Available replacements Rubycon MBZ 3300uf 6.3v low ESR?
  • EFritz20
    • Nov 2020
    • 11
    • BE
    I have a few busted Rubycons MBZ 3300uf 6.3v that are used for VRM purposes on a socket A motherboard. According to spec 12 mOhm with 2800 ripple.
    I have used the search engine and it appears the Panasonics are the ones to get, but those are topics already years old and these electronic ultra low ESR caps aren't availably anymore .
    I can't seem to find any available caps on the known sites that are in spec of these Rubycons. Also i can't find Polymers with 3300uf or even close to that. Closest ones i found where 2000/2200uf ones but they are >12mOhm with smaller ripple.
    What would you guys advise as replacement caps these days?
    Thanks!
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Available replacements Rubycon MBZ 3300uf 6.3v low ESR?
    Going down a bit in capacitance is usually not a problem when poly modding.
    The reason for this is that the original designs where after the low ESR.
    It just so happens to be lower in the larger caps so that is mainly why they where chosen.
    That said it is possible to find such caps now if you want.
    Just make sure they are for the VRM output side as they are only rated for 2.5v:
    https://www.mouser.se/ProductDetail/...%2FUll8A%3D%3D
    That said if you are from Belgium and only need a few drop me a PM and I'll send some your way.
    They are nearly 20 years old though but I have successfully (for fun) used one in a recent machine and saw no I'll effects yet.
    • jayjr1105
      • 281
      https://www.digikey.com/en/products/...R1A332/2433517
      Pretty darn close in spec if you can fit a 12mm wide cap instead of a 10.
      Ryzen 3600x
      16GB Patriot 3600MHz
      MSI B450 Gaming Plus
      MSI Air Boost Vega 56
      Acer 32" 1440P Freesync
      Rosewill Capstone 750W
      Hakko FX-888D Station
      FX-8802 Iron
      MG Chem .8mm 63/37 RA 2.2%
      • EFritz20
        • Nov 2020
        • 11
        • BE
        Thanks for your answers. I have checked my poly stash and found some 4V ones for VRM output side that will probably work.
        Some more information; I would like to polymod the board, its an older socket A Asus A7N8X-E. So I would also need caps for the VRM input.
        As far as i could tell the board is still using the 5V rails for it, hence the 6.3 Rubycon caps.
        Would 6.3V polys work with a lower capacitance on the VRM input? since there aren't any 3300uf poly caps and the total uf will not match the original capacity. For instance; i found some 2000uf/2200uf 6.3v Poly caps of about 8mOhm (original Rubys are 12mOhm).
          • 31288
          try real hard to match the capacitance on the input.
          it's more reliant on the capacity to hold energy than the esr.
            master hoarder
            • May 2008
            • 12175
            +1
            For the input on a VRM, try to keep capacitance fairly close to what it was originally. Having slightly worse ESR there won't matter too much, if that's what you have to do to get the same capacitance. On that note, Rubycon ZLH will probably be close enough (there are 6.3V 3900 uF ZLH in 10x25 mm, IIRC.)
            As for the VRM output... sometimes the capacitance does matter as much as the ESR, if not more. It really all depends on the VRM design, whether it uses relatively low switching frequency or not. For example, ECS K7S5A, K7SEM, and a few other similar boards with a 2-phase low-frequency design really do need their high capacitance. But in the case of the A7N8X-E, I think that's a relatively newer motherboard with a normal (i.e. not low-frequency) VRM design on the CPU... so for the output caps, you can drop the capacitance a bit in favor of getting same or better ESR. Or you could also mix-n-match very low ESR polymers with higher capacitance electrolytic caps to get both low ESR and nearly the same capacitance as before.
            All in all, those older boards aren't that picky in reality. So any decent cap should work in there. Could probably get away with Panasonic FM/FR/FS, Rubycon ZLH, and Nichicon HW for everything and the board still running fine. Of course, if you do plan on doing extensive OC-ing (as if this is the hottest hardware today like it was nearly 2 decades ago ), then every bit of extra capacitance and lower ESR could possibly help.
            • EFritz20
              • Nov 2020
              • 11
              • BE
              Thanks for the answers. I do have one final question, might be a stupid one.. but how can i see which caps are VRM input, and which are VRM output?
