Whirlpool WRF40 fridge Metallized Polypropylene Film Capacitor Replacements?
  • RickyZA
    • Jan 2017
    • 33
    • South-Africa
    Hey there everyone,
    So my controller board on my fridge which has 5 temperature settings which are displayed by leds on the front of the fridge has decided to only work on setting 1, 2 or 3, switching it to 4 or 5 causes the lights to flash and the fan kicks in and goes off repeatedly, i have phoned somebody who had the same problem and has told me to replace the 2 yellow capacitors, from what i see these are EPCOS Capacitors, 1u 250v & u47 250v, Model number : B32669.
    It seems like the board isnt worth alot of money but down here where im staying they want to charge 250$ for it..
    Datasheet : http://pdf1.alldatasheet.com/datashe...OS/B32669.html
    This company is local to my country and i was wondering if any if these capacitors listed would be applicable :
    http://za.rs-online.com/web/c/passi....264,4294464783
    http://za.rs-online.com/web/c/passi....766,4294464783
    it needs about 5 seconds to load the filters i added.
    Any help will be greatly appreciated.
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: Which Metallized Polypropylene Film Capacitor Should i use ?
    I get blank forms - stuff at the top and sides, but no particulars about any parts. Did you notice the "~" after the "250V" on those capacitors? That means that the rating is 250VAC.
    The B32669 series was, I think, originally a Siemens part. They partnered with Matsushita (Panasonic) to create Epcos. Siemens and Matsushita sold their holdings in Epcos in 2006, and TDF acquired Epcos. The B32669 series was discontinued in 2014.
    Vishay has several axial lead AC rated MKP series. You might see if any of those are available there in South Africa.
    PeteS in CA
    • redwire
      • 3912
      I would use any X1 or X2 rated film capacitor, polyester or polypropylene.
      Axial film caps are harder to find and expensive like 10X. If you measure the lead spacing, maybe put in a boxed part. But watch the height.
      Example http://za.rs-online.com/web/p/polyes...itors/8741481/ or http://za.rs-online.com/web/p/polypr...itors/1247430/ or http://za.rs-online.com/web/p/polypr...itors/8829496/
      The electrolytic caps (c4 etc) I would change out too.
      • RickyZA
        • Jan 2017
        • 33
        • South-Africa
        Hey there Pete, not sure what you mean by blank forms, do u mean i should of put a bigger picture of the whole board ?
        I did notice the ~ , had no idea it meant vAC, learnt something new !
        This board has been running 14 years so it makes sense that it has the old epcos caps, i did see a TDF data sheet on some similar caps i think. ill see if i can find it.
        Ill definitely take a look at some of the Vishay caps then, i think i do know a supplier, could i ask is there anything else i should be looking for when matching these capacitors ? Besides Voltage, capacitance, polypropylene dielectric etc ? Thank You
        • RickyZA
          • Jan 2017
          • 33
          • South-Africa
          Appreciate the help Redwire, im not too shy spending some money on these, as long as they are matched the closest as possible, ill probably go with polypropylene to match the previous Caps, a boxed part sounds fine, there is quite alot of head space where the pc board is mounted so i doubt it will be a problem at all, would this sort of capacitor work man ? http://za.rs-online.com/web/p/polypr...itors/1908450/ it is rated for 630v DC and 250v AC , would this work ? Ill change out the the elec caps for sure man, thanks for that!
          • redwire
            • 3912
            Capacitors with suppression rating X1 or X2 can withstand overvoltages from lightning etc. so they are the toughest part. You don't have to have them for this board, and the one you linked to is fine without that approval.
            Big 27.5mm lead spacing, if it fits the PCB.
            I find film caps fail short-circuit, so I am not sure these parts are the problem with the board. Let us know how it turns out.
            • Agent24
              I see dead caps
              • Oct 2007
              • 5038
              • New Zealand
              Your links to RS-Components are bad. Something has copied the shortened version for display and trashed the URL.
