How bad does a bad cap look?
  • catleugh
    • Aug 2016
    • 3
    • United Kingdom
    My tv stopped working this week, blank screen & no sound, but power OK. Took the back off and had a look at the main board. It looked OK at first, but when I had a closer look at the capacitors, saw that 5 of them had very slightly bulging tops. Think that may be the problem? I've sent for some replacements anyway, because if it's anything else it will be cheaper to buy a secondhand TV, rather than get this one repaired.
    • 31028
    Re: How bad does a bad cap look?
    caps go bad BEFORE they look bad.
    so if they look bad - they are very bad!
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      Originally posted by stj
      caps go bad before they look bad.
      So if they look bad - they are very bad!
      This! +1
      This site has a resource on that: https://www.badcaps.net/index.php?pageid=identity
      Follow the white rabbit.
      • catleugh
        • Aug 2016
        • 3
        • United Kingdom
        Thanks guys.
        • cdrsteve
          • Aug 2016
          • 18
          I too feel your pain. After literally years of procrastination, I finally got serious about opening up my Sammy 61A750 DLP to do some long overdue cleaning and repair its increasingly noticeable "white dot" problem. This TV has VERY HIGH usage so in the back of my mind I "knew" there would be other (cap) issues once I got inside. Not only did I find numerous bulging PS caps (and I mean BULGING), I found one totally open (560 uf/200wv) and many more with bad ESR and/or capacitance levels. Needless-to-say, they are all now sitting on my bench with their legs in the air while I research replacements. Thank you "SAMWA" for years of service but you will be replaced with Pannys!!! Good luck on your set - don't give up..... repairs can be "fun"!
          • Mint Waxed
            • Aug 2016
            • 35
            For your viewing pleasure, here are some really bad looking caps.
            https://www.google.com/search?q=capa...w=1030&bih=887
            • bianchi77
              • Jun 2016
              • 1121
              How can we know the caps are bad if they don't look bad ?
              • junktv
                • Nov 2010
                • 3065
                These are still working.
                  • 31028
                  with an ESR meter
                  • joshnz
                    • Feb 2011
                    • 969
                    • New Zealand
                    ESR meter.
                    i have had many caps that look like new that are bad
                    My pc
                    CPU : AMD PHENOM II x4 @ 3.5Ghz
                    MB : ASUS M4A89TD PRO USB3
                    RAM : Kingston ValueRAM 16gb DDR3
                    PSU : Cooler Master 850W Silent Pro
                    GPU : ATI Radeon HD 6850
                    • Mint Waxed
                      • Aug 2016
                      • 35
                      Place a stethoscope on the top and listen for a gurgling sound.
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        no they are not.those are open now.
                        the 2 polys are eating all the ripple and allowing the board to limp along.
                          • 31028
                          you may want to get something like this.
                          http://www.ebay.com/itm/222210243721
                          • mikail13
                            • Aug 2013
                            • 93
                            • Turkiye
                            Originally posted by joshnz
                            ESR meter.
                            +1
                            https://www.badcaps.net/forum/showthread.php?t=56932
                            no bulging. looks like new..All of bad 400 v.
                            • cdrsteve
                              • Aug 2016
                              • 18
                              Wow, that board looks a bit rough! Used to see a lot of pcb's and components looking like that when I was repairing in Hawaii. That salt air gets to everything after a while.
                              • junktv
                                • Nov 2010
                                • 3065
                                Speaking of ripple sometimes the bestech psu powering it needs a little heat from a hair dryer to get going.
                                It needs some attention but so long as it doesn't catch on fire i'm not to concerned with it.
                                Wait actually i better get at it. I was going to move it to the garage.
                                • cdrsteve
                                  • Aug 2016
                                  • 18
                                  Amazing just how much of a difference this old set looks with a full re-cap and DMD chip replacement! Bad (and sometimes, marginal ones) caps DO make a difference!
