3300uf vs 3900uf
  • WeaselXP
    • Oct 2015
    • 107
    3300uf vs 3900uf
    I am working on my parents 32 inch samsung tv (LN32A450C1D) from 2008.It had a bad 2200uf cap on the PS that I replaced. I was in the process of replacing all the larger value capacitors but there is a 3300uf 10v and I only have 3300uf 16v and it's too tall to fit. I do have 3900uf 10v Rubicon ZLS caps with a measured capacitance of @3700uf. Could I get away with this?
  • petehall347
    • Jan 2015
    • 4451
    Re: 3300uf vs 3900uf
    if its a filter it might be ok . try it and see .
    • paulstef
      • Dec 2013
      • 724
      Very likely yes.
      • WeaselXP
        • Oct 2015
        • 107
        OK, it works. Thanks!
        • Oldschool297
          RELAND SUN 6.3v 3300uf Low or High ESR?
          by Oldschool297
          I found these, i would only like to try them on a board to see if it post. It don't post at the moment, i guess there are 9 6.3v 3300uf that can be broken. Is these low or high esr? I did not find info on the web.
          https://www.amazon.de/-/en/10-Capaci...s%2C469&sr=8-1
          08-14-2023, 04:32 AM
        • ssl6
          MSI K7T266 Pro (Ver. 1.0)
          by ssl6
          Hey Everyone,
          Long time lurker, but I think this is my first time posting.
          Just looking for some assistance on identifying some suitable replacement capacitors for an MSI K7T266 Pro (Ver. 1.0). I just got my hands on two of them actually, both working but one has some visibly bulging capacitors and the other has a few that I can't tell for sure if they're bulging because it's faint at best if they are.
          I'll be honest I don't fully understand much on capacitor spec sheets beyond voltage and capacitance but I can solder like nobodies business so I've...
          11-09-2023, 01:00 PM
        • Satdude
          2700uF instead of 3300uF
          by Satdude
          Hey guys, I have a question. I need to replace the caps on my og Xbox motherboard, but I can't buy quality capacitors in my country with this specification (everything is either out of stock, with a minimum order of 1000 or just plain too big to fit in the Xbox). Can I replace the 5 3300uF caps with 5 Panasonic 2700uF caps? Thanks
          02-12-2023, 06:23 PM
        • EFritz20
          Available replacements Rubycon MBZ 3300uf 6.3v low ESR?
          by EFritz20
          I have a few busted Rubycons MBZ 3300uf 6.3v that are used for VRM purposes on a socket A motherboard. According to spec 12 mOhm with 2800 ripple.
          I have used the search engine and it appears the Panasonics are the ones to get, but those are topics already years old and these electronic ultra low ESR caps aren't availably anymore .
          I can't seem to find any available caps on the known sites that are in spec of these Rubycons. Also i can't find Polymers with 3300uf or even close to that. Closest ones i found where 2000/2200uf ones but...
          05-20-2021, 10:22 AM
        • ajdrenter
          Picking caps for Antec SU-380
          by ajdrenter
          In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
          https://www.badcaps.net/forum/showthread.php?t=14159
          It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
          05-13-2023, 10:40 AM