              -David VanHorn
                So the caps no longer show the capacitance as 1uF and 0.47uF when tested?
                • RickyZA
                  • Jan 2017
                  • 33
                  • South-Africa
                  That makes sense redwire, so they just way more durable caps then ? so the ones i linked would work but they are not recommended because they cant withstand such overvoltages ? So pretty much wasting my time going with non x1 or x2. Spacing shouldnt be a problem with any box cap, the enclosure that the pcb is in has alot of headroom, id say almost 2 inches.
                  Would i be wrong to say that a capacitor like this could sort of half work ? Or in other words lost some of its capacitance ?
                  Here is another picture of the pcb maybe you could tell me what else you think has gone wrong ? Thank You man !
                  • RickyZA
                    • Jan 2017
                    • 33
                    • South-Africa
                    Sorry about that but i guess we can ignore it , if the link to the the datasheet of the current B32669 capacitor shows then atleast we can use that as a baseline on finding a new replacement, the links i gave are probably not the right type anyway.
                    • RickyZA
                      • Jan 2017
                      • 33
                      • South-Africa
                      I havent checked that man, i need to but after 14 years of running the same capacitors ? I mean wouldnt you say its due for a change ? How long can metallized polypropylene film capacitors actually run for ? Could they do 20 years ? 30 years ? 40 ? Im not even sure myself.
                      • redwire
                        • 3912
                        The board looks like a sturdy design, 14 years is nothing. Here is a CERN research paper on film cap failure and lifetime.
                        If you can measure the two film caps, that will tell you if they are bad. There are MOV's for surge protection R22, R23 so you don't have to use X-caps.
                        It sounds like power cuts out when many LED's are on?
                        I am guessing but DZ1, C11, C4 are for power to the voltage regulator near R8, maybe +5VDC for the MCU. DZ2, C10, C5 are maybe for the relay power RL1.
                        Taking some voltage measurements across DZ1 and DZ2 will tell you if board has enough DC power. Or you can change parts and hope it fixes things.
                          Those two caps look to be used Vdrops capaciitive power supply for drooping line Voltage for low level dc power supplies.
                          The lytics caps on the board should be changed for sure.
                          • RickyZA
                            • Jan 2017
                            • 33
                            • South-Africa
                            THanx for the reply once again Redwire, i take it you get boards that last quite alot longer than 14 years ! Thats intense !
                            I havent measured the film caps as of yet, i did order replacements though & i did get x-rated capacitors, you said i dont have to use them but using them wont be a problem right ? I got 5x1uf 250v & 5x0.47uf 250v Panasonic Caps as such :
                            http://za.rs-online.com/web/p/products/6225075/
                            Board does cut out when all leds are on, even on setting 4 as there are 5 settings, currently on setting 3, when i go to setting 4 or 5 all leds start to flash and fan inside fridge goes on and off along with the flash.
                            Im not too good at reading voltages across boards, if you can give me some tips maybe i could give it a try man ? Im hoping its one of these capacitors though.
                            • RickyZA
                              • Jan 2017
                              • 33
                              • South-Africa
                              Hey budm, so you think those two caps used for dropping line voltage are kind of finished aswell ? I have received all lytic caps for the board, will be replacing them for sure ! got some good quality ones too !
                              • RickyZA
                                • Jan 2017
                                • 33
                                • South-Africa
                                Hey guys just an update, i installed the two capacitors the ones that i linked in the post when i quoted Red and the fridge is back! all settings are working! i havent replaced the electrolytic capacitors just yet, not really keen to tinker more if i dont have to, what do you guys think should i replace them now ?
                                To anybody else viewing this thread this fridge is a Whirlpool WRF40, i should of put this in the topic but hey maybe this post helps you pick it up : )
                                • UHU
                                  • Sep 2016
                                  • 35
                                  Personally I would replace the electrolytic capacitors because after 14 years they would be past their best and could still fail blowing something else in the process - electrolytics are generally more delicate than film capacitors - if your fridge is the type with PID Temperature control (a lot of Liebherr Fridges / Freezers are [Liebherr make ALL Miele fridges and freezers] but I am not sure about Whirlpool/Philips) you would suddenly find out just how accurate temperature control can be!
