HP Digital Picture Frame goes black
  • sumdumgai
    • Aug 2013
    • 33
    HP 8" Digital Picture Frame model df810v1. Screen initially lights up with images but after a few minutes, the screen goes completely black. Would this likely be a capacitor problem? I've posted a picture of the board. If this is likely a capacitor problem, can those bad capacitors be identified for me on this picture? Thanks. None of the capacitors appear to be bulging.
    • Jul 2011
    • 6040
    Re: HP Digital Picture Frame goes black
    What is the part number of IC chip that has a heat sink tab to the board and also has a lot of pins on it and looks like some thing spilled on it or burned up it hard to tell which one it is
    It is on left hand side of the board toward the bottom of the board
    Can you take a closer photo of that chip thanks
    • sumdumgai
      • Aug 2013
      • 33
      Thanks. Here's another picture.
        • 31055
        conductive glue - bastards know not to use that stuff!!
        • sumdumgai
          • Aug 2013
          • 33
          Good or bad?
            • 31055
            you need to carfully remove it.
            • sumdumgai
              • Aug 2013
              • 33
              So the chip is bad? The one that "has a heat sink tab to the board and also has a lot of pins on it and looks like some thing spilled on it or burned up"?
                • 31055
                no, just remove the brown glue.
                it turns conductive with age and shorts stuff out - causes all kinds of problems.
                specially bad in psu's!!!
                • sumdumgai
                  • Aug 2013
                  • 33
                  Thanks. I'll try that. Is there a 'best' way to remove it, aside from being careful?
                    • 31055
                    not really
                    it starts like gum, and as it gets older it becomes brittle like honeycomb
                    so it's very variable.
                      • Jul 2011
                      • 6040
                      I would careful removing that glue
                      That a lot better photo
                      • delaware74b
                        • Apr 2009
                        • 628
                        Looks like there is also that conductive glue on the high voltage transformer, lower left corner of the photo in the first post. Burn mark on right side of it, likely causing the display to shut down.
                        I have had to deal with that cr!p in HP evil (EVO) mini toaster (SFF desktop) power supply that shorted out from that glue. The supply had the glue poured all over the board. It took me 2 hours to scrape it off the board. Unfortunately, I know of no other way to remove except to carefully scrape.
                        Stupidity should be a crime, especially for drivers. I have NO patience for them.
                        • sumdumgai
                          • Aug 2013
                          • 33
                          Thanks for all the help. I'll give it a try and let you know how it turns out.
                          • sumdumgai
                            • Aug 2013
                            • 33
                            No luck. Removed most of the glue (using acetone to first soften). See picture. Now, the screen will not light at all.
                              • Jul 2011
                              • 6040
                              Look at the pads on the transformer the soldiering joint on the left hand side dose not look very good and another one a few pins from that one dose not look
                              Good either I would resoldier all the pins on the transformer
                              If you have an ( ex-o-knife or very thin blade screw driver)I would try to remove more of the glue but be very care not to dig deep in to the board
                              • sumdumgai
                                • Aug 2013
                                • 33
                                Thanks. Is there any way you can point to the areas/pins you're referring to on the picture and re-post it?
                                • sumdumgai
                                  • Aug 2013
                                  • 33
                                  Not sure which pins you're talking about. But anyway, what is the purpose of this 'conductive glue'? Is it already conductive and used in place of solder, or is it just glue and it becomes conductive with age? Thanks.
                                    • 31055
                                    becomes conductive with age.
                                    probably used intentionally as a "suicide" device to limit the life of the equipment!!
                                    • sumdumgai
                                      • Aug 2013
                                      • 33
                                      Ain't that a Btch! But now I'm wondering why removing some of the glue made the problem worse. I was really careful to not damage the board or any connections.
                                        • 31055
                                        look at your foto, it looks like you may have cracked a resistor and possibly dislodged the soldering on a cap or 2.
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • kerberos137
                                          Sony xbr-65x930e faded to black; now has backlight but no picture
                                          by kerberos137
                                          Hopefully someone can help me out. This tv was working perfectly until a few weeks ago. At some point, the TV just faded to black, but sound continued playing. It almost looked like smoke on the screen as it faded from the bottom left corner toward the top right. Took only a second or less, but wasn't instant. After restarting, it turned back on and worked fine for another day or two. Then it happened again more or less the same way, but in a slightly different direction, again with sound continuing. I thought it was working fine after another restart, but looked a bit dimmer than before. Then...
                                          11-29-2022, 05:40 AM
                                        • S14Sr20det
                                          Nec E557Q lines and fade to black picture FIXED
                                          by S14Sr20det
                                          Trash picked this tv from a local business, had a garbage image and would fade to black within second then cut off. It would get shorter and shorter every time.
                                          Narrowed it down to the right side of the panel by unplugging half the t con
                                          One side had a great picture the other was black and distorted still.
                                          Down to the buffer boards… found yet another set of two esd diode arrays. One leg had a 60 ohm short to ground and would get lower the more attempts made to turn the tv on.
                                          Soldering iron and some chip quick knocked both of them off and...
                                          06-17-2023, 02:55 PM
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