              Have a look at the board here (or just use google )
              Its about the 5 under the socket and the 3 in a row above the AGP slot.
              http://hw-museum.cz/mb/8/asus-a7n8x-e-deluxe
                • 31288
                input are higher voltage / size than output ones.
                output caps are close to the cpu too.
                  master hoarder
                  • May 2008
                  • 12175
                  5 under the socket are VRM low (i.e. filtering less than 1.8V, or whatever is the highest voltage that the board can give to the CPU... so you could technically use as low as 2.5V caps here.)
                  The 3 caps in a row above the AGP slot are the VRM in... and since there is no 4-pin 12V CPU power connector, then that means these are powered from the 5V line (you can check that with a multimeter actually - the positive leg on each cap will show close to no resistance to any red wire on ATX power connector)... so either 6.3V, 10V, or 16V caps will work fine here.
                  Also, don't forget to recap your RAM VRM - that would be the circuit with the MOSFETs and toroid inductor located by the 20-pin ATX power connector. Most RAM VRMs are powered either from the 3.3V or 5V rail... but since DDR RAM uses 2.5-2.8V, it's best to use at least 4V -rated caps on the RAM output... or just 6.3V caps to be on the safe side (since 6.3V caps can be used on both the input and the output of that VRM.)
                  • TomGJ
                    Genelec 8020C Bad capacitor
                    by TomGJ
                    Hi All, So I have two Genelec 8020Cs that are about 10 years old, one of them stopped switching on. I took it apart, fuse was blown, and I've traced the short to one of the two large capacitors on the circuit board.
                    Now from looking at the Capacitors, they seem to be from Samwha's SD Series with the following specs: 3300uf, 35v, 85C, 25 x 16 mm Radial.
                    The problem is, I can't find any capacitor from Samwha's SD Datasheet that matches these specs. The closest is 3300uf, 35v, 85c but 31.5 x 16mm, with a max ripple current of 2.5A. I'm guessing the 25mm is custom made for...
                    11-02-2024, 07:45 AM
                  • withalligators
                    Looking for best replacements for Capxons, but can't find data sheets
                    by withalligators
                    Recapping the power supply board for a Samsung 305T monitor, everything is Capxon except 2 Rubycons. I can't find data sheets matching these online, so don't know what ripple numbers, impedence, etc, to look for. There are a few different looking GL series data sheet PDFs, but the listing that matches the capacitance and voltage is a much bigger case size. I've narrowed down selections with lead spacing and case diameter, and what's in stock at Digi-key
                    1 x Capxon 1000uf35v GL C720(is this a part number or batch number, can't find it anywhere) 105c
                    1 x Capxon 1000uf35v...
                    03-25-2022, 02:30 PM
                  • ajdrenter
                    Picking caps for Antec SU-380
                    by ajdrenter
                    In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                    https://www.badcaps.net/forum/showthread.php?t=14159
                    It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                    05-13-2023, 10:40 AM
                  • qwerki
                    Advice for replacements for some Rubycons in a Dell Precision 670
                    by qwerki
                    Hello, I was hoping some of you kind souls could give me some advice.
                    I have a couple of old motherboards I'd like to have a go at repairing. They come from Dell Precision 670s, and the caps have gone bad.
                    Ultimately, I intend on getting rid of them, but it's a fun project to practise my (de)soldering on, so I want to see if I can resurrect them, even if only temporarily. I'd also like to check if there's anything on the onboard RAID array I missed backing up (I don't think there is, but you never know).
                    It's the VRM caps that visibly leaked, so I removed...
                    06-20-2021, 07:20 AM
                  • ssl6
                    MSI K7T266 Pro (Ver. 1.0)
                    by ssl6
                    Hey Everyone,
                    Long time lurker, but I think this is my first time posting.
                    Just looking for some assistance on identifying some suitable replacement capacitors for an MSI K7T266 Pro (Ver. 1.0). I just got my hands on two of them actually, both working but one has some visibly bulging capacitors and the other has a few that I can't tell for sure if they're bulging because it's faint at best if they are.
                    I'll be honest I don't fully understand much on capacitor spec sheets beyond voltage and capacitance but I can solder like nobodies business so I've...
                    11-09-2023, 01:00 PM