                                  • RickyZA
                                    • Jan 2017
                                    • 33
                                    • South-Africa
                                    Your right man, i have all the necessary replacements, i should pull that board soon and give them a replacement. Fridge still working perfectly since i replaced the two film caps, so your implying i would get better temperature control with the newer lytics ? Thanx : )
                                    • Wayno
                                      • Jul 2017
                                      • 8
                                      • South Africa
                                      Hi RickyZN,
                                      I have the same problem with my Whirlpool WRF40 fridge, Please could you send me a picture of the board with the new components soldered on if possible, I am newb to this kind of thing and would like to double check everything before I attempt the repair.
                                      Thank you.
                                      Regards,
                                      Wayne
                                      • Per Hansson
                                        • Jul 2005
                                        • 5895
                                        • Sweden
                                        What is it that you need to see?
                                        The pictures posted by RickyZA makes things very clear.
                                        I have attached them to his posts in case you could not see them.
                                        • wnlewis
                                          Whirlpool RDE3340W electric Range needs On-Off-On rocker switch, McGill 0801-1059, FSP 686605, Whirlpool p/n 865745
                                          by wnlewis
                                          I am trying to track down a replacement rocker switch for a Whirlpool RDE3340W electric range.
                                          The rocker switch was made by McGill under their part number 0801-1059 and supplied to Whirlpool by FSP under their part number 686605. Whirlpool's original part number was 865745.
                                          The switch is an On-Off-On type (SPDT) designed for use with either 115 VAC or 230 VAC. It is not lighted.
                                          Are there any current switches that could be substituted for this switch?
                                          01-04-2025, 09:32 PM
                                        • mikey5791
                                          Help repair Panasonic fridge not cooling
                                          by mikey5791
                                          Hi all forum members,
                                          Few days ago, i might have forgotten to close my home fridge freezer door completely. The next day, the ice cubes and frozen meat almost melted halfway and the freezer doesn't feel cool. I shut it off, wipe dry and let it air dry for one whole day. The next day i switched on the fridge, the compressor run for a second and it shuts off(no vibration and no sound at all) only the internal freezer compartment fan is running but is not cooling even i switched on a full day.
                                          After shut off, i dismantle the rear water pan holder and reached to the compressor wiring....
                                          07-16-2025, 02:01 AM
                                        • CG2
                                          Liebherr Fridge Freezer KGT 3456 not working
                                          by CG2
                                          To be a bit more specific, I've got a 20-ish year old Liebherr that has just stopped working. This was quite a sophisticated beast for its time. It's a twin compressor model, and you set the desired temperatures of the fridge and freezer parts from a couple of little control panels above the door. It displays the actual temps on some eight segment displays there, flashing if it's working to get to where you want it. There's a control board with a microprocessor on it that read the temperature from a couple of sensors, switches the compressors on as necessary, and runs the display. There's also...
                                          01-25-2023, 02:12 PM
                                        • tmcw
                                          Fridge - Gram
                                          by tmcw
                                          Have this fridge, laboratory grade unit, not working fully.
                                          It's designed with a chilling unit at the top, on the inside, and a fan just below that. When the door is closed, the fan blows the cold air down through the fridge, and when the door opens, the fan switches off, presumably so that it doesn't blow all the cold air out.
                                          The fan isn't switching on, so in addition to not having uniform cold throughout the fridge, the chilling tubes tend to ice up. I took the lid off the top, electronics are in the lid, and when the door is opened and closed, I can hear the relevant...
                                          10-10-2023, 05:00 AM
                                        • Joe24
                                          Maytag Whirlpool Kenmore clothes dryer data bus
                                          by Joe24
                                          Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
                                          Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
                                          I've been over the board looking for...
                                          01-13-2025, 06:50 PM
