Macbook Air 2019 A1932 / 820-01521-A No power
  • Bogbog
    • 5
    • Finland
    I recently acquired a faulty Macbook Air 2019 A1932 with mainboard 820-01521-A.
    Seller claimed that device just stopped working suddenly.
    Device does not boot or give any signal of life other than the white led on mainboard.
    Using cheap multimeter and microscope I went trough list of semi-random diagnostic steps:
    Voltage measurements
    Charger in USBC-B (closer to display) everything disconnected.
    PP20V_USBC_XB_VBUS 20.7v
    PP3V3_UPC_XB_LDO 3.25v
    PP1V8_UPC_XB_LDOA 1.81V
    PP1V8_UPC_XB_LDOD 1.80V
    PP1V1_UPC_XB_LDO_BMC 1.8V
    PP1V8_SLP_S2R 1.81v
    PP3V3_G3H_RTC 3.3V
    PHV_INT_XA_G3H 0V
    PP5V_G3S 0V
    Charger in USBC-A (closer to trackpad) everything disconnected.
    PP20V_USBC_XA_VBUS 5.16v
    PP3V3_UPC_XA_LDO 3.32v
    PP1V8_UPC_XA_LDOA 1.80V
    PP1V8_UPC_XA_LDOD 1.79V
    PP1V1_UPC_XA_LDO_BMC 1.11V
    PP1V8_SLP_S2R 1.81v
    PP3V3_G3H_RTC 3.3V
    PHV_INT_XA_G3H 0V
    PP5V_G3S 0V
    Readings in diode mode, positive probe in ground.
    USBC_XB_CC1_CONN 815
    USBC_XB_CC2_CONN 793
    USBC_XA_CC1_CONN 805
    USBC_XA_CC1_CONN 816
    Resistance measurements (from ground to probe)
    PP5V_G3S 25kohm and raising
    PP3V3_G3S 0ohm (shorted?)
    Other observations:
    - I didnt see hints about liquid but there was some stuff and dirt around CD3215COOZ chips and battery chips. I cleaned them using isoprophyl alcohol and brush.
    - Capacitor C7670 is missing. I found it detached (and lost it).
    - U3100 (CD3215COOZ) feels warped - with finger it feels like there is slight bumb.
    - Charger cable had yellow coloring in rubber and it looked like broken. Possible cause?
    - When usbc-b is connected SYS_DETECT_LED blinks slowly.
    - When usbc-b is connected SYS_DETECT_LED is constantly lit.
    - No obvious hot spots detected using Flir heat camera. Allthough i'm not sure if the resolution is good enough.
    - At first i measured battery at 11v but now it shows 10v.
    I have feeling that CD3215COOZ chip replacement is typical case but is it here? I have read many forum posts, watched youtube videos and tried to understand how this works, but now I feel that I would really need some advice. Can you help me further?​
  • mon2
    • 14713
    Continue to use USB-C port since it can negotiate the PD contract for 20v.
    What is the voltage to ground of P5VG3S_EN_DLY ? Some trouble here if the output rail is @ 0 ohms to ground. Checking if the enable signal is present for this power rail or not.
    What is the voltage to ground of PPBUS_G3H ?
    • Bogbog
      • 5
      • Finland
      OK, here are the measurements:
      P5VG3S_EN_DLY 0v
      PPBUS_G3H 12.7v
      Thanks for your reply, I appreciate it.
      • mon2
        • 14713
        Try a DFU restore.
        reference:
        MacBook Air A1932 Not turning on, missing P5VG3S EN signal repair - Repair Wiki
        Continue to post your updates here.
        • Bogbog
          • 5
          • Finland
          I managed to put device to dfu mode but both revive and restore actions fails. Device is titled as Apple controller in Apple configurator.
          Progress bar stops at about 1/3 on step 4/4 Installing System.
          Finally Apple configurator displays error message: "The system cannot be restore on this device. Gave up waiting for device transition from DFU state to DFU state. [com.apple.MobileDevice.MobileRestore - 0xFCA (4042)]"
          I noticed that battery voltage raised from 10 to 11 when trying to restore. Apparently it is charging.
          • mon2
            • 14713
            Try this:
            https://boards.rossmanngroup.com/thr...2-error.64310/
            • Bogbog
              • 5
              • Finland
              I have tried dfu restore with two cables (Apple charger cable and high quality usb-c display- & charging cable)
              - target battery disconnected
              - target battery disconnected, target power connected
              - target battery connected
              - target battery connected, target power connected
              Same result always, apple configurator hangs on step "4/4 Installing System". Host machine is 2018 MacBook pro with most recent MacOS.
              • Tuxedo Gaming
                • Mar 2024
                Hi bog bog, any updates on your MacBook? I find myself in a similar situation unfortunately. Additionally where can I find the schematics for the MacBook in question. I’d appreciate it if you could link it
                regards
                • bouch
                  unlock macbook air A1932 2019
                  by bouch
                  hi
                  i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                  i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
                  i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
                  have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
                  I need help or information?
                  Does anyone have the minat2 activator 1.4 software?
                  Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
                  Thank yo...
                  03-12-2025, 10:14 AM
                • nikolayu
                  MacBook Air A1932 internet recovery loop
                  by nikolayu
                  I have A1932 that is going to internet recovery every time.
                  i tried nvram and smc reset but it looks that MacBook is not reacting to that.
                  i tried to restore it through DFU but it restarts in the middle of process and Apple Configurator does not show any error, just stays like in progress.
                  keyboard is working because I can connect to WiFi but internet recovery always fails with 2100 or 2003 error.
                  also won’t open option to boot from usb device.
                  and I noticed that is not possible to turn off the MacBook. It’s always turning on by itself.
                  07-22-2025, 02:55 AM
                • TOMÁŠ
                  MacBook Air A1932
                  by TOMÁŠ
                  Hi, I've never worked with a MacBook before, so I need some advice.
                  I have a MacBook Air A1932 (820-01521). When I plugged in the charger with an amp meter, it showed 19.7V and 1.9A, which indicates that it's charging, but when I press the power button, it doesn't turn on. So, I disassembled it, disconnected the battery, and plugged in the charger again. It showed 19.6V and 0.04A, and pressing the power button had no effect—no current draw at all. Then, I removed the motherboard, connected the charger again, and got the same results. I took a multimeter and checked all the coils, and everything...
                  05-20-2025, 11:19 AM
                • Arshad alam4659
                  macbook air a1932 sign out of find my
                  by Arshad alam4659
                  Today I receive a MacBook Air A1932, its apple ID has been deleted but when I am resetting it is showing a message(sign out of find my ) customer's have no apple id he bought this MacBook from someone else can someone help me remove this message...
                  04-09-2025, 12:37 AM
                • astroboypaul
                  Macbook A1932 Some Keys Not Working
                  by astroboypaul
                  Macbook A1932 had completely dead keyboard. I found liquid damage on circuitry on keyboard itself, and repaired it by replacing what i think was a 10k 0201 resistor (here's my post requesting schematic for keyboard circuitry where I included a photo of the resistor: https://www.badcaps.net/forum/troubl...ic-820-01294-a)
                  Now most of the keyboard works and I can login, but the following keys don't work: Delete, "/', left...
                  06-10-2024, 05:32 AM
