 150µf, 560µf and 68µf.
                    The reason why i've have not seen them in datasheets is because if i'm looking for a certain size i end up skipping over all of the others until i find the one i'm looking for.
                    I feel like i should just leave.
                    • rhomanski
                      nowhere man
                      • 5157
                      • U S of A
                      Shame is good, builds character!
                      When you can bend over in the middle of Wal-mart and puke your guts out and not feel shame, you've got enough character. Not until.
                      • jazzie366
                        • May 2016
                        • 304
                        Originally posted by Cartel
                        Alpine 445U
                        thanks
                        As a car audio fnatic who does massive builds (6000W RMS, dual 15's in a coupe, etc.) I can tell you that Alpine is one of the best brands out there, right up there with JL Audio (JL is the best, hands down).
                        The last Alpine amp I had to open was one that was shaken so hard the pins that went from the PCB to the RCA jacks had broken off and shorted out all of the mosfets on one side, killing the amp completely.
                        However, the build was always amazing. Dual switching transformers, all caps were either Elna, Nichicon or Panasonic, never seen anything else inside them (except for older ones and some of the newer class D ones that have had NCC in them).
                        I would be extremely surprised if they were fake, especially considering how costly these amps are.
                        To put the cost of the amp in perspective, their 1000W class D monoblock is ~400$ depending where you get it. A standard class D amp from a brand like SoundStream (who also makes great stuff) is about 150$, both are certified to make their power AND have been tested to make more or over their rated power.
                        IMO, they're probably real panasonic caps, which wouldn't be anywhere out of the ordinary.
                        Also, Alpine makes the stereos in higher end Buick cars, and they make the stereos for Jaguar and a few others.
                        Popcorn.
                          • 31267
                          alpine was the high end option in BMW's - not sure if it still is.
                          low end option was Blaupunkt!!!!!
                          • BigPete
                            Panasonic Heatpump Dryer Repair
                            by BigPete
                            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                            Unfortunately the whole machine has to come apart to fix it.
                            I have...
                            11-01-2025, 06:40 PM
                          • Andre Gilbert
                            by Andre Gilbert
                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                            11-20-2024, 08:52 PM
                          • AquaMan Ua
                            by AquaMan Ua
                            05-17-2025, 09:40 AM
                          • stecos
                            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                            by stecos
                            Hi everyone!
                            For my passion for technology I'm now collecting several...
                            11-28-2022, 11:39 AM
                          • aa10aa10
                            Panasonic Toughbook CF-33 mk1 BIOS repair
                            by aa10aa10
                            Good day,
                            I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                            I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                            01-21-2025, 06:13 AM