                                  • Mint Waxed
                                    • Aug 2016
                                    • 35
                                    You can say that again! I finally got around to updating 17 caps in a Gateway FPD2185W monitor and brought it back to life. Actually, I have six of them bought on the cheap from eBay. Manufactured around 2005, they were part of the great Capacitor Plague and people not knowing a capacitor from a resistor were dumping them in droves. Originally, these monitors were msrp at around $600. The LCD has Samsung stamped on it as well as the chassis but the power & video boards were made in China. Four of them are completely restored while one still has a vertical yellow line on the LCD. Another has a cluster of pixels stuck on gray. Both with defects however are still usable. You might say my hobby is keeping old junk alive.
                                      BFG Tech BFGR550WGSPSU [LW6550SE Rev. K] – recapping & modding
                                      by momaka
                                      Rather than post in the PSU build quality pictorial thread, again I am splitting off the recapping info into its own thread. Also, I plan on doing some possible modding/experimentation on this PSU, so I figured that info would also be better to go here.
                                      The PSU in question is this one:
                                      Detailed post with parts and build quality is here:
                                      https://www.badcaps.net/forum/showpo...postcount=3085
                                      So this PSU has very simple output filtering: two 2200 uF caps on each major rail (3.3V, 5V, and 12V.)
                                      Here is a cap diagram showing the caps...
                                      06-13-2020, 12:41 PM
                                    • rattlesnake
                                      Voltage issues SY-5SSM, where's the problem? Help needed
                                      by rattlesnake
                                      I'm trying to fix this SY-5SSM motherboard (Socket 7).
                                      When the PSU is connected it powers on by itself but there's nothing on the POST card, no beeps.
                                      The BIOS EEPROM is ok (latest BIOS was flashed).
                                      All the jumpers are set ok.
                                      All the 1000µF 6.3v (14) and 1500µF 16v (2) caps are in spec.
                                      There are two 76129D MOSFETs (datasheet). I took them out and tested them and they are ok (no continuity from drain to source) in off state.
                                      But the voltage in the gate of the second 76129D fluctuates between 1.468-1.649,...
                                      01-26-2025, 11:26 AM
                                    • edugimeno
                                      Fancoil.controller with current issues
                                      by edugimeno
                                      Hi there! One friend called to say his fancoill (used for a main access cold Air courtain) controller caught fire, and asking if I could recover the half burnt board
                                      He said the design was too bad as this thing was probably designed for hot water only, as the board was places right underneath the condenser radiators
                                      I found some burnt traces and after a quick Google search for the board name (Pwr-05v-w) I could see an image of the original I was able to find where the original traces were going
                                      The scheme seems simple, from what I understand mains gets into the while 3 lead...
                                      07-26-2024, 01:02 AM
                                    • Amraks
                                      Tops of resistor have seperated
                                      by Amraks
                                      Hey need a temporary solution for a emergency repair on these resistors this will not be long term but it will need to last a weekend in a cross over circuit. as I can't find these 66 ohm 20w valued resistors in Australia. The resistors are reading fine but I'm wondering what type of bonding I can use to stick these back together....
                                      09-25-2019, 09:57 PM
                                    • Bogbog
                                      Macbook Air 2019 A1932 / 820-01521-A No power
                                      by Bogbog
                                      I recently acquired a faulty Macbook Air 2019 A1932 with mainboard 820-01521-A.
                                      Seller claimed that device just stopped working suddenly.
                                      Device does not boot or give any signal of life other than the white led on mainboard.
                                      Using cheap multimeter and microscope I went trough list of semi-random diagnostic steps:
                                      Voltage measurements
                                      Charger in USBC-B (closer to display) everything disconnected.
                                      PP20V_USBC_XB_VBUS 20.7v
                                      PP3V3_UPC_XB_LDO 3.25v
                                      PP1V8_UPC_XB_LDOA 1.81V
                                      PP1V8_UPC_XB_LDOD 1.80V...
                                      02-26-2024, 05:04 AM
